E63 S 4Matic M157 | Factory WIS Maintenance and repair documents
Old May 25, 2022 | 05:04 PM
  #126
Code7rpd's Avatar
Porsche 997.1
Hey Joe - the part numbers are 212-330-21-03 and 204-330-19-03/203-330-19-03. They should fall under the steering gear assembly.
Old May 25, 2022 | 05:23 PM
  #127
Valvestud's Avatar
2014 E63 AMGs, 2015 F-150 Lariat, 2010 Porsche C4S
Can't find the first part, but found the other two. It appears the other part is the inner tie rod which MB shows as A2123302803. Procedure and pic/parts list attached.
Regards,
Joe
File Type: pdf
File Type: pdf
Old May 25, 2022 | 05:29 PM
  #128
Code7rpd's Avatar
Porsche 997.1
That's perfect and helps. I guess MB calls it a track rod. Is there a replacement procedure for the inner tie rod listed?
Old May 25, 2022 | 05:36 PM
  #129
Valvestud's Avatar
Here you go.
Regards,
Joe
Old May 25, 2022 | 06:19 PM
  #130
Code7rpd's Avatar
Porsche 997.1
Thanks so much!
Old May 27, 2022 | 05:59 PM
  #131
dustinN's Avatar
09E350, 07E63, 13CLS63
Is there instruction on how to replace the Glove box assembly? Part # 218-680-02-91. VIN WDDLJ7EB3DA079389
Thank you!!
Old May 27, 2022 | 07:11 PM
  #132
Valvestud's Avatar
Thank you!!
Attached.
Regards,
Joe
Old May 27, 2022 | 08:12 PM
  #133
dustinN's Avatar
Great! Thank you so much for the quick response!
Old Jun 2, 2022 | 10:25 PM
  #134
dustinN's Avatar
Mr. Joe, may I have the instruction on how to replace the camshaft magnet solenoids please?
Thank you
Old Jun 2, 2022 | 10:59 PM
  #135
Krule77's Avatar
2014 E63S
O2 sensor replacement on 2014 e63s
vin=WDDHF7GB3EB003123
Hopefully these are what you need.
Regards,
Joe[/QUOTE]
Old Jun 3, 2022 | 09:55 AM
  #136
Valvestud's Avatar
Regards,
Joe
[/QUOTE]
Guessing you want part number for the sensors. If so, it's A 276 905 10 00.
Regards,
Joe
Old Jun 3, 2022 | 10:58 AM
  #137
Valvestud's Avatar
Thank you
Here you go.
Old Jun 3, 2022 | 11:16 AM
  #138
dustinN's Avatar
As always, thank you so much. I really appreciate your help. For step #3, remove oil filter housing: may I have instruction on how to do this? I have everything opened, staring at this for hours and couldn't figure it out how.
Old Jun 3, 2022 | 12:16 PM
  #139
Valvestud's Avatar
Attached.
Regards,
Joe
Old Jun 3, 2022 | 01:30 PM
  #140
Code7rpd's Avatar
Porsche 997.1
Hey Joe - any chance I could get the removal for the alternator on VIN WDDHF7GB7EA984434?
Old Jun 3, 2022 | 01:42 PM
  #141
Valvestud's Avatar
It looks like it's quite a project based on the attached procedure. I've included the referenced other procedures as well.
Regards,
Joe
File Type: pdf
File Type: pdf
Old Jun 3, 2022 | 02:15 PM
  #142
Code7rpd's Avatar
Porsche 997.1
That does seem pretty involved...I appreciate the info!
Old Jun 3, 2022 | 05:01 PM
  #143
Krule77's Avatar
2014 E63S
Regards,
Joe[/QUOTE]
looking for the procedure to change the upstream sensor and was trying to see how the dealer does it. If it’s possible without removing exhaust or not
thank you so much for your quick responses. If we ever cross paths the beers on me 🍻
Old Jun 5, 2022 | 01:09 PM
  #144
Valvestud's Avatar
Regards,
Joe
thank you so much for your quick responses. If we ever cross paths the beers on me 🍻[/QUOTE]
Please confirm from attached what you're wanting to replace. If not there then I need more description to isolate part/procedure.
Old Jun 9, 2022 | 02:39 PM
  #145
to1988's Avatar
C55 '05
Hello Joe!
I have a small coolant leak from the timing cover on my E63 M157. Can you help me about the procedure and in the parts?
Thanks!
Tom from Hungary
Old Jun 9, 2022 | 03:09 PM
  #146
Valvestud's Avatar
Originally Posted by to1988
Hello Joe!
Thanks!
Tom from Hungary
Need VIN ta assure proper procedure/parts.
Old Jun 9, 2022 | 03:25 PM
  #147
to1988's Avatar
C55 '05
WDD2120761A973970
Old Jun 9, 2022 | 03:35 PM
  #148
Valvestud's Avatar
WDD2120761A973970
Attached is the procedure, a parts list, and pictorial. There are numerous procedures involved in replacing the case. If you decide to move forward, let me know which other procedures you need. One other note; the procedure calls out specifically Loctite 5970 for the case sealant.
Regards,
Joe
File Type: pdf
Old Jun 9, 2022 | 03:43 PM
  #149
to1988's Avatar
C55 '05
Regards,
Joe
Thanks Joe!
I will show it to my mechanic because he will do it. Have you got any suggestions on this job? What to replace or change?
Old Jul 14, 2022 | 03:51 PM
  #150
to1988's Avatar
C55 '05
Hello again!
Do anybody know what type of coolant I need to refill my intercooler system?
2014 E63s.
Thanks!
Tom
