New exhaust setup 14 E63s
Old May 17, 2018 | 12:52 AM
g60wall's Avatar
2014 E63s
Car is eurocharged tuned, the h pipe really makes the idle smooth. Car has no mufflers also not as loud as you would think.
I ran a 11.07@127.5 on stock resonators, going to give this a goo this when the rain lets up.
Old May 17, 2018 | 12:57 AM
g60wall's Avatar
2014 E63s
Old May 17, 2018 | 01:02 AM
g60wall's Avatar
2014 E63s
3rd gear
Old May 21, 2018 | 11:15 PM
Ed99's Avatar
E63s AMG
Originally Posted by g60wall
thanks for the vid. I agree an exhaust delete isn’t crazy loud with minimal drone on an E63s. Would you have a drive by vid?
Old May 21, 2018 | 11:22 PM
g60wall's Avatar
2014 E63s
Old May 22, 2018 | 07:43 PM
Savage212's Avatar
2014 E63 AMG wagon
Woo hoo! Sounds like a frigging race car !
Old May 23, 2018 | 09:08 PM
Ed99's Avatar
E63s AMG
Wow I think yours is louder than mines due to the H pipe you put in there. Did you get more pops with the H pipe?
Old May 23, 2018 | 09:13 PM
g60wall's Avatar
2014 E63s
Yea, a lot of pops but probally more a result of not having cats.
With out the H pipe you get a rough idle, I have gutted stock cats. Removed the braket around the exhaust looks a lot cleaner. Will get a rear diffuser soon!
Old May 24, 2018 | 03:32 PM
Savage212's Avatar
2014 E63 AMG wagon
I have to get under the car and see how easy it is to gut the cats.
Old Jun 12, 2018 | 09:10 AM
CerBErusM113's Avatar
2015 CLS63 S AMG
It's pretty easy, about 10 bolts to remove, 2 on each cat, 2 on each midpipe bracket and 1 on each side of the resonator coupler and then you'll want to cut the cat to put an impact hammer or screw driver/chisel to get to the catalyst material. There are 2 walls of it as well One in front of the Secondary O2 and one behind it. The primary O2 is on the top of the pipe and the secondary O2 is in the middle of the cat. Kind of strange IMO compared to previous AMGs that had them on the lower pipe.
Old Jun 12, 2018 | 11:14 AM
Hdaddy's Avatar
2016 E63S
Dude...that sounds AWSOME. Personally...a little louder than I would want but still. NICE!
Old Jun 16, 2018 | 12:53 AM
Ed99's Avatar
E63s AMG
Did you hit 11.07 with your gutted cat and tune? Those are great numbers with just a tune from Eurocharge. What is the hp and torque gain?
I was thinking of Renntech, Weistec, or Eurocharge.
Old Jun 16, 2018 | 11:39 AM
g60wall's Avatar
2014 E63s
11.07 was on nothing else than gutted cats and muffler delete to along with my eurocharged tune. I also am running OEM plugs gapped to .022. There literally no discussion eurocharged > the rest. I did a $200 cat delete(gutted stock cats) and $100 muffler delete and running the 10th fastest time on drag times. Needless to say the proof is in the pudding on this one.
Old Jun 16, 2018 | 08:11 PM
vdubpower's Avatar
i drive them all, fast and hard
ok question about gutted cats??? the reason for this is what? sound? or power? or both
why not just remove the cats?
thanks....
oh and im sure u guys saw this dude
Old Jun 16, 2018 | 08:46 PM
2015 CLS63 S AMG
Gutted cats for sound and power. I can't see a reason to go and spend ~$2k on "off road" down pipes that aren't true Downpipes removing the turbo bridge pipe. That being said. VA does a visual inspection. So I chose to get then instead of cut it and weld in a new pipe. Atleast it looks stock :-) And that video has me considering doing the Turboback pipes. Have a guy who makes solid engine mounts locally and was thinking of doing them when those go in too
Old Jun 19, 2018 | 11:58 AM
Amg63-'s Avatar
CLS63 AMG
I know running catless downpipes definitely adds more power over stock, but muffler delete,is that just for sound or does it also add any power?
Old Jun 19, 2018 | 12:01 PM
Amg63-'s Avatar
CLS63 AMG
But is it worth it? How much difference are we looking at between turboback downpipes and just going with catless downpipes?
Old Jun 19, 2018 | 02:08 PM
2015 CLS63 S AMG
According to weistec they got some 680whp with Turbobacks. And personally I don't think their tuning is the best. I think other shops could get more power from that setup. Especially dyno tuned. And I feel, if I'm going to pay to put in the engine mounts, I might as well do the Turboback while in there.
Old Jun 19, 2018 | 09:16 PM
Ed99's Avatar
E63s AMG
Muffler delete might get you a few extra hp. But people do it for the sound to get more pops and V8 gurgles.
Old May 15, 2022 | 02:40 AM
PhuongNguyen's Avatar
2013 E550 coupe
Smell
How’s the smell with gutted cats and had anyone gutted their cats AFTER getting a tune? Was it a noticeable gain ?
Old May 16, 2022 | 12:34 AM
Mr. CVE's Avatar
MY06 E55
Not quite the answer to your question, but I did the dump pipes and front cat delete AFTER the tune and it was a massive difference.
my tune was done on the full factory exhaust and that took my rwd only car down to 11.4 from 11.9. cant get traction to re run it now. ( don't want to buy drag tires, supposed to be a daily ! ) plus I have a drag only car.
Old May 16, 2022 | 12:52 AM
2013 E550 coupe
Nice
That answers it. So basically you got turboback down pipes i’m guessing. How is the smell?
Old May 17, 2022 | 11:36 AM
Cifdig's Avatar
Top Answer: 1
2007 e350 sport. 2010 350 4matic sport. Worlds first W212 E63R self built.
the entire system is under sized. You can squeeze 800-900 hp out of it of course. But it’s struggling . You will gain hp by even just gutting the cats. But if you were to get a 3” catless dp and do 3” from mid Exhuast to 3” straight through mufflers, you will gain a good amount of power. Drop quarter time raise
mph and lower back pressure, and you should see a drop in waste gate duty cycle making the turbos more efficient. Then at some point if the motor is down do a bridge pipe.
Old May 17, 2022 | 11:43 AM
2013 E550 coupe
Exhaust
i would most definitely do all that and more if I had an e63. But it’s just a 2013 e550. And I don’t wanna put too much money into it. Gutting the cats, removing rear mufflers and rear resonator, adding an x pipe, and using stock 2.5” pipes should suffice for me. I’ve done all this already besides gutting the cats.
Old May 17, 2022 | 02:00 PM
PekkaH's Avatar
2015 CLS550 Shooting brake 4-matic
Hi. Like Cifdig said you should consider bigger exhaust. Maybe only downpipes if it fits better to budget. M278 exhaust size is only 60mm (2,36") not even 2,5". You can make M278 also run pretty nice and fast.
Look this exhaust thread https://mbworld.org/forums/cls-coupe...-diameter.html
