Broken turbo cooling line
I have a 2014 E63 wagon, and, to make a long story short, the coolant feed line 2782000200 that feeds coolant to the drivers side turbo has failed. The plastic fitting that goes into the water pump has broken off, for reasons unknown.
Drove the car home from work, all was normal, get out of the car to go inside, smell coolant, pop the hood, coolant everywhere but, can’t tell from where. Started the car, coolant light comes on (finally) put it up on ramps, can’t find the leak. Fill it back up, still not finding the leak. I took the belt off, the water pump was extremely tight, so, I assumed that was the issue, started tearing it down to do the water pump, and then when I took the cap off the system, to drain it, that’s when I noticed the leaking turbo line.
my two questions are this: Can that line be changed without pulling or lifting the motor for access, and what else should I do while I’m in there?
I figured I’d do the pump, the thermostat, the 4 turbo water lines (if I can get the other 3 out), and clean out the heat exchangers and straighten the fins, since all that front bodywork has to come off anyway to do the pump and lines.
If you so much as look at the remainder of the coolant lines, they will break.
I can't speak to the install, only based on my experiences.
They say if you change one your should change them all or I'll likely be back soon doing another. I wonder if any are accessible and could possibly be done without the huge labor hit? They didn't tell me which was leaking.
Decided to do a a bunch of service, to include a coolant flush. Went ahead and pressure tested my coolant system and guess what suddenly appeared. Better on the lift in my garage than on the road. Still annoying.
my guess is quite a few.
absolutely shameful design flaw on a $60k motor in a $100K+ vehicle. The real kicker in all this too is that the passengers side lines are all metal. There is, as far as I can tell, no reason for the plastic on the drivers side lines, other than to provide flexible lines for clearance to do the water pump, but, if you’re in it that far to do a water pump, you’re going to do these lines anyways because they’re plastic, so who cares!
if you do this little activity, don’t stick the screwdriver or other straightener in any further than you need to, as the fin material is actually louvered between the tubes, and sticking it in too far damages those tiny louvers. While not perfect, holding the shop light behind them, I could only see light through about 65% of the heat exchanger, and now I can see through about 95% of it.
I tried a few different tools, including a fin comb, and that little flat blade screwdriver and lots of patience seems to work the best, along with blowing them out from behind with an air hose as I moved along.
the leaves behind the oil cooler had been riding around in that pocket for so long that there was about 1 1/2” of mushy “leaf mud” where they had started to decompose!
I ordered the MB OEM “blue” coolant for the intercooler, and am planning on using the Zerex G-05 for the engine coolant. I assume the G-05 still meets the OEM specifications for engine coolant?
Knock on wood, no leaks so far. Will keep a hawk eye on the coolant tank for the next few days, but I think it was a successful job! It even feels a bit quicker, probably from the straightened cooler fins, or maybe it’s just all in my head after driving my wife’s Alfa for a 2 weeks, the Merc feels like a rocket ship.
