Safest way to remove my ecu?
2015 E63s AMG, 2020 GLC 43 AMG
Peter,
It's a piece of cake. If it takes you longer than 3 minutes you must very mechanically DECLINED! LOL
Just make sure your ignition is not on and you are fine. If you are only removing it to see the label underneath (to get a 2nd ecu ordered) you don't need to even disconnect it. I thought you were doing dyno tune in person. So if you are they should be doing this. If you do need to remove it entirely though there are 2 cam sliders on the 2 connectors. Just slide them each about 3/4 of an inch and the connectors come off easily.
I have done this a few times now without any issue. Really nothing to worry about. Fairly bullet proof.
Cheers
Cheers
2014 E63S; AMS 100 octane ecu tune; edok tcu tune; BB intakes; dyno tuned
Peter,
Cheers
Cheers
good advice vrod!
MY17 S63AMG - MBUSA Buyback. MY16 SL63 - Sold MY19 W213 E63s. 2020 W213 E63s Wagon
Did you get your tune and if so, how do you like it. Got a extra ECU for the M157 for sale if your still looking for one.
Peter,
Make sure you check with AMS the serial number of the ecu being offered. I was told that they are not all the same. Some may not be compatible with your existing one for cloning. This is why I had to send them a pic of my label before they sourced it for me. You would think they would all be the same, but they insist no, they are not.
Just trying to help brother.
Good Luck.
Good Luck.
Peter,
Good Luck.
Good Luck.
Oh and ams said I don't have to take the negative terminal off the battery during ecu removal
got a great ecu off eBay from a donor 2015 gl550
time for a tune
time for a tune
