Check Engine - Misfire
Old Sep 29, 2021 | 04:00 PM
FireBall's Avatar
2013 AMG E63
I have a 2013 E63 with 95k miles, and it has always been flawless.
About two months ago I noticed a slight misfire at cold start up but would clear up when warm.
On Sunday, the Check Engine light appeared so I assume that it's related to the misfire. I will have it scanned but here are my thoughts...
1) My daily driver, 95% of driving is in manual shift mode, run hard whenever possible.
2) It has always used a lot of engine oil (for the turbos), but always burns clean, no smoke, no leaks.
3) 95k miles on the original plugs, so one or more have begun to foul?
4) Ignition coil(s) or plug wire(s) are failing?
5) Pushed a head gasket (though not using coolant)?
My guess...fouled plugs. What say you???
Old Sep 29, 2021 | 05:21 PM
PeterUbers's Avatar
omg please get new plugs and coils and continue to enjoy your car .. you've been on borrowed time for 20-30,000 miles!
Old Sep 29, 2021 | 05:28 PM
Savage212's Avatar
2014 E63 AMG wagon
I'd at a minimum start with plugs. I replace mine (plugs) every 20k miles or every year whichever happens first. I also did coils @50k miles.
Old Sep 29, 2021 | 06:06 PM
kponti's Avatar
E63
Do both coils and plugs, make sure they are indexed!!!
Old Sep 29, 2021 | 09:23 PM
Mojo20032004's Avatar
2014 E63S
Surprised you haven't misfires alot sooner.. Change the plugs and coil!
Old Sep 30, 2021 | 10:49 AM
PeterUbers's Avatar
Never Replace plugs or coils, he runs it hard as often as he can, and it's been flawless for him this is a testament to the engine, the m157
OP you owned it since new? I've owned mine since new as well
Old Sep 30, 2021 | 02:42 PM
FireBall's Avatar
2013 AMG E63
I'm the second owner, bought it with 37K miles in 2017. No issues at all since I bought it.
Old Sep 30, 2021 | 02:43 PM
FireBall's Avatar
2013 AMG E63
Thanks to PeterUbers, Mojo20032004, kponti and Savage212 for the responses and info, very much appreciated.
I just removed the engine cover and air cleaner boxes to access the job of replacing the plugs and coils. The mechanical work needed is beyond my knowledge and ability.
I predict a costly repair bill in my future...
Old Sep 30, 2021 | 04:00 PM
mbwillgrubs's Avatar
2013 CL 63, 2002 E 55, 04 Jaguar XJ8, 66 Jaguar XKE
It is not that bad of a job. I have a CL and it was all reasonably accessible. The spark plug boots were snug but the right tools made the job straight-forward. If you don't want to do it get a recommendation for a good independent service center and it should not be too bad a cost. Couple of hours max.
Old Sep 30, 2021 | 04:15 PM
FireBall's Avatar
2013 AMG E63
Thanks for the info, that's good news.
Are there individual coils for each plug?
Old Sep 30, 2021 | 05:50 PM
Yes, one coil per plug.
Old Oct 1, 2021 | 12:18 PM
PeterUbers's Avatar
Old Oct 1, 2021 | 12:19 PM
PeterUbers's Avatar
$400 + $200 for plugs and coils and install from a good Indy who knows how to index plugs
Old Oct 1, 2021 | 12:20 PM
PeterUbers's Avatar
https://mbworld.org/forums/w212-amg/...s-vrodman.html
Old Oct 1, 2021 | 03:49 PM
NoVAe63s's Avatar
2016 E63s
So where do I get the flaccid ***** extension? Can I just take my regular ones and dunk them in cold water??
Video was super helpful, thanks for sharing.
Old Oct 1, 2021 | 03:58 PM
2014 E63S
I have a friend in Miami who can do this work for u and index them correctly as well. Pm me if you are Interested I will get you his Info and shop
Old Oct 2, 2021 | 01:11 AM
vdubpower's Avatar
i drive them all, fast and hard
ive had mine since new...been a while since ive posted much here...been building my amg tribute 500sec over on benzworld mostly
anyways, 2012 car with almost 80grand miles... never had misfire...yet. I think i did plugs not coils at 60000
never drive in manual mode...usually S plus in sport but i have been turning esc off too...otherwise its in C for around town
I just need it to start and stop with out issue as its my almost daily. Still no tune...no need
Old Oct 3, 2021 | 01:14 PM
FireBall's Avatar
2013 AMG E63
Nice video, thanks for sharing. The work appears to be more reasonable after watching the video.
Old Oct 3, 2021 | 02:16 PM
FireBall's Avatar
2013 AMG E63
I started this post about my E63 with a misfire and check engine warning, last week. At 95k miles, I believed that it was fouled plugs, and you guys suggested replacing the coils too, which seemed reasonable at that mileage. I watched the video that PeterUbers posted, then checked with my MB dealer for parts and labor ($24.50 per plug - $105 per coil - $800 labor = $1,836), and I contacted a local repair shop that suggested it may be a blown head gasket. So I decided to remove the engine cover and filter boxes again to get second assessment of the job. I also checked the air filters that I had replaced in 2020, they were covered with a lot of dead bees, bugs and dirt/pollen (I don't recall running through a swarm of bees). I vacuumed both filters, reassembled everything, purchased two new filters, returned home and installed them.
The check engine light is now off, no engine misfires detected, and it runs very strong again. Obviously, a combustion engine needs a lot of air to run properly, especially the m157. I spent $50 for two air filters and fixed a misfire problem. I was prepared to spend $1,036 on parts alone, and possibly $1,836+ at the MB dealer. I did not have it scanned so that may have identified the air filters as the problem, but I'm not sure if that is a detectable error. Anyway, a very interesting lesson for me...
Thanks for all of the comments and suggestions, very much appreciated! You guys saved my a lot of cash...
Old Oct 3, 2021 | 04:45 PM
PeterUbers's Avatar
Misfires can sporadic -- pay attention to the codes - misfires are devastating on this engine - go ahead and replace the coils and plugs
Lifetime warranty with free replacement
Old Oct 3, 2021 | 05:36 PM
2014 E63S
Not to mention the old coils are super skinny and are pretty flimsy compared to the new revision ones they have.
