RENNtech Tune
I have a stock 2015 E63S with the M157 engine. I am wanting a little more throatier exhaust note and am considering a RENNtech tune to achieve it. I am not interested in a lot of crackling, popping nor a constant overly loud exhaust sound, just a little huskier than stock. I'm planning on the ECU tune and then either the RENNtech downtubes and/or the RENNtech mufflers. I'd appreciate any comments from those who have experience with a RENNtech tune. Of particular interest is downtubes versus mufflers - one or the other or both? I notice that the RENNtech Stage 1 tune includes their mufflers but not the downtubes.
Their mufflers as mentioned above arent loud and change the tune mostly. I think a R1 pack with their catted downpipes would be nice package. I dont believe they support or will make a tune for a complete catless downpipe any longer if you wanted even louder, only catted but I may be wrong.
"Our performance downpipes replace the restrictive stock exhaust with high flow, 200 cell sport catalytic for improved performance, greater exhaust gas volume and better sound.
Combined with RENNtech's ECU software, our downpipes create an incredible sound with performance to match.
Our downpipes mate perfectly with the stock Mercedes Benz AMG exhaust system and include all necessary mounting hardware and clamps. High strength 304 stainless steel construction with high flow, 200 cell catalytic ensure lasting quality and a rich, consistent sound."
So you're right in that they are catted and they at least suggest that the exhaust note will be improved. It was this description that led to my initial plan of getting the downpipes together with an ECU tune.
My local RENNtech installer also suggested, that since this plan would greatly improve the exhaust output capability, I should also add a high performance air filter to improve the air intake capacity to match (although the RENNtech CF airbox is quite pricey, but there are alternatives).
RENNtech downpipes
On the AWD cars, the front sub-frame(at the least) must be dropped, but most people just drop the subframe/eng/trans all together to get it done.
On RWD cars, the Bridge Pipes can be installed with the motor in place.
I'm planning on doing the R1Package (which has the 638 HP ECU tune) together with the RENNtech downpipes in February.
