charge pipes removal m157 m278
Old Jun 29, 2021 | 06:46 AM
SL14NTP's Avatar
SL500 R231
hello guys, does anyone know or has a thread for removing the charge pipes from the engine? i have the parts to add meth and i need to remove them to add the adaptors for the nozzles. thank you
Old Jun 29, 2021 | 08:56 AM
kenneyd's Avatar
poop
It's only a bolt and two hose clamps per side, however it is an extremely frustrating and difficult job lol.
The issue is they're just not a lot of room to work with the fan assembly being in close proximity, and the attachment at the actual turbo inlet is extremely snug. In fact it's actually spring loaded.
I found that just the awkwardness of your arm position made it very hard to get it off and especially back onto the turbo.
If I was to do it again, I would likely just remove the fan assembly.
I posted a few links from the WIS in this thread, they should get you started. Hopefully other people chime in with some tips
https://mbworld.org/forums/showthread.php?t=816434&goto=newpost
Old Jun 29, 2021 | 09:31 AM
SL14NTP's Avatar
SL500 R231
Thank you very much. I'm trying to save my welder some time. Its gonna take a day if i give him the pipes or just wait 2 weeks for him to do it. Im gonna attempt to do it with a friend of mine thats a mechanic and see where it leads us
Old Jun 29, 2021 | 09:57 AM
BCP's Avatar
BCP
2014 E63s
People have seen better results from meth in places other than the charge pipes, so it may be worth exploring that also.
Old Jun 29, 2021 | 10:01 AM
SL14NTP's Avatar
SL500 R231
Where do you suggest is worth adding the nozzles for the best results?
Old Jun 29, 2021 | 10:38 AM
BCP's Avatar
BCP
2014 E63s
I'll refer to this thread, particularly number 7 in the first post.
https://mbworld.org/forums/w212-amg/...-part-two.html
