Down Pipes wiestec VS the rest
Old Jul 10, 2019 | 05:09 PM
Roverron's Avatar
ML63
Are the wiestec downpipes worth it powerwise is there a gain? Or just go with the easy bolt on ones?
Old Jul 10, 2019 | 05:47 PM
Das_it16's Avatar
2004 E55 AMG
Yes there are gains. Check out this thread and I even show a roll race video comparison. Go to post #19.
https://mbworld.org/forums/w212-amg/...ml#post7792283
Old Jul 10, 2019 | 09:11 PM
V-AMG's Avatar
2016 E63s Wagon - CCB & CF package
https://youtu.be/1s9SrZuwi6s
This can’t possibly be just from the bridge pipes. The CLS walked away effortlessly. Probably close to 100WHP difference between these two cars if i had to guess.
That said, I want bridge pipes badly, but I won’t ever get them for as long they require engine removal on 4matic cars.
Since we are on topic, how much louder is catless vs with cats? I am debating starting to mod a bit, and get catless downpipes.
Old Jul 11, 2019 | 12:58 AM
Iron Sheik's Avatar
E 320
Catless is much louder vs cats!
Did it on my E63 when I had it. Now brother has the car
Got a CLS63 and did the same thing to it.
Absolutely love it!
Do a cat delete, stage 1 and call it a day!
Iron Sheik
Old Jul 11, 2019 | 03:39 AM
cocobeex's Avatar
2014 E550 4MATIC TUNED - Turbo Upgraded Stage 3
With true 3 inch DP.
It for sure has gain...i should have done Dyno before and after.
Old Jul 11, 2019 | 10:15 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
I just go these make for a customer with a AWD he did not want the bridge pipes
Old Jul 13, 2019 | 01:01 AM
Hammer Down's Avatar
2015 E63S, 2018 E63S
What’s up old friend how have you been? How much?
Old Jul 13, 2019 | 07:06 AM
V-AMG's Avatar
Playing devils advocate here, but what’s the point of 3” midsection if the bridge pipes are smaller and the rear section of the exhaust is 2.75”?
Old Jul 17, 2019 | 08:47 AM
Lumi's Avatar
E63 AMG S
Bridge pipes are and will remain useless on these cars. This video is extremely misleading to the community and that is not an accurate representation of a oem bridge pipes vs a aftermarket bridge pipe. Not sure if he has a connection or works for a company.
Old Jul 17, 2019 | 08:57 AM
V-AMG's Avatar
There’s gotta be some improvement, no? You saw a before and after? I’d love to hear they don’t do much so i can feel better about not getting them 😁
Old Jul 19, 2019 | 10:36 AM
5soko's Avatar
AMG
There’s gotta be some improvement, no? You saw a before and after? I’d love to hear they don’t do much so i can feel better about not getting them ��
I had argued this in the other thread aswell but once that massively misleading video was posted, i gave up my efforts .
Ive seen the race between the two and there is nothing in it..
There is no actual restriction inside these ‘bridge pipes’ , these vendors and companies argue flow limitations due to the oem pipe construction.
The oem bridge pipe is formed tall in the middle and not round. These companies use this oem shape to convince people this is a flow limitation as many naturally think its a bottle neck, but anyone who understand fluid dynamics, understands you aren't losing any flow volume because of the tall shape, and if the oem pipe was round and not tall , it would naturally tell your brain higher flow rate vs tall and skinny.
The hassle and expense to fit these aftermarket bridge pipes is laughable when you see little to no results in person on the road.
Non the less, the oem bridge pipe isnt gonna limit flow from 19-20psi from these small turbos, and from what i have seen, it doesnt.
These aftermarket bridge pipes, look pretty, are big, and visually appealing to the brain in terms of flow, but it is overkill for our small turbos.
Dont get me wrong, with bigger turbos, engine out, might be worth ditching the oem pipes.
just another easy money exhaust option for vendors to profit off of.
Old Jul 19, 2019 | 01:19 PM
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
Exactly. Bridge pipes offer nothing measurable on stock turbos. In fact, you’d be pressed to see a difference from aftermarket DPs compared to hollowing out your cats. But to the OP’s original question, nothing from Weistec is worth the mark up unless you perceive brand recognition as something you want to pay extra for.
Old Jul 19, 2019 | 04:13 PM
V-AMG's Avatar
I think that’ll be my route then, tune and replace cats with straight pipes using factory pipes
