KW HAS - long term review?
Any issues with these? How about height adjustability? Tire wear? Camber issues?
Go for it. You won’t regret it.
Did an alignment right after the install - the alignment shop was able to get the car within factory spec for both camber and toe fairly easily.
Just make sure you get an alignment done once you are satisfied with your height setting.
KW HAS, just the lowering springs with adj links. No need for HLS for me.
Wheels dont rub in the rear, over bumps or climbing into gas stations?? I am considering 20’s but was afraid of lowering too
