w212 water leake
Old Mar 17, 2020 | 02:26 PM
Mohd Saadi's Avatar
W212 2011
w212 water leake
hello guys my w212 is leaking water from behind
hhow can i fix this problem
but i dont think its water
ca someone help please
Old Mar 17, 2020 | 05:42 PM
speedlimit's Avatar
Administrator Emeritus
Hi and welcome!
Good question! i'm moving your post to the W212 forum for help from fellow owners. Good luck!
Bob
Old Mar 17, 2020 | 06:19 PM
cdk4219's Avatar
95 SL600
Could be the sunroof drain in the rear sunroof pan has become dislodged or possibly clogged. The tube runs in that vicinity.
Old Mar 18, 2020 | 01:37 AM
Mohd Saadi's Avatar
W212 2011
could you please help me fix it .....or you can send me a video
and how can i clean all the sunroof drains in my w212
Old Mar 18, 2020 | 01:42 AM
Mohd Saadi's Avatar
W212 2011
can you please help me fix it.....and can you tell me how to clean all the sunroof drains please
or maybe you can send me a video
Old Mar 18, 2020 | 07:28 AM
FastWgn's Avatar
2016 E63 Wagon
Sunroof tubes alright. Clean them carefully so they don't get dislodged. Then you have a real ****show on your hands. Plenty of write-ups on how to do that on the interwebs.
Old Mar 18, 2020 | 11:36 AM
Ncbimma's Avatar
E63S
use compressed air to shoot thru the drain tubes or you can "fish" a speedometer cable thru and snake out the blockage.
Old Mar 18, 2020 | 12:37 PM
FastWgn's Avatar
2016 E63 Wagon
Very careful with this approach. If there is blockage you may disconnect the tube instead.
Old Mar 18, 2020 | 01:41 PM
Mohd Saadi's Avatar
W212 2011
can you send me a link or a video please or tell me where the tubes are located
Old Mar 18, 2020 | 01:43 PM
Mohd Saadi's Avatar
W212 2011
can you please send a video or tell me how to do it
Old Jul 4, 2023 | 03:00 PM
CyndiV's Avatar
2011 E350 Wagon
Hello,
Just finding this thread.
Just took possession of a new to me, 2011 E350 wagon.
Gave it a good detailing and noticed a lot of debris in the sunroof track and a bit of staining on the interior headliner on the passenger side near the panoramic roof. I watched a couple of videos about sunroof drains and decided to see if they were clogged. I poured some water into the track and was surprised to see water coming down the WINDSHIELD from right in FRONT of the glass panel of the panoramic roof. Its appears to be bypassing the A column drain hoses and discharging in front of the glass pano panel where it joins the windshield.
I am confused, since i would assume it should drain as many have suggested, down a hose in the A column and out into the wheel well.
Anyone have any clues? I am not sure if someone tried to 'fix' a leak this way? Is this an issue or concern? There have been several recent rain storms, and I washed the car for hours when I brought it home and there is no moisture that I can detect now...(but maybe I am just not seeing it??)
ANy help would be appreciated.
Cyndi
Old Mar 15, 2024 | 09:43 PM
Jcpaul's Avatar
2014 W212 wagon
Originally Posted by CyndiV
Hello,
Cyndi
Cyndi - did you ever figure this out? I'm having an identical issue and have confirmed that the drains are working correctly.
