Turbo coolant pipes bite the dust
Old Jun 7, 2022 | 10:37 PM
  #51
dustinN's Avatar
09E350, 07E63, 13CLS63
Originally Posted by Typer599
Sorry to revive this thread from the dead but what are these 3 coolant pipes called? Know the part numbers for them?
I have a 2012 S550 with 125k miles and GREEN circled hose is leaking. I figured I should replace them all.
I read here to replace the water pump as well since I'll be getting this thing replaced. Is it necessary to also replace the thermostat too then?
Thank you!
They are turbo coolant lines. See the attached part info on M157. Did you replace those lines? I am in the middle of removing the oil filter housing and the green and orange lines are on the way and block access to a crew behind those. I already removed the 2 bolts which hold the lines but they are not flex enough to put away so I can reach the oil filter housing screw. How did you remove those lines?
File Type: pdf
Old Jun 17, 2022 | 11:07 PM
  #52
Dakintosh's Avatar
13 S550 4MATIC, 14 S63
Hey my M157 just began leaking from the green one too... actually more like pissing lol! Glad it decided to go sitting in the driveway when I turned it on rather than at work or something. Started pulling stuff off tonight. Should be fun
Old Jun 17, 2022 | 11:20 PM
  #53
Typer599's Avatar
S550
sorry Dustin, wish I could help. I had a local shop do it 😢
Old Aug 31, 2022 | 07:53 PM
  #54
S. Madman's Avatar
2012 E550 sedan 2019 E63 Wagon
How much they charged you. Local to me wanted 5k.
Old Aug 31, 2022 | 08:12 PM
  #55
Typer599's Avatar
S550
Labor was $300. I had to find the parts myself. So all in all under $500.
the shop I go to is here in Garden Grove, CA.
it’s not a MB specialist shop
Old Aug 31, 2022 | 08:36 PM
  #56
Laethageal's Avatar
2013 E550 - AMP+MPP packages
When I had 1 of the line done 4 years ago, the local shop charged me about 1200 CAD (roughly 950$usd). The turbo coolant hose snapped while doing basic work and part of the taper plastic stayed stuck inside the engine. I didn't get the other done at that time since I thought it was pretty high cost for the work.
Few months later as I changed the belt, I barely touched the other line and it cracked. Decided to do it myself. It was, honestly, a damn pain to do for some diy without deep knowledge of MB mecanic. Getting to remove everything you need to access it is laborious. I recall having a hard time unscrewing/tightening back the clamp on the turbo intake, passenger side. Had to cut a (8mm?) socket shorter for it to get in place, and couldn't use a ratchet on it because even my smallest 1/4 drive was too large to fit. Ended up using visegrip to lower the socket in that small space, fit it in and then do 1/30th of a turn, unlock the visegrip, move them, lock them back, turn 1/30th of a turn, etc. Felt like an eternity and surely took 3hr only for that part 🤣🤣🤣
Overall, if memory doesn't play tricks on me, it took me almost 2 full days! I did change the turbo oil intercooler as it was leaking as well (think that's the name of the part recessed im the motor, under the thermostat).
Not a job I'd recommend unless you got patience and some knowledge. It was over my skills/tools and barely got it done, even with MB azra.
Old Aug 31, 2022 | 09:01 PM
  #57
dustinN's Avatar
It's difficult but doable. Be patient, it's time consuming. If you have an alternative drive, it will give you more time to get it done. 5k for this job is way too much. I'm not techie at all but I managed to get the job done myself. Ask this forum if you need help. That's what I did.
Old Aug 31, 2022 | 11:37 PM
  #58
AMGfifty5's Avatar
05 C55-gone 06 E55-gone 15 P85D 14 E63 S 11 Sonata 😅
Quote from local MB dealer, I ended up going to a local shop for less. Fremont CA
Old Sep 1, 2022 | 08:03 PM
  #59
S. Madman's Avatar
If the quote was 2.5k I would get it done, but 5k?
Techs here in n.FL think they live in Dubai.
Old Sep 2, 2022 | 04:23 AM
  #60
lampeater's Avatar
'14 E63S, '00 E430, '07 C230
I just recently had mine done at the beginning of August, right as the car hit 80k miles the hose started leaking profusely so I took it in.
During my PPI last year, they noticed that there was dried coolant around one of the lines and warned me about it, since it wasn't actively leaking, I just kept an eye on it and it held up for an additional 10k miles.
I had my work done at the dealership here in Vegas and was only charged $1700 with labor for all the lines to be replaced.
Earlier this year, I had my rear heater hose done for roughly $500 by a local Mercedes specialist.
Old Sep 2, 2022 | 07:49 AM
  #61
BlownV8's Avatar
E55, GLS450, GL63, GLE350
Really wish there was a vendor who made these parts from a non biodegradable material.
Old Sep 2, 2022 | 03:27 PM
  #62
AMGfifty5's Avatar
I got all 3 on screenshot plus new belt for $4k. Still hurt to pay that amount
Old Sep 4, 2022 | 12:25 PM
  #63
mweber88's Avatar
2015 E63s S212
In the attached PDF, there are lots of substitution part numbers for these. Are there any data about the substitution part numbers as to when they were implemented and if they help prevent the problems associated with these coolant pipes in later model years? I have a 2015 E63s and wondering if they, too, are plagued with the same problem.
Old Sep 12, 2022 | 09:44 PM
  #64
SebastianM157's Avatar
R231 / C207/ x166/ W213
Hey,
Working on the driver side coolant lines, shallow 8 mm ujoint socket or a shallow joint e10 ujoint socket will loosen all the little hard to get fasteners, At the turbo you need ot apply some force, they are simply not going to pop out easy. Large pry bar did the top one , lower one needed something kind of wedged behind it (screw driver) and the aforementioned prybar. I was fixing a cam magnet sensor and the oil filter housing needed to come off, this is when these fittings broke. clearly not design to last but car is 10 years old and has113 k (C207). Tomorrow i will be "threading" the new lines in ,should be exciting. If these were steel or aluminum they would probably be lifetime items with an occasional oring change.
Any one has a good suggestion for the threading of the new lines? it is supertight!
Old Sep 13, 2022 | 08:03 AM
  #65
dustinN's Avatar
Originally Posted by SebastianM157
Hey,
Sounds like you got everything out smoothly. Lots of us had the turbo lines broken while replacing the magnet sensors. It's a nightmare for me but felt really good after it's done. Take pictures so you can remember where things are, some little thing you may forget. To insert the turbo lines, do it from the front, below all other line, you will need the prybar to enforce the 2 lines into the turbo. Good luck.
Old Sep 13, 2022 | 10:07 AM
  #66
thanks. This is the angle of attack i have planned. Thanks for
the pry bar tip. I would not call the removal smooth lol
Old Aug 10, 2023 | 02:56 PM
  #67
skonker's Avatar
2014 E63S
I'm tackling this issue on a 2014 E63 S 4matic - anybody have part numbers for these three coolant lines? Seems to be a lot of versions out there.
