Coolant leak - bad reservoir?
Old Dec 17, 2021 | 09:48 AM
hwright's Avatar
SLK 230 - 1998
Thank you. It is fragile.
Old Dec 17, 2021 | 10:40 AM
bdubs's Avatar
Current: 2018 E63 Selenite Wagon (700hp/850tq) Prior: 2016 E63 Selenite Wagon (670hp/830tq on E30)
Just had my coolant reservoir replaced a few weeks ago. Minor leaking/coolant staining was noticed at ~61,000 miles on my 2016.
Old Dec 17, 2021 | 11:01 AM
hwright's Avatar
SLK 230 - 1998
Here is how I temporarily patched the hose that broke. I used a 7/16 ID hose (3/8 should also work) and slipped it over the two halves of the broken hose and clamped it on both ends. So far (1 day) so good.
Old Dec 17, 2021 | 01:59 PM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
The M157 coolant lines are horrible. I'm beginning to think MB had them made from some seriously biodegradable material that is not heat resistant. Never have I ever had coolant lines on any previous MB fail so quickly. Just junk.
Old Dec 17, 2021 | 05:06 PM
AMGfifty5's Avatar
05 C55-gone 06 E55-gone 15 P85D 14 E63 S 11 Sonata 😅
Nice work. I did the same on my 06 e500 while the part came in fcpeuro. It worked so well I never installed the oem piece 😂
on the e63 I decided to spend the extra cash
Old Dec 20, 2021 | 11:43 AM
hwright's Avatar
SLK 230 - 1998
Thanks for the information and part number!!
Old Nov 1, 2022 | 10:35 AM
  #32
NoVAe63s's Avatar
2016 E63s
Well karma has caught up and now in addition to the cap leaks now I have my own pinhole leak.
It's not at the seam between the clear and black plastic but oddly in the middle of the clear. You can see the high pressure stream in this picture as well as dried coolant residue from previous leak events. Going to stealership this week.
Old Nov 1, 2022 | 08:49 PM
  #33
SilverE5588's Avatar
'15 E63S,'21 LCI M5
Nice shot there . Swapping out reservoirs is easy enough pinching off the lines to avoid bleeding the system . Are these 157's self bleeding ? or is a vacuum tool needed if a more significant amount is changed or lost ?
Old Nov 9, 2022 | 12:09 PM
  #34
NoVAe63s's Avatar
2016 E63s
MB replaced under warranty, service notes don't specify whether the system was bled just refilled.
They also found a stress-cracked turbo coolant line, presumably the plastic one and replaced without prompting. Kinda surprised actually.
Old Nov 9, 2022 | 09:22 PM
  #35
WANTED!!'s Avatar
14 E63, 05 E55, 03 Evo 8, 08 F250, 06 R6R, 92 Talon TSI, and instability
​​​​​​​It is not self bleeding. The WIS notes that bleeding the coolant system should be done with a vacuum tool. However, you can bleed via the old traditional method of cap off under idle. It take ALOT of time to do it that way on these cars, but know it can be done.
Old Nov 10, 2022 | 09:10 AM
  #36
'15 E63S,'21 LCI M5
Thanks for clarifying . Yeah looks like fill/bleeding the intercooler side star is needed for activate the ic pump . Wonder if it's like the e55's where you can jump the fuse or pump to run to bleed it out ..
Old Nov 10, 2022 | 09:14 AM
  #37
WANTED!!'s Avatar
​​​​​​​on the e55s, the coolant system wasn't a split setup (unless you did it yourself) and necessitated that step. If your car is a face-lift model, the system is already split and that's not necessary.
