Hey Guys,
Wanted to see if this has happened to anyone. I just put on the H&R springs on my 2014 E63s 4matic and got these rear links. Rear Adjustable Links. I am now getting an Suspension Malfunction message on my car. Anyone know what could be the issue? The error resets once I restart the car but turns on within a minute.
Cylinder Head
close
- Join DateJul 2006
- LocationSeattle
iTrader Positive Feedback100
iTrader Feedback Score(1)
- Vehicle(s) I drive'19 E63S, ‘16 CLS63 RIP, '09 E63 Gone, '06 M5 Gone, '97 Supra TT Gone
Liked:594 Times in 388 Posts
Probably something wrong with your install, and first suspect is the rear.
Rehabguy
close
- Join DateJan 2012
- LocationNYC
iTrader Positive Feedback0
iTrader Feedback Score(0)
- Vehicle(s) I driveE63S
Liked:310 Times in 235 Posts
I wish I could offer a real solution, but the only idea I have is as stated above. That has to be coming from the rear section as the front doesn't have sensors (as far as I know). Aside form getting the message, are there ill effects? Does anything happen to the ride height? Does it pop up cuz/when you are switching between drive modes?Originally Posted by thabigo22
Hey Guys,Wanted to see if this has happened to anyone. I just put on the H&R springs on my 2014 E63s 4matic and got these rear links. Rear Adjustable Links. I am now getting an Suspension Malfunction message on my car. Anyone know what could be the issue? The error resets once I restart the car but turns on within a minute.
Quote:
Ah good point sorry forgot to mention that. The suspension setting stays locked so I can't change it at all. It stays at the comfort height. I'll recheck everything with my mechanic on Monday to see if we missed something. Originally Posted by Rehabguy
Your rear links could be touching the control arm on certain bumps . The ball of the link, it happened to me when I would hit the gas hard or hit a big dip. So I adjusted the main bracket and re adjusted the link . Problem never came back. Make sure link end ball doesn’t come in contact. Unfortunately it’s hard to see if it willl at regular stance . Jack the car up so that the rear bags air out then drop the car from the jacks and check where the link placement is before you air up.
Thanks for the tips.guys. turns out it was a front left sensor that needed a slight adjustment. These cars have sensors on all 4 sides the the front left was reading off so we loosened the bracket and readjusted it and now it's all good to go.
Rehabguy
close
- Join DateJan 2012
- LocationNYC
Quote:
That's great news! Glad to hear you figured it out.Originally Posted by thabigo22
Where are the sensors at the front?
yeah just did the same install and now I have malfunction light... even went back to stock links and it sill the same!
ExploreQuote:
They are connected at bottom end to the infamous squeaking cross struts.Originally Posted by Rehabguy
That's great news! Glad to hear you figured it out.Where are the sensors at the front?
Rehabguy
close
- Join DateJan 2012
- LocationNYC
Quote:
Yes! I have since learned about the location of these sensors. Thanks!Originally Posted by Valvestud
I am about to lower the car and with a 1000 mile road trip couple of weeks away, may be I should just wait and do it after words ?
Can someone explain, the locations of these sensors and how to avoid these issues?
Rehabguy
close
- Join DateJan 2012
- LocationNYC
I don't know how the issues discussed in this thread come about. I had my car lowered and, knock on wood, everything has been great for a couple of yrs now. the front Ride height sensors don't get discussed much on here (you can see I did not even know of their existence 2 yrs ago). But I am sure (evidently) they affect the overall outcome (as they play a roll in keeping the car leveled).Originally Posted by Faast
I am about to lower the car and with a 1000 mile road trip couple of weeks away, may be I should just wait and do it after words ?Can someone explain, the locations of these sensors and how to avoid these issues?
Look at this video as they show how the lowering is done (though they don't talk about the front sensors either):
And, yeah, I'd do that 1K mile trip and THEN mod my car if I were in your shoes.
