Lightest wheel for 14' E63s
Old Jan 28, 2019 | 10:38 PM
gashby's Avatar
2019 E63s
What is the lightest wheel that you can put on a e63s. Does it come to a point on a Vehicle this heavy were that weight wont make that large of a difference?
Old Jan 28, 2019 | 11:53 PM
bucktown's Avatar
2016 e63s amg
https://www.machinedes********/sprin...nsprung-weight
Saving wheel weight, as with any unsprung mass, will be one of the best overall performance improvements you can make on a vehicle, and a higher ratio of sprung to unsprung weight is ideal.
The diminishing returns will kick in when you start to decrease strength to the point of failure, as well as cost, especially on a passenger vehicle.
I don't have any direct suggestions on specific wheels, but you're on the right track.
Old Jan 29, 2019 | 01:03 AM
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
I don’t know a specific answer but based on my experience I’d imagine you could spec out a quality 19” wheel pretty close to 20lbs.
Old Jan 29, 2019 | 03:56 PM
e65's Avatar
e65
2014 E63 S model
advanti hybris 19". avail on tire rack. ~19lbs each. They bend easy if u hit a bump. Lightest affordable wheel option.
Old Jan 29, 2019 | 06:42 PM
PeterUbers's Avatar
I would rather tune my car more aggressively than compromise on lighter wheels on this heavy e63
Old Jan 30, 2019 | 03:00 PM
gashby's Avatar
2019 E63s
I currently have 19" Brabus Monoblocks on my car, an they seem to be made with a lot of material, so I am assuming switching down to a forged wheel from any company would save weight. As you said above @PeterUbers the car is tuned right now with 712hp/ 850lbs torque, before turbo or meth. I dont know which of those routes is next, but upgrading to racing brakes with stainless lines was a night and day difference eliminating the extra weight at each wheel. I love the design of the BBS RI-D, but those are only in 20's and not available for our car.
Old Jan 30, 2019 | 03:21 PM
PeterUbers's Avatar
get the lightest forged rims you can afford or the lightest oem rims that are appealing to you
Just don't want you to compromise safety but your head is in the right place
Old Jan 30, 2019 | 04:42 PM
try m3's Avatar
Top Answer: 1
M3, E55, cls63
Advans or volks are a good option but might be hard to find in our bolt pattern. I ran Volk te37's on all my track/street builds super strong and light.
Old Feb 2, 2019 | 09:28 PM
gashby's Avatar
2019 E63s
I was looking for something along the lines of very thin spokes, or massive open spaces. the less material the better is the look I am going for.
These are the current wheels.
Old Feb 3, 2019 | 02:31 PM
Staff@WORLD's Avatar
Former Vendor of MBWorld
2012 Mercedes SLS, 2014 Mercedes SLS Black Series, 2014 E63S, 2013 S550, 2012 ML63, 2013 C250
A set of Titanium wheel bolts will save you a pound across all 4 wheels. The cost for a set of 20 bolts is $275.00 and that's an easy low cost way to save unsprung weight.
Give me a call if you would like a set.
Old Dec 20, 2022 | 12:45 AM
theMover's Avatar
2014 E63S
Cool The rods are weak on the M157’s
I’d not tune it. The M157’s have weak rods and bearings. Anything over 680 crank hp/600 hp wheel, and you’re playing Russian roulette. I’d do wheels, lighter brake rotors, no rear seats, light battery, non run flat tires are 25% lighter and last 35% longer and grip better, Carbon hood, trunk, lexan windows, run with 7-9 gallons of fuel instead of 19-20 gal > 6 lbs per gallon, etc. also, technically the CLS w218 models are lighter because there’s no dual pano roof and they are “slightly”more aerodynamic. They’re estimated at 50-75 lbs lighter than the E w212. Ironically the newer post 2018/19 models with the smaller 4.0 V8 are heavier. How is that?? Lots more “dumb distract driver” aids that adds weight. The AMG S53GT and r sedan are 4800+ lbs with the V6 six. Sadly it’s a Mercedes, so rod and piston kits for it are 2-5x more expensive than for any domestic high performance car like a corvette, because folks feel they can charge you for the marquis/brand. Same parts but triple the price. So do lots of regular maintenance and other mods but avoid the aftermarket tunes. Especially if your over 35k miles on the odo. I inherited this car but have had other relatives and friends own them. Mine was maintained to a decent degree but I see hints of oil residue under the passenger side cam sensors and a leaky front axle. I don’t have 8k laying around to get these few things looked at and resolved. Others tell me if I am a reasonably ok wrench, I can do a lot my self, and I am. I can do brakes, hoses, plugs, etc. sure I’d love to have 700-800 crank hp and keep up with my neighbor in his 2015 Huracan but I don’t want to worry about a engine well out of mechanical warranty, unless is a company that will write paper on these. I over did it in this post but I just don’t want lots of unhappy miles later. Or sell the car. It is enjoyable though, I must admit. The thrust is like a 757 full throttle to fire wall on a cool day and light load, it just builds exponentially 😁👍. I am in Phx, Az too. I’d love a good rep shop vs the stealership’s. Even a parts Mgr suggested staying away from the dlrs. That’s is for now. Happy Holidays.
