Race start
Old Jan 19, 2019 | 07:01 AM
E63sMonster's Avatar
2014 e63s 2009 ML350 4Matic
Race start
anyone know how to use it properly. Whenever I try to race start it goes in race start mode rpm locks at 4K but only for like 2/3 seconds then cuts off. Is this normal or m I missing something
Old Jan 19, 2019 | 07:42 AM
danclements's Avatar
2012 E63 AMG Estate
That's normal. Drop the brake and you'll launch.
Old Jan 19, 2019 | 01:02 PM
but m only getting 2/3 seconds. Like if I am at a red light I wana get ready to race n wana use race start it won’t work cause I can’t tell when light will go green.
Old Jan 19, 2019 | 01:38 PM
timm206's Avatar
C63 W204 / E63S W212 / E63S W212
Mine holds the rpms for about 3-4secs, its a 2016 S with a recent transmission software update. Im guessing its a safety feature so you cant abuse the clutch pack.
Old Jan 19, 2019 | 01:55 PM
got u thought something was wrong with mine. Must b a safety feature. Thanks
Old Jan 19, 2019 | 04:30 PM
PeterUbers's Avatar
yeah it's not great for the street ... you can try low rpms until you're ready to go and then floor the accelerator ... you may get more time before your timeout
Old Jan 19, 2019 | 04:56 PM
brutus_tx's Avatar
2014 AMG E63S and 2020 AMG GTC
Use the correct sequence to enter RS mode... start by holding your foot on the brake and following your normal RS start sequence, but don't touch the gas! The car will stay in this mode happily.
Once you're ready to launch, only then should you mash the gas. You will have approximately three seconds to release the brake. Any more and it will time out and cancel RS.
Try it next time at the lights.
Old Jan 19, 2019 | 04:59 PM
brutus_tx's Avatar
Timur, can you speak to this transmission software update? Was it a factory update or aftermarket? Was this strictly for 2016 or do you know if it may be available for 2014 E63S?
Old Jan 19, 2019 | 07:17 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
Practice, practice and practice some more.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Jan 19, 2019 | 11:45 PM
timm206's Avatar
Yes a factory update from MB dealer. That exact update is compatible with w212 E63 2014-2016 for sure, not sure with pre-facelift. The car shifts better overall, more responsive but i must note that the adaptations were fully reset as well via Xentry at the same time so that plays a role too. Build date of the car is 10/15. One more thing i noticed after the update was the delay being shorter when shifting from R to D and vice versa, prior to the update there was a much more noticeable delay and i doubt the adaptations reset have anything to do with that.
Old Jan 20, 2019 | 11:20 AM
jvakos's Avatar
E63 SL55 996TT C5Z06
Timur - did you ask your dealer to reset your trans adaptations and in doing that, the dealer also applied the software update? did they do that under warranty?
I've asked my dealer about this a few times (Mercedes of Chicago) and they keep telling me everything is normal with my transmission and there is no software updates to apply my car is a 2015 E63S. I've heard several here got this trans sofware update and were pleased with the improvements.... maybe time to try this with another dealer.
Old Jan 20, 2019 | 11:45 AM
TRIAgain's Avatar
2016 E63s CCB
https://mbworld.org/forums/w212-amg/...ion-start.html
a thread on the transmission update and the campaign number
Old Jan 20, 2019 | 01:13 PM
Lumi's Avatar
E63 AMG S
I believe this might for cartain 2016's only?
Old Jan 20, 2019 | 03:45 PM
timm206's Avatar
https://mbworld.org/forums/w212-amg/...dy-issues.html
I was having some shifting issues, that was the reason for my visit to the dealer but before handing over the car i asked them if they could also check for ECU/TCU and Command System updates. The dealer said no problem and about after an hour it was all ready, quote “There was a TCU update available for this platform.”
Yes it was all under the factory warranty.
Old Jan 21, 2019 | 11:36 AM
Vrodman's Avatar
2015 E63s AMG, 2020 GLC 43 AMG
FWIW, I believe you will get the same result from your launch with simply turning off traction control all the way and doing a break boost up to the 3,000 rpm or so that it will let you while in S+. This was how I got my fastest 0-60 (3.1). It might take a little practice but it's not that hard and it's way less of a pain in the *ss than RS!
Old Jan 21, 2019 | 03:28 PM
haha thanks can’t wait to try it
Old Jan 21, 2019 | 03:30 PM
holy moly stock 3.1 man I guess I got long ways to go. I’ll keep practicing.
Old Jan 21, 2019 | 05:03 PM
Savage212's Avatar
2014 E63 AMG wagon
Pretty sure he's tuned. I also got a 3.1~ with the same method. (tuned)
Old Jan 21, 2019 | 06:39 PM
Vrodman's Avatar
He may or may not be tuned! He probably would know for sure if he wasn't still under extended warranty.
Old Jan 21, 2019 | 09:09 PM
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
The device making the measurement also makes a difference...
Old Jan 22, 2019 | 08:08 AM
Savage212's Avatar
2014 E63 AMG wagon
I'd agree, all timing devices present a margin of error. It would appear low 3's is normal for tuned E63's regardless of the device. I do think many would agree that GPS based units are among the more accurate with some being better than others. Additionally, the same device with the same car, location and similar environmental conditions should be accepted as a good measure for change in performance regardless of the reported times.
Old Jan 22, 2019 | 09:41 AM
PeterUbers's Avatar
When I first got my 63 I had the Liberty mutual safe driver module that measures various patterns of your driving via the obd2 and uses that as a means of offering you a discount on premiums ...
i pulled up that app online at Liberty and after a series of 0-60's and the best I got was 4.0 seconds 0-63mph or something like that (stock format with 1200 miles on the odo)
needless to say I didn't get much of a discount.
Old Jan 22, 2019 | 11:10 AM
Vrodman's Avatar
This is spot on with my thinking. I don't so much care about the absolute numbers as I do the relative change. best time I could ever get 0-60 with the Vbox was 3.5 for the car entirely stock. Now if , say, I had an AMS tune, I might have seen 3.1 using the same metrology (the Vbox). So because both runs were performed at the same location and general conditions, I can safely conclude that the tune (if I had one) was a 0.4 second improvement. Not subtle! lol
Old Jan 22, 2019 | 10:58 PM
jvakos's Avatar
i have that phone app called DashCommand and my best 0-60 time time i ever hit was 3.5 seconds on a stock e63s. that was on a perfectly clean high way road in mid summer. i have never seen better than 3.7 seconds on chicago downtown streets and i assume thats because of all the crap on the streets that dont allow the ****ty pirelli pZEROs to hook. seems 3.1 or 3.2 on a tuned AMS is very realistic
