Kind of bought one, have few questions... '14 e63s
Sold my w211 e55 last month, instant regret.
I chose to skip the m156 models and began looking at 12-13 w212 p30 cars and V2 CTS-Vs (owned one a few years back)
I was looking at a few low mile e63 p30 cars until I began reading about the timing chain issues. I had the dealers send pictures of the chains and every single one had the old "split" chains. I've spent a few hours reading, about it but I couldn't find the info I was looking for.
1. I do all my own work, but I couldn't find a single DIY chain replacement thread here? I know obviously is very involved, but i was surprised I couldn't find any examples
2. How common is this? should they be completely avoided?
ANYWAY, I then began considering the 2014-16 e63 S models and 2016-18 CTS-Vs. To be honest, I mildly prefer the 12-13, but the updates is growing on me.
I reserved one at caranna of all places tonight lol, it seemed like a good price for the super low miles. Just wanted to know your thoughts on the 12, 13 vs the 14-16 and is it worth the bump in price in your opinion.
Thanks guys
Thanks guys
The timing chain issue probably isn't super common however its a major repair which could lead to catastrophic damage. Might as well put that money towards buying a facelifted model which doesn't have that issue and has updated interior, exterior, and features.
The other 2 I was considering were the black '12 wagon in WA (couldn't be father way, but wagon, night vision etc 44k for $44k) and a '12 P30 sedan with 22k, for $41.
I enjoyed my V2, it was 600/601 at the wheels, loved the sound, but would light the tires at any speed. e55 was modded as well, not quite as much power, but still traction issues and last thing you want is to lose control when your playing around and put it into a ditch. Another reason why I was leaning towards an AWD E63.
DIY is huge for me, I love it. Heck my 355 requires pulling the motor out every couple years for routine maintenance. The DIY e55 and 355 communities have grown quite a bit and there is all kinds of resources if you needs some pointers. Hoping to find and contribute here.
For sure there are examples of later model changes that were to the detriment of the tunability - being an old DSM guy, the 2G swapped to a smaller T25 turbo to reduce lag, but it just killed top end when you modded. But I think the 2014-16 E63s have been great cars.
If I was looking to tinker I would go CTSV, if simply driving it I would go E63S.
As far as I know, and I cross-checked in WIS, the upgraded chain group begins from 03/02/2012, engine # 60009367. My 2013 W212 M157 has the upgraded chain group.
Hope this helps.
Hope this helps.
Thanks guys
whatever, we'll see here in a few days
Today, It's worth $50k.
Kills me just thinking about it. But that's just how the market works sometimes.
Girodisc rotors are premium parts and also the lightest generally available at 23.6/14.4 lbs (10.7/6.5 kg) F/R. You do not *have to* replace OEM rotors every time with pads. Replace based on rotor wear such as remaining thickness, grooving, warping, cracking.
So I do my own vehicle inspections, anything specific to an 14' e63s besides brakes I should look for?
As you know, LSD significantly raises the threshold; but does not eliminate traction problems. Not the least because of high engine torque, loss of traction is very real even with LSD. I would not recommend the line of thinking that LSD helps brake wear. Remember that ESP/ETS braking, as one of several countermeasures, aims to slow the mass of a spinning wheel, not vehicle. IMHO, LSD is a must in heavy and powerful vehicles like the E63. I am glad that all (facelifted) E63 S-models come with an excellent LSD included. Was not the case with the P30 Performance package MY12-13 in the US market; needed stand-alone option 471.
Bottom line: I would not worry about brake wear from ESP/ETS. An academic concern.
$78.90 EBC Redstuff Front, p/n DP31939C
$129.99 EBC Redstuff Rear, p/n DP32117C
from rcagarage.com
$839.99 Brembo Rotors, Front + Rear Set, p/n BBHN-57087-168-1534416 (p/n 09.9764.23 + 09.A822.11)
from Newparts.com (call them for additional discount)
This is an excellent quality low-dust combination for my driving needs. For all the advantages of Girodisc (they are top shelf, no doubt), I could not justify their cost $2,350, which is 2.8 times the Brembo parts. The difference is close to fund a TCU tune, for example.
Regarding rotor mating, they speak of the grooving wear, which degree shall be examined per axle. New pads over old rotors quickly align and work just as well in most cases. Good luck whatever makes sense for you to do.