Old Dec 20, 2022 | 12:49 AM
theMover's Avatar
2014 E63S
Ha, when the engine blows, the $$$ will be a much bigger concern than the wheels.
Old Dec 20, 2022 | 12:53 AM
PeterUbers's Avatar
Ok
Old Dec 20, 2022 | 08:09 AM
FastWgn's Avatar
2016 E63 Wagon
HRE has a some nice ones in the flow category (much more reasonably priced than the core lineup) and they are in the 21-22 lbs range, so a solid 10 lbs lighter than stock, per wheel.
Old Dec 20, 2022 | 09:59 AM
AMGfifty5's Avatar
05 C55-gone 06 E55-gone 15 P85D 14 E63 S 11 Sonata 😅
Has anyone done any real tests to see how much gains if any a lighter wheel in the 1/4?
Old Dec 20, 2022 | 10:01 AM
thesaintusa's Avatar
2019 911 GTS / 2016 X3 / 2015 E63s / 1993 RX-7
100% consider Volks!
TE37 Have them for my RX-7 and love them.
There are pictures of TE37s on a white E63 wagon on this forum Looks fantastic.
And yes you will notice a lighter wheel set up.
Old Dec 20, 2022 | 11:46 AM
cotmfk's Avatar
On the shoulder
I’d not tune it. The M157’s have weak rods and bearings. Anything over 680 crank hp/600 hp wheel, and you’re playing Russian roulette. Happy Holidays.
Care to provide any support to those claims? Plenty of people running tunes with good power and near or more than 100k miles...
Old Dec 20, 2022 | 11:49 AM
cotmfk's Avatar
On the shoulder
I'd be interested in seeing that analysis.
As far as light-weight wheels, money is the factor - there are plenty of light weight aftermarket wheels, but the lightest ones are typically $10k+ per set. If you have the standard OEM 212 wheels, they are 27 pounds. So it is relatively easy to find lighter aftermarkets. If you have the stock forged wheels it's a bit tougher.
Old Dec 20, 2022 | 03:13 PM
ThreeSix's Avatar
G550
Im running 19x10 squared Volk ZE40's. The wheels are forged and weigh approximately 19lbs in this size.
Old Dec 20, 2022 | 05:07 PM
PeterUbers's Avatar
A decent article with actual data
https://medium.com/@almirx101/lightw...n-b30c4b6189fe
but see his final conclusion about very powerful cars.. interesting
Old Dec 20, 2022 | 07:33 PM
I.T. Guy's Avatar
2023 E63S Wagon
Anything in Magnesium is lighter weighing just 15-16 lb per wheel in 19” for our cars.
Theres a few places doing them, here’s one:
https://www.litespeedracing.com/technology
Old Dec 20, 2022 | 09:01 PM
C2 Turbo's Avatar
1991 964 Turbo, 2002 Black E55, 2002 Black E55 " The Beast"- 2014 E63s
Looks good
Care to share the offsets and the tire sizes?
Old Dec 20, 2022 | 11:12 PM
Scott Gerhardt's Avatar
2014 E63 AMG
m157 is pretty stout in terms of tuning and reliability.
Old Dec 21, 2022 | 12:39 AM
ThreeSix's Avatar
G550
Originally Posted by C2 Turbo
Looks good
The wheels are +33, but the front is +28(running 5mm spacer so that the center cap clears the wheel bearing dust caps). Tires are 265/35/19 DWS06 all around
Old Dec 21, 2022 | 08:02 AM
C2 Turbo's Avatar
Any vibrations with the 5 mm spacers? what brand are they?
