E63 AMG 2014 ECO mode deactivated after one stop/start
when this happened to me I had a bad crank position sensor code and they replaced it and I never had an issue after, this was when I had about 600 miles on the car ...
about 14 variables have to be the right number before eco shuts the engine down but it should never deactivate itself to the point where the button light goes off
it is abnormal for it to disable itself like that -- meaning the green dot on the eco button doesn't light up
How much fuel does "shutting off the engine at a traffic light for 45 secs actually save anyone? I feel it's more of a drain on your battery more than anything...Merry Xmas, all!
You are absolutely correct. However, starting the car and hitting that green button has become a habit. Not having to do that anymore makes you wonder why, and whats causing it.
BTW - there is significant additional wear on the engine doing the start-stop thing, and many (including me) don't like it at all. And as discussed above - doesn't deliver any real world fuel savings. I have disabled it - or rather - have it disabled by default and I can turn it on as needed.
Liking it or not, a simple push of the button disables it. For myself personally, I like it on long, traffic stops.
Not to mention extra wear and tear on your starter!
Done to me at last visit when there was other warranty work being done.
i personally find the ECO function useless living in downtown Chicago where i'm in stop and go all the time and any stop light is maybe 30 seconds of waiting. ECO was not a reason I bought the E63
but if your battery is bad and you are under factory warranty then get MB to give you a new one regardless if you use ECO going forward or not !
