E63 S 4Matic M157 | Factory WIS Maintenance and repair documents
Old Jun 19, 2024 | 01:16 PM
  #251
Jtaveras13's Avatar
2015 e63s
Originally Posted by Valvestud
As always with Mercedes, their terminology of parts and those of us in the US, don't match up. I need more description of what pipes you're referring to, as the EPC system comes back with a myriad of possibilities.
Thanks,
Joe
For these 2 pipes but on the left/driverside
Can I also get the parts list for the 2 pipes going into oil for housing.
Old Jun 19, 2024 | 01:27 PM
  #252
Valvestud's Avatar
2014 E63 AMGs, 2015 F-150 Lariat, 2010 Porsche C4S
Attached are two that should help you. I'm again not clear on your follow up request "2 pipes going into oil for housing".
Regards,
Joe
File Type: pdf
File Type: pdf
Old Jun 19, 2024 | 02:49 PM
  #253
Jtaveras13's Avatar
2015 e63s
Regards,
Joe
I guess it for the oil cooler. I will send a pic.
These 2 pipes. I just want to make sure I use the correct screws
Old Jun 19, 2024 | 02:51 PM
  #254
Jtaveras13's Avatar
2015 e63s
The parts list for this one as well. This is on the driver side. One goes to intercooler and the other goes to turbo housing
Awesome the two attachments are exactly what I needed. Thank you. Please Message me so I can send you money for lunch/dinner. You been a huge help. Zelle,cash app or any instant money app
Old Jun 19, 2024 | 03:06 PM
  #255
Valvestud's Avatar
Perhaps these will help.
Regards,
Joe
File Type: pdf
File Type: pdf
Old Jun 19, 2024 | 06:07 PM
  #256
Jtaveras13's Avatar
2015 e63s
Hose going to waste gate
Does this hose go in front of thermostat or behind.
Old Jun 21, 2024 | 01:07 PM
  #257
Jtaveras13's Avatar
2015 e63s
Thanks,
Joe
I got it already. Ty. I do need the dipstick tube and bracket parts information it possible.
Old Jun 21, 2024 | 01:15 PM
  #258
Valvestud's Avatar
Attached.
Regards,
Joe
File Type: pdf
Old Jun 22, 2024 | 04:01 AM
  #259
Jtaveras13's Avatar
2015 e63s
Attached.
Regards,
Joe
Ty Joe. Can you send me the coolant housing parts. I took out one of the of m8x80 bolts and need the torque specs
I found it in this thread. its 10nm and then 20nm.
Old Jun 23, 2024 | 02:27 AM
  #260
Jtaveras13's Avatar
2015 e63s
This picture only shows one bolt but in the picture below it has 2 bolts
This is the bracket that come off valve cover on left side
Old Jun 23, 2024 | 02:34 PM
  #261
Valvestud's Avatar
I searched thru pretty much all sections and can't find the bracket. Can you be more descriptive about what it is attached to?
Old Jun 23, 2024 | 03:30 PM
  #262
Jtaveras13's Avatar
2015 e63s
This bracket bolts onto the the engine itself. Not the valve cover by 2 bolts. This bracket also holds the clip for ecu near the firewall. It also holds the oil dipstick tube
Old Jun 23, 2024 | 05:19 PM
  #263
Valvestud's Avatar
Sorry, not finding anything that look anything like that bracket.
Old Jun 23, 2024 | 07:37 PM
  #264
Jtaveras13's Avatar
2015 e63s
wow thats so wild. I have tried finding it everywhere online also and cannot not find anything
I look at the valve cover pcover no success.
I have one m7×65mm and thats the only hole i don't have a screw in.. i just cant remember
Old Jun 24, 2024 | 06:24 PM
  #265
Jtaveras13's Avatar
2015 e63s
Does this picture help out?
You can zoom in and see the part i was referring to. I went to local mercedez and no help.
Old Jun 25, 2024 | 02:37 PM
  #266
Jtaveras13's Avatar
2015 e63s
Engine lift bracket
This is the part i was referring to. Part number 2782230641. Big screw is a m7x65. Other bolt holding dipstick tube is m6x20
Old Jul 3, 2024 | 02:29 PM
  #267
Mojo20032004's Avatar
2014 E63S
I know this off topic, happen to a w222 s560 valve cover repair manual? Drivers side specifically?
Old Jul 3, 2024 | 03:22 PM
  #268
Valvestud's Avatar
Please provide VIN. PM me if you don't want it public.
Thanks,
Joe
Old Jul 4, 2024 | 12:30 PM
  #269
Valvestud's Avatar
Thanks,
Joe
Attached is the primary procedure. There are numerous others. Please request which others you need.
Regards,
Joe
Old Jul 4, 2024 | 03:02 PM
  #270
2014 E63S
Regards,
Joe
Hey Joe, so this is for the W222 s560? Mentions nothing of engine removal as they recommend or even the front end needing to be pulled off?
Old Jul 4, 2024 | 03:35 PM
  #271
Valvestud's Avatar
If you just look at the top of the document, you'll see that it is for the M176 engine in the W222 model. So, not sure what else I can tell you.
Old Jul 4, 2024 | 03:43 PM
  #272
2014 E63S
Just looks way easier than what everyone is saying about 24hr job and such. I did see the top with the engine codes and chassis.
Old Oct 5, 2024 | 09:43 PM
  #273
jcarsnz's Avatar
Hi Joe
Could I please request instructions to remove the Radiator Fan Unit for the W166 ML63?
VIN: WDC1660742A440774
Old Oct 6, 2024 | 12:40 PM
  #274
Valvestud's Avatar
Originally Posted by jcarsnz
Hi Joe
Attached.
Regards,
Joe
File Type: pdf
Old Oct 31, 2024 | 02:58 AM
  #275
jcarsnz's Avatar
Hi again Joe,
Could I please request instructions to remove/replace the Oil Drip Pan (A2730100162) for the W166 ML63?
