Help spark plug indexing
Why does MB insist on not building robust ignition systems??
How many old-fashion details are used against basic performance..??
- Adjustment Tips: For normal physical phenomena, some spark plugs electrode will spring back when adjust the gap. You are suggested to use 0.028in feeler gauge size if your desired gap is 0.03in, smaller scale than the target gap is recommended
is this common knowledge or do I stick with gap as marked?
Gap doesn't spring back open right away, it takes countless heat cycles for steel to exert its shape memory.
What we want is a consistent spark rather than a long spark once a while.
So what you want is to under gap a hair knowing in 10kMi your plugs gap will have slightly widen into spec instead of out of spec already.
Make sure you do not drop any plug to the floor while gapping. If a plug falls down, don't use it! Work on your plugs over a table prior to installing.
You won't have to revisit for another 50kMi or so. Hopefully the coils and boots will get the benefit of normal engine heat level.
Having a trusted ignition is a solid base for engine performance.
-- Small lean misfire are laggy weaknesses
-- Heavy ones are complete stumbles with injector off.
-- And every strength in between!
"No fault code" is still ****-poor performance.
You best be far away from the misfire territories.
>> HERE IS HOW TO GET THERE:
-- Step No 1: ALL reliable ignition components.
-- Then you get good TIMINGS (MOD-4)
-- Then ECU rewards you with good MIXTURES
-- Then you have strong CONTRIBUTIONS.
= Great Mercedes ownership: nice & easy!
