E63 S 4Matic M157 | Factory WIS Maintenance and repair documents
Old Jun 8, 2023 | 12:05 PM
  #201
Valvestud's Avatar
2014 E63 AMGs, 2015 F-150 Lariat, 2010 Porsche C4S
Originally Posted by Jaybird123
Joe, do you by chance have a doc on the m278 camshaft adjuster replacement? I have done the swap but need the torque value for the cam adjuster bolt...
Attached. Given that you did not provide a VIN or year/model info, I used a VIN from a 2007-2011 S500.
Edit: I see now you put model info into your signature data. Correct procedure attached.
Regards,
Joe
Old Jun 8, 2023 | 12:30 PM
  #202
Jaybird123's Avatar
2015 E63S Sedan, 2014 E550 coupe
Thanks so much for the quick response. I found 115Nm referenced in another post from a few years back, glad to see the official 130Nm value here!
I realize now that while I have the valve cover bolt tightening sequence and torque values, I don't have the sealant path pdf...do you have that one as well?
Now I owe you beers...but HOU is a bit out of range from KY. THANK YOU
Old Jun 8, 2023 | 12:40 PM
  #203
Valvestud's Avatar
Attached.
Regards,
Joe
Old Jun 8, 2023 | 01:18 PM
  #204
Jaybird123's Avatar
Thank you, and hmm...those are the docs I have already...see where it says "Notes on sealant path for cylinder head cover AH01.30-P-1000-08MM" ? I was wondering if there is a document it is referring to here? I have such a sealant path doc for the front cam covers, but not for the valve covers. I can mostly follow where I have residue, but...
Old Jun 8, 2023 | 01:34 PM
  #205
Valvestud's Avatar
Attached.
Regards,
Joe
Old Jun 21, 2023 | 08:57 AM
  #206
pkak2023's Avatar
2014 E550 4matic
Hi Joe,
I'm looking for instructions and part number list to remove and replace oil pan and gasket for 2014 E550.
VIN WDDHF9BB7EA886684.
Thank you,
Paul
Old Jun 21, 2023 | 01:32 PM
  #207
Valvestud's Avatar
Originally Posted by pkak2023
Hi Joe,
Thank you,
Paul
Attached. Look like lots of things need to happen to remove the pan. Let me know if you need other procedures listed in this one.
Regards,
Joe
File Type: pdf
Old Jun 21, 2023 | 02:01 PM
  #208
pkak2023's Avatar
2014 E550 4matic
Can you post part number for the oil pan and the bolts ?
Thank you,
Paul
Old Jun 21, 2023 | 02:53 PM
  #209
Valvestud's Avatar
Thank you,
Paul
Not sure why but all of the parts you're looking for are grayed out. As such, there's no part displayed. I've attached a picture of what comes up. I assume the parts you're looking for are shown.
Regards,
Joe
File Type: pdf
Old Jun 23, 2023 | 01:55 PM
  #210
cold bud3's Avatar
2015-E63S | 2012-C300
Question 2015 E 63S
Originally Posted by 5soko
Hey guys, figured id post the most up to date maintenance documents and repair procedures according to Mercedes Benz direct from the factory dealer WIS. WIS is what the techs use at the dealer and how benz wants these cars repaired, its a factory service manual in short.
These are good for 14-16 E63 S 4matics, but most will be good for early E63 M157 aswell!
I will add more if i think it may be helpful to the community.
Enjoy!
How to access and clean the throttle body on the M157 ? I need to clean it somehow. Thank you for any input guys.
Old Aug 20, 2023 | 07:27 AM
  #211
Jaybird123's Avatar
Regards,
Joe
Hey Joe, one more ask fella
Do you have front strut replacement doc(s) for my m278? Not getting any response on the sub-forum dangit. I have the electronic dynamic pkg (483)
Old Aug 20, 2023 | 11:27 AM
  #212
Valvestud's Avatar
It will take a few days to get you the procedure. My PC with XENTRY is toast. Should be back up later in the week.
Regards,
Joe
Old Aug 20, 2023 | 02:48 PM
  #213
Jaybird123's Avatar
Regards,
Joe
Aw man, sorry to hear it Joe! Understood, no worries
Old Aug 24, 2023 | 03:44 PM
  #214
Valvestud's Avatar
I'm back up now. Your request is too vague. Please post or PM your VIN
Regards,
Joe
Old Aug 28, 2023 | 10:43 AM
  #215
Jaybird123's Avatar
Apologies Joe, here is my VIN: WDDKJ7DB9EF228017
Old Aug 28, 2023 | 03:53 PM
  #216
Valvestud's Avatar
Here you go, Let me know if you need additional information.
Regards,
Joe
Old Oct 27, 2023 | 04:20 PM
  #217
Waleed amg63s's Avatar
Cls 63
Thanks a lot bro very helpful!!
can I find diagram or any thing about engine air system,, all tubes,vacuums , sensors,etc
my car may have an AIR LEAK pin the engine air system ((cls 63 2012)) 🧐🧐🧐
Old Oct 27, 2023 | 04:23 PM
  #218
Cls 63
Enjoy!
Old Mar 20, 2024 | 11:50 PM
  #219
PeterUbers's Avatar
Oil filter and oil housing torque specs thanks to @Valvestud
https://mbworld.org/forums/w212-amg/...que-specs.html
Old Mar 31, 2024 | 08:53 AM
  #220
NickE63AMG's Avatar
W204 C220
Procedure to remove the trans
@valvestud
Hello Joe,
do you have a doc showing how to disconnect and remove the trans from the engine on a CLS w218 AMG 63s 4WD?
Thanks you
Nick
Old Mar 31, 2024 | 01:38 PM
  #221
Valvestud's Avatar
Originally Posted by NickE63AMG
@valvestud
Hello Joe,
Thanks you
Nick
Attached are many procedures to get you started. Let me know if you need others.
Regards,
Joe
Old Mar 31, 2024 | 02:03 PM
  #222
NickE63AMG's Avatar
W204 C220
Many thanks Joe
I didnt figure out it was so complexe
I will look at thème
Nick
Old Apr 1, 2024 | 08:13 AM
  #223
PeterUbers's Avatar
@Valvestud do you have a document to discuss service recommendations for oil solenoid failure in the m157? Or for code P06DA00
thank you
Old Apr 1, 2024 | 11:55 AM
  #224
Valvestud's Avatar
thank you
Sorry, nothing of that sort.
Regards,
Joe
Old Apr 3, 2024 | 12:18 PM
  #225
PeterUbers's Avatar
Regards,
Joe
any idea where to find service documents on this?
