60 -120 MPH Times
Old Aug 15, 2018 | 06:13 PM
727E63AMG's Avatar
2014 E63 S, 2017 GLE 43, 2020 Cadilac Escalade, 2019 Lamborghini Performante
60 -120 MPH Times
Was wondering what 60-120mph times everybody is getting?
Please list ur modfications
I did 60-120 mph in 6.69 seconds at 4250 FT altitude DA adjusted
Pure Turbos, catless DPs ,UDP intake spacers, mid pipes, resonator delete
Old Aug 16, 2018 | 07:54 AM
efiftyfizzle's Avatar
W212 E63 AMG S Model
the conventional speed range for testing top end is 60-130. Can you give that a try?
Old Aug 16, 2018 | 02:30 PM
PeterUbers's Avatar
A strong tune only will yield a 7.0 seconds or better on this platform, 60-130mph
Old Aug 16, 2018 | 06:02 PM
i don’t know about that... if he’s doing 6.69 with upgraded turbos, that’s going to be in the low to mid 7s with another 10mph to go.
Old Aug 16, 2018 | 07:23 PM
727E63AMG's Avatar
My Buddy in his stock Hellcat run 7.03 just 10 min later same stretch same temperarure same device and DA
you guys think it ran slower do to the 4250ft altitude DA adjusted?
Old Aug 16, 2018 | 09:01 PM
TMC M5's Avatar
'14 E63S & '14 Audi SQ5
In very cold, negative DA conditions I did 6.34s 60-120mph, 6.85s 100-200kmh, and 8.11s 60-130 mph (all same run). That was with EC stage 2 tune, Speedriven catted downpipes and UPD spacers and filters.
Old Aug 17, 2018 | 12:42 AM
PeterUbers's Avatar
maybe I'm thinking 8 seconds
Old Aug 17, 2018 | 01:31 AM
PeterUbers's Avatar
https://mbworld.org/forums/w212-amg/...-60-130-a.html
Old Aug 17, 2018 | 10:23 AM
TMC M5's Avatar
The Alpha 9 had upgraded turbos. The best tune only M157 E63 I have seen was in the high 7s but was a pre-2014 RWD model. The gearing on these cars and powerband are less than ideal for 60-130mph runs compared to other cars in the segment.
Old Aug 17, 2018 | 11:28 AM
kponti's Avatar
E63
Yes, that Alpha turbo car also ran a 10.7@135mph so OP is in good company.
Also check out previous statement
Great time! For some perspective my full bolt-on E85 tuned GT-R ran a best 6.67s 60-130mph ....
Old Aug 17, 2018 | 12:52 PM
PeterUbers's Avatar
exactly - so it seems the op is doing pretty good since he has upgraded turbos too
Old Aug 17, 2018 | 07:11 PM
TMC M5's Avatar
I am not sure that is the correct assessment. The OP posted 6.69s 60-120 mph... the Alpha 9 posted 6.58s 60-130mph. It is hard to gauge how much time is lost to the bad DA.
Old Aug 17, 2018 | 08:15 PM
PeterUbers's Avatar
good point
Old Aug 18, 2018 | 09:02 AM
good point
those last 10mph can take a while...
Old Aug 18, 2018 | 11:16 AM
PeterUbers's Avatar
in that case... I "thank" we have a problem ....
Old Aug 24, 2018 | 02:04 AM
e65's Avatar
e65
2014 E63 S model
If you want to get the best time 60-120 time, better to start at 45 or 50 miles per hour in 3rd gear and then give Full Throttle. You boost lost and shifting time during the 2nd to 3rd shift that occurs at 60 miles per hour. This would also apply to be 60-130 time. For that you also want to make sure you hold 4th gear until 131 miles per hour. If 4th - 5th shift occurs at 128 miles, that will hurt your 60-130.
