Boost lost
Old Dec 9, 2018 | 03:36 AM
Dman63's Avatar
CLS63
Boost lost
Hi all. New here. So i am having am issue with my CLS63.
i picked it up recently p30 pqckage. Bone stock. It made 475whp on conservativr dyno dynamics. Boost would peak at 11-12 and tapper off to 8psi. The performsnce was there. Ran 100-200kmh in 8.1-8.2 consistsntly.
then we loaded a tune. Peak boost went up to 20psi but would tapper off to about 12psi. The performance gain was big. Dropped 100-200 to 7.1 with a lot of spin and a passenger. At 2% incline.
the car did 7-8 strong pulls the boost just disapeared it starts of at 18psi and then drops to 3psi til the end of 4th- 5th gear.
star shows absolutely no codes. I ve chs ged the solenoid and vacuum pump. Made zero dofference. I ve also smoke tested the system found no leaks. I ve flashed the ecu back to stock file.made no difference. At this point i dont know what else to do.
any help will be hugely appreciated.
Old Dec 9, 2018 | 10:57 AM
Utopia Texas's Avatar
2019 SL550/2023 EQS 580 SUV
“then we loaded a tune.”
Contact the company you bought the tune from in the first place. If they are legitimate they will help you out.
Old Dec 9, 2018 | 11:27 AM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
What are your IAT's? Sounds like the car is getting heat soaked.
Old Dec 9, 2018 | 12:46 PM
PeterUbers's Avatar
Reset your ecu and tcu
the engine is pulling timing perhaps, do you get better performance on the first pull?
Old Dec 9, 2018 | 04:50 PM
kponti's Avatar
E63
Timing will not account for measurable boost loss. Your car is going into some form of limp mode and eliminating boost. I would look into your boost solenoid and the vacuum hoses attached to it going to the turbos
those hoses get brittle and won't stay on especially with a tune
Old Dec 9, 2018 | 04:52 PM
PeterUbers's Avatar
im always curious ... limp mode without CEL? Or code?
Old Dec 9, 2018 | 05:32 PM
Dman63's Avatar
CLS63
So i did the ecu / tcu reset. When u hold the gas for 15 secs etc etc. It worked. Car made 19psi peak and dropped.down only to 14psi.
iats are fine. Timing is fine. I ve chsnged the solenoid and checked the vscuum hoses.
it drove fine for a bit then i went to check 100-200 and wasnt abale to..boost dropped again..and i wasnt able to reset anymore....
well at least i know now its electronic. I didnt like 3td to 4th shift when we first loaded the tune, when car ran fine, so i m thinking to chsnged trans fluid which i was planning anyway.... i leaning toqards ecu protecting transmission...
Old Dec 9, 2018 | 07:53 PM
PeterUbers's Avatar
how many miles did you drive after tcu reset? It is mentioned often that it takes 100 miles to adapt the trans and obviously other parameters are being adjusted too to adapt to your driving patterns
i think that if you're in s+ mode it should discard any tcu adaptations and let your drive it fiercely
Ah I see what you're saying; when you change the solenoids and hoses the battery was most likely disconnected and therefore you reset the tcu by definition. That's why it drove fine for a while
imagine how many guys are taking m157's to the track without resetting tcu and having less than stellar 1/4 mile and trap times....with and without tunes
Old Dec 9, 2018 | 10:37 PM
kponti's Avatar
E63
Mine usually did not throw a code for a while. When it was stock, it threw a low boost code immediately. When I had a tune, it was not all the time
Old Jan 14, 2019 | 04:51 AM
cocobeex's Avatar
2014 E550 4MATIC TUNED - Turbo Upgraded Stage 3
Mine too. No CEL.
But i can hear the exhaust sound change. Then, i scan code. It shows "Pending code P0299"
Usually, it happens when i drive aggressively. 50% chance it comes up.
Old Jan 14, 2019 | 11:20 AM
Dman63's Avatar
CLS63
So finally we figured it out!!! Man this took long. And pissed me off a bunch.... in the end it was the 2 sensors at the filters. Removed the sensors from the airboxs and just placed them in the bay. Car ran good for a few runs. Then went back to low boost scenario.
placed the sensors back in their places bit ditched the filter. Car ran like crazy. No issues at all. Other than the feeling that something might fly in the turbos without filters.
placed the filters back but unplugged the sensors. Car runs great. No issues since.
I didnt get a chance to change the sensors. See if they had gone bad.... because the original filters thst the issue came upon were KN in decent shape.
Waiting for new BMC fikters to arrive. See how they do. I ll chsnge out the sensors in the meanwhile.although i m thingking to just tune out those sensors. They are there just to tell u when filters are dirty. And the fsct thst the car goes fine with them unplugged, i ll just tune em out....
car runs sick now. 100-200 came down to 6.8s with a passenger from 8.2s. In nearly identical condotions.
Old Jan 14, 2019 | 12:34 PM
amgboy916's Avatar
2012 CLS 63
sorry if i'm not understanding. but What sensors are you referring to? and are you saying the filters were to blame? were they clogged? did you have better results with oem filters?
Old Jan 14, 2019 | 12:52 PM
timm206's Avatar
C63 W204 / E63S W212 / E63S W212
Mass Airflow sensors.
Old Jan 14, 2019 | 01:01 PM
amgboy916's Avatar
2012 CLS 63
ahh i see. he could be onto something beneficial. waiting to see if changing them helps. or removing them entirely? are there any risks of me having my tuner tune them out completely? I have aftermarket filters as well
Old Jan 14, 2019 | 01:02 PM
amgboy916's Avatar
2012 CLS 63
it seems like the filters is fouling the sensors. ive read somewhere this could happen on oiled filters? not sure if yours are oiled. not sure if mine are either. I have the green performance filters
Old Jan 16, 2019 | 05:05 PM
cocobeex's Avatar
so, you are running it without MAP sensors !?!?
I thought that would throw AFR off the chart.
Old Apr 18, 2019 | 01:38 AM
pchiu408's Avatar
2016 AMG GTS
@amgboy916 what ever happened with you test with new sensors and filters?
Old Jun 17, 2019 | 10:56 AM
Siegmann's Avatar
10-second E550
Bump... hoping for an update from OP
@Dman63
Old Jun 19, 2021 | 10:11 PM
CerBErusM113's Avatar
2015 CLS63 S AMG
I have had this same issue. Boost will be crazy and then drop and feel as though it's an N/A motor. I tried cleaning the MAP sensors and boost has stayed consistent and felt as though the car should. Prior even under boost it felt sluggish and didn't have power off the line.
