Dyno tuned my 2014 E63S by AMS today
https://www.genuinemercedesparts.com...der-0009932160
Great find! When I went there, it looks like one length though. The front mounts are not the same height as the rear ones. Also one has the hex feature for a wrench and one does not. I know this from working between my ECU’s quite a bit. If you can supply the part numbers for both front and rear mounts\risers you will be DA MAN!
also, everybody keep in mind that these ECU’s are often the same piece of hardware used in multiple models. This means that these mounts/standoffs/risers might be different from one ECU to the next. You will most likely need the risers from at least a v8 e-class, CLS, or s-class.
Hey Buddy,
https://www.genuinemercedesparts.com...der-0009930860
I haven't had any hiccups in the two years I've had it tuned. I've put on a little over 15k with the tune like this. The bigger cooler just ensures that she runs cool no matter how hard I drive her, it doesn't really improve your #'s. The only problem I ever had was when I romped on the car too hard with less than a 1/4 tank of fuel. She gulped some air, faulted out and then the fault wouldn't clear. Took it to the dealership to clear and all has been good.
https://www.amsperformance.com/produ...-cooling.html/
Ringking - great feedback, much appreciated! Did you buy the AMS upgraded primary or auxiliary heat exchanger, or go with one of these entire cooler systems? They!
I am tempted to put downpipes on, have them tune it or maybe even do a turbo upgrade but I know that the return on investment will be NOTHING like the change of going to stock to a tuned ecu so I'm hesitant based off their pricing. That's a lot of dough I could do something else with.
Seems like its essential to get Max Performance grade tires like the Michelin PSS or Nitto's if you're tuned. Otherwise even with 4matic you will experience quite a bit of wheel spin even with good All seasons like the DWS06 or MIchelin PSS A/S 3 tires when driving in dry/warm conditions. i know you garage your car in winter, which I do as well...but trying to figure out how long i might be able to drive on PSS if we get a warm November and it stays dry with temps in the 40+ range or do i just garage it and deal with driving my c240 4matic for 4 months
From a roll with the ams tune I don't lose traction ever.
my suspicion is that summer tires on the track would net you the best 1/4 mile compared to the Conti dws, but for my daily driving it's probably not the most important thing to accomplish this season ...
i think Vrod has summers on his and with his ams tune he described that his four tires spun.
im gonna try all traction off from a dig and see what happens
I don't completely understand what the need was. Why do you need to swap anything? If you have 2 ECU's with the same standoffs already on them why do you need to ever unscrew them?
I'll probably just keep my current PZeros (although i hate them) through the fall until i put the car away for winter, then will probably buy 4 new Pilot Super Sports in spring since those sound like great tires to put this power down.
If you breakdown on the side of the road somewhere you will want to swap out those ECU's before it gets towed to the dealer. And when you are in an OH SH*T stressed moment, do you really want to be standing there on the side of the road/freeway swapping these simple little bits? I would get the second set my man. Cheap enough and no urgency.
