Cylinder cylinder wall scuffing with pictures...oil additive might help?
I have a Mercedes m157 engine (5.5liter bi-turbo) in my short commute, daily driven ride. I bought the car with 50k miles with fresh dealer oil. at 55k i changed the oil and put a cheapo boroscope into cyl 5 (known to be the first cylinder to show wear)
and as you can see there is some minor scuffing.(1st image at 50k, 2nd image at 55k) At 55k (1 year later) I did a 2nd oil change. again I did the boroscope and got the 2nd image with notably more piston scuff. I was running Liqui Molly 5w40 leichtlauf. I also ran a mild tune for 4k of the 5k miles. I've now pulled the tune and am sending a sample to blackstone. I'm not looking for magic but if an additive could slow down the rate of damage I'd like to try. I'm interested in the Liqui-moly Ceratec or MoS2. I'm in a colder climate (ny state) and have read that some suspect (mostly porsche owners that seem to be having a cylinder scoring problem) that when cold, the piston warms and expands faster than the aluminum cylinder and can cause this. I've also found more general piston/cylinder info suggesting this is a lubrication issue. I'd welcome any thoughts...Thanks for reading!
The two leading candidate proposed root causes in my mind are failed cylinder surface coating, or failed piston surface coating. Failure of either, or both, of these coatings can lead to exposed aluminum rubbing against a harder surface, and the inevitable (scuffing) is the result.
I am not convinced that more, better or different lubricant can prevent coating failure, if this is the root cause, from happening. To me it's all too believable that MB cheaped out on either the cylinder coating, the piston coating, or both. The coatings are expensive steps in the manufacturing process.
Another potential root cause is that the coating process for cylinder #5 had a problem in the manufacturing process. This type of thing happens every day in manufacturing. It could be the thermal environment of the coating machinery when cylinder #5 is being coated is suboptimal. Same line of thinking can be used for the engine operating environment. Cylinder 5 could see just the right (wrong) combination of coolant flow+temp, oil flow+temp and mechanical stresses that the coating fails over time.
Because cylinder #5 seems to be a common failure point, my thinking is the cylinder coating design or manufacturing process is the root cause of scuffing.
To the original post, a lubricant change may indeed help.
https://media.daimler.com/marsMediaS...e%20attainable.
I'm not familiar with Blackstone's test to know if these would be detected.
I'm wondering if anyone has had this issue on an e63. The car has was never tuned and never driven hard. I didn't even race start it, which is kind of a shame.
this is not a common issue that I've read about, I'm sorry for your frustration. So you've owned it since fifteen hundred miles? So basically new? Certainly it could have been abused by the first owner but to then fail at 38,000 miles is odd.
others will chime in here shortly on how this could have happened mechanically. The m157 does not like short mild trips - it needs to get warmed up and driven hard at times to blow out carbon deposits.
this is a thread perhaps worth reading though it's entirely unclear if it affects you:
https://mbworld.org/forums/w212-amg/...rs-beware.html
Curious if they found oil in your ECU pins or in the engine wiring harness.
Posts like these scare me, especially being tuned. But than I see guys running 10s,chasing 9s, and wonder maybe these cars really do love getting warmed up, getting hot, and getting abused!
This is the reason to avoid M157 and M278 engines if the vehicle is owned without original manufacturer’s or exclusionary (Fidelity) warranty coverage.
Scoring in the #4 will not stop and engine.
Really the only catastrophic failures are then like hydro lock, bearing seizure from oil starvation or literally blowing a rod through the block.
Ive spun a single bearing on chevys, and the oil looks like there's a 5lbs of glitter in the oil... and the motor still turned over.
Im guessing ECU failure or something electrical. maybe even a starter.
where are you?
I’ve taken apart and rebuilt so many engines I’ve lost count. In the 100’s.
To me, those cylinders (in the first post) look like what you’d expect to see on the thrust side of any cylinder with 50,000 miles.
Thrust side always shows some wear on any engine with that kind of mileage. Especially with the cyl pressures seen in a turbocharged engine.
It’s really not that bad….
Now I’m no fan of aluminum cylinder walls and always prefer sleeves, but think there’s a lot of misdiagnosed issues surrounding these MB V8’s (and other MB engines)
Folks should pay attention to leak down tests more than anything else. Borescopes are handy, but you have to have some context. A failed ring or piston skirt will look much worse than that. I think detonation /pre ignition is a bigger danger than anything else. I believe it’s the cause of many failures here on these, and other manufacturers forums. It’s not limited to Mercedes.
I know it’s no consolation to mjhk97, but Autotrader is littered with M157’s and M278’s over 100k miles….
I would verify by getting a second opinion for sure. Also see if you can get pictures of Cyl 4 and post it here. Unfortunately there’s a lot of incompetence in this (and any) industry these days. ☹️
Also, benz has a document with pictures showing acceptable cylinder wall scuffing and scoring, ill try to pull it up and post it here.
You can see that what is acceptable as cyl wall scuffing would make most forum members cringe. Unless you've inspected many cyl wall failures, its easy to get caught up looking for the perfect bore.
The reality is, if you look in the bore of most engines with 50k and more, you'll see some scuffing. Leakdown & Compression is really the preferred method to diagnose a failure. That goes for Aluminum cyl walls or Cast Iron.
The last two pictures of that document show what a true piston skirt/ cylinder wall failure really looks like....
As I said in my earlier post, borescopes are a mixed blessing. Many of the pictures I've seen posted on forums where people claim to have cylinder wall failure/scuffing look like the top two pictures on the last page of the MB .pdf
As far as mjhk97's failure. As I posted above, I would suggest a second opinion for sure. See if you can get pictures of Cyl 4 and post it here.
Here is the attached document for the silitec bores M157:
Just curious, were you the original owner of that SAAB? I ask because odometer readings are not always indicative of actual mileage on engine. i.e. maybe it was replaced
Of course, no one whose engine has failed is gonna be happy they won that lottery, and I would be pissed too...
But tolerance stacking of sorts, i.e. a whole series of events adding up to a failure (think USS Titanic) and manufacturer pushing the envelope on engine efficiency/power and production costs, is what's leading to many of these failures.
It sucks if it happens to you, and I can empathize with those people. I certainly don't want to downplay their frustration.
This is perfectly normal marks for a cylinder bore on any engine. It’s very premature to be thinking this is the start of the dreaded bore score. If you are worried, run liqui molys ceratec with oil changes or use their molygen line of oils with added molybdenum. This will help protect the engine quite a bit.
100% agree here, there are so many misdiagnoses with this bore score that it’s getting a bit silly now. The photos the op posted are exactly what I would expect on a motor when hauling it apart for whatever reason and would think of it as normal markings.
I think we are at the early stage of seeing the effects of sulphurs in North American fuels. Seems to be a lot of concentration on the North American market for this. Honestly I’m seeing it across a lot of brands with all aluminum blocks. Porsche being another with the 4.5 and 4.8 V8 engines and as well as the M97 six in the 996,997 gen 911’s
im new to the merc world having just bought a E550 as a winter beater, but Like yourself I’m not new to engines and have been building them and tuning for most of my life.
looking forward to getting more involved with these posts on the m157 and m278 and putting some ease to a lot of owners minds.
Frequent oil changes, no long idling warm ups and slow routine to operating temp will go a long way.
@PeterUbers take a look at this doc its quite interesting seeing the MB interpretations of the different types of cylinder wall issues which apparently are considered fairly normal!
And we're not even talking about Ethanol issues either
I believe testing of gas after a catastrophic engine failure might reveal some interesting results....That would be a stretch for coated aluminum cylinder walls living with high cylinder pressures.
