Time for Brakes 2016 options
Old Jan 19, 2022 | 02:35 PM
I.T. Guy's Avatar
2023 E63S Wagon
Well it's time for pads and rotors, all 4 corners on the E63S Wagon.
Dealer is CAD$2500 front and CAD$1400 rear = CAD$3900 (about USD$3100)
What are all the cool kids doing?
Old Jan 19, 2022 | 02:50 PM
berti_00's Avatar
2016 Cls63s AMG
Fcp euro rotors
I got fronts brembo 2pc
Rear Zimmermans
Powerstop pads all around. Zero dust
Old Jan 19, 2022 | 02:51 PM
berti_00's Avatar
2016 Cls63s AMG
Rear don't come black I did it to match the fronts
Old Jan 20, 2022 | 08:45 AM
Mojo20032004's Avatar
2014 E63S
I too went with 2pc Brembo from fcp, remember lifetime warranty, so in 30-40k get a free set again.. Ebc red brake pads
Old Jan 20, 2022 | 10:02 AM
I.T. Guy's Avatar
2023 E63S Wagon
Any other options? Looking for cheap but don't want to rag it out either. I don't track but do use the brakes 240kph+ occasionally.
Old Jan 20, 2022 | 11:45 AM
bdubs's Avatar
Current: 2018 E63 Selenite Wagon (700hp/850tq) Prior: 2016 E63 Selenite Wagon (670hp/830tq on E30)
I just had full brake service done on my 2016 E63 wagon. I was about to go down the route of others - 2pc Brembos from FCP with the lifetime warranty, and then EBC red brake pads. Ended up talking with a local shop owner who owns several AMGs and races some...he tipped me off to moving away from the 2pc setup in front and using 1 pc C63 rotor that fit perfectly (and that he had done several times before on E63s).
And, if it makes a difference, the owner is "master certified with Mercedes-Benz and Maybach/McLaren SLR"...so I trusted his recommendation/advice.
All in, with them doing the work, I spent just under $1,400 for all four corners - rotors, ceramic pads (not EBC), and fluid flush. And I can't tell a difference and they still look badass enough when standing beside the car, lol.
Front rotors were only $136.99 each. Rears were $107.99 each. Pads were $130.99 front and $66.99 rear. So for under $800 parts, if doing the work yourself, you can have new brakes all around.
Unfortunately, the invoice doesn't have the part numbers on them...I can probably get them if you can't find them online but would have to go back to the shop owner.
A pic of the C63 rotor by an E63 rotor is below.
Old Jan 20, 2022 | 12:55 PM
I.T. Guy's Avatar
2023 E63S Wagon
How much do the FCP Euro rotors weigh?
EDIT 29.1 lbs found here https://www.brembostoreusa.com/produ...mbo-09976423-n
They are now almost $500 a pop https://www.fcpeuro.com/products/bra...mbo-2194210212
for slightly more at $600 a pop I can just get Girodiscs and save 10lb per side https://www.girodisc.com/Front-Rotor...MG_p_6606.html
Stock 34.5 lbs (still googling to verify this)
Brembo 29.1 lbs
Girodisc 23.6 lbs
Old Jan 20, 2022 | 01:13 PM
I.T. Guy's Avatar
2023 E63S Wagon
Interesting I found the same Brembo brakes here for a lot cheaper but this site says they will not fit
BRE-09976423 part number on both sites:
https://www.eeuroparts.com/Parts/450...60mm-09976423/
Old Jan 20, 2022 | 03:30 PM
bdubs's Avatar
I really wanted to go with lighter weight / non OEM rotors...but in the last month I'm $4,000+ into repairs on my 2012 A4 Avant my son is driving. Combo of driver error lol and then a multitude of issues that were triggered by the alternator ferociously dying. When I had the chance to save some dollars and likely feel no seat of the pants impact, I jumped at it.
I guess it's nice to have an $800 option or a $3,000 option, lol...
EDIT: Also...those Girodisc are what I really wanted; if I was going Brembo I would have likely swapped to those. But you truly can't beat the FCP Euro replacement policy IF you are going to keep the car long enough for another set of rotors. But dang if those Girodiscs don't look awesome...
Old Jan 20, 2022 | 05:55 PM
threeMBs's Avatar
Only MBs - the best or nothing
Originally Posted by berti_00
Fcp euro rotors
Rear Zimmermans
Yes they do not dust, but how do they stop the car? Why Z16 and not Z23 compound? FF friction as shown above indicates to me these are not high performance pads, I believe stock is GG (much gripper both cold and hot).
Old Jan 20, 2022 | 09:41 PM
berti_00's Avatar
2016 Cls63s AMG
man nice catch.. I am going to return them all.
I just ordered front z26 and rear has z23 only so.. thanks man
Old Jan 21, 2022 | 09:20 AM
threeMBs's Avatar
Any particular reason PowerStop pads were chosen over EBC Redstaff pads?
Old Jan 21, 2022 | 10:18 AM
berti_00's Avatar
2016 Cls63s AMG
They seem to have excellent reviews and the dust is almost none existence
Old Jan 21, 2022 | 12:40 PM
AMGfifty5's Avatar
05 C55-gone 06 E55-gone 15 P85D 14 E63 S 11 Sonata 😅
I recently went with brembo discs and ebc red stuff all around.
Old Jan 21, 2022 | 06:55 PM
I.T. Guy's Avatar
2023 E63S Wagon
So I can get Girodisc all four corners and their Magic Pads for 12% off list
My friend can get me stock replacement stuff (not oem) wholesale for just under CAD$1500 all in including sensors
I’m going to sleep on it THEN GET THE GIRODISC!!!
Why?!
Everything needs to be lighter.
It is the way.
Plus I love this car. She deserves it. Just back from a platinum detail:
Old Jan 22, 2022 | 11:08 AM
threeMBs's Avatar
Once installed, please let us know how they stop the car both when full force is applied and especially their initial bite (the fact that initial bite will be diminished is unquestionable, just to what degree is the question).
Old Jan 22, 2022 | 02:51 PM
Jonny English's Avatar
2019 W213 E63s AMG
The Z16's which I recommended for the rear are perfectly good in my experience over the last 6 months. The heavy braking is done by the front pads. I used TRW low dust at the front. My E63 pulls up just fine from speed.
Old Jan 25, 2022 | 09:55 PM
thesaintusa's Avatar
2019 911 GTS / 2016 X3 / 2015 E63s / 1993 RX-7
Nice.
Brakes / rotors and pads = DIY job. Even buying the tools needed is a fraction of the cost of labor.
