Weird suspension noise. Squeaky Squeaky!
Old Dec 8, 2022 | 11:37 PM
rjz2177's Avatar
Three MB's: GLK, ML & E - Class with Panam Grill
Dropped it today and my dealer says everything look good - Of course no squeaking today. I'm still arguing with them about the pictures above for the control arms and how can they be stained like this. Anyone has any ideas?
Also they said the sway bar is fine also. So I called MBUSA customer support to complain, they opened a case emailed the dealer, cc'ed me, than closed the case after the email. Whatever that suppose to do.
is MBUSA Customer support the right people to complain about your dealer?
Old Dec 9, 2022 | 08:26 AM
NoVAe63s's Avatar
2016 E63s
They don't give two chits. Had a dealer try to swindle me on the AC funk smell issue, wanted to charge me for disinfectant spray and new filter. When I showed them the class action settlement terms where this was supposed to be covered by MB they claimed no knowledge of it and even blamed poor training materials.
Sent a complaint to MBUSA nothing ever happened. You'd think a court order would be taken seriously...
Old Dec 13, 2022 | 09:12 AM
NoVAe63s's Avatar
2016 E63s
@NoVae63s: Any update what the dealer found to resolve your issue and if they covered them under CPO. Thanks
Well here's the update. They didn't find an issue with the lower control arms but rather found failures in the upper control arms. Invoice notes "torque arm" but part # references upper CA.
Maybe check these if you can get to them.
Old Dec 13, 2022 | 02:39 PM
E55 KEV's Avatar
Veteran: Air Force
2024 GLE63s / 2016 GLE63s (traded) / 2016 E63s / 2002 E55
Last year I got estimate for those Strut Rods but when work was done, they replaced the Lower Control Arms (Cross Members):
squeaky/creaky front end - Page 2 - MBWorld.org Forums
Old Dec 20, 2022 | 11:03 PM
rjz2177's Avatar
Well....Still have 5 months into the CPO...Noise barely ever consistent to show it to the dealer...I give up at the moment till the noise is constant for the dealer to put his finger on it.
Just received Command update to 6.80, and increased tire pressure to 38 on all tires...any possible way that this update may have adjustment on the suspension to make it soft?
Old Dec 21, 2022 | 10:18 AM
E55 KEV's Avatar
Veteran: Air Force
IMO 38 PSI is too low.
Old Dec 21, 2022 | 10:22 AM
  #32
PeterUbers's Avatar
did the comand infotainment update improve your suspension? No
Old Dec 21, 2022 | 11:43 AM
  #33
rjz2177's Avatar
On the gas cap lid it says 35/38 front/rear. Dealer had it set at 35…. What tire pressure is correct for 19”AMG Run Flat tires?
Old Dec 21, 2022 | 11:47 AM
  #34
E55 KEV's Avatar
Veteran: Air Force
Sorry my mistake I was thinking of my GLE63s which is 45/51.
Old Dec 21, 2022 | 12:01 PM
  #35
E55 KEV's Avatar
Veteran: Air Force
here's inside fuel door posted on another thread:
Alignment/tyre wear question - MBWorld.org Forums
