2013 E63 rpm jump/acceleration stall
Old Mar 16, 2022 | 12:55 AM
KP916's Avatar
2007 E63
Sorry if the title is confusing I don’t know exactly what word to use to describe it but when I put the car into reverse or drive and try to accelerate the car jerks back and forth for a second or two and the rpm bounces up and down then it drives. I want to say it feels like a clutch issue but at this point I’m not sure. I have no error codes in the engine/transmission/shifter or anywhere. It’s not a hot/cold thing as it happens always even if the car has been running. It happens in C/S/S+/M. I’ve browsed many forums and I’ve tried brand new spark plugs and I did a wet clutch adaption. No help. I took it to dealer but OF COURSE they can’t create the problem so they can’t see what it is. They looked for a software update for the tcu but there wasn’t one. Besides this the transmission shifts beautiful through all the gears up and down, just the take off is an issue. When I say take off I don’t mean I’m flooring it, easy gas pedal acceleration like a normal drive, if anything I would say it doesn’t happen on a floored take off. I really want to say it’s the wet torque but would my rpm jump if it was a transmission issue? Any help would be greatly appreciated
Old Mar 16, 2022 | 01:30 AM
PeterUbers's Avatar
How long have you owned the MCT based vehicle?
If the Mct is new to you then likely it's working fine you just need to learn to feather the throttle like a manual trans clutch
a leak in the manifold can also do this ...
Old Mar 16, 2022 | 02:00 AM
KP916's Avatar
2007 E63
not gonna lie it’s my first one, could this really be normal? Also would a leak throw a engine light or no?
edit: to answer to the feathering the throttle, this happens if I put the car in drive and don’t press the gas at all too just let go of the brakes.
Old Mar 16, 2022 | 01:09 PM
PeterUbers's Avatar
manifold leak won't necessarily throw a code
can you upload a video of the tachometer while it does this as you idle in drive? Your situation does not seem normal
have you sat with the tech during a test drive to have him explain why this is normal for your car? Often they change their tune when you go for a drive with the tech
Old Mar 16, 2022 | 01:17 PM
KP916's Avatar
2007 E63
I tried to get a video last night actually but was unsuccessful I’ll try again today and no I didn’t get a chance to sit with the tech and I don’t want to take it back because they charge way too much for a visit only to not find anything. Going to do a smoke leak test today see if I can find any leakage in the intake system. Do you think if this was solely a transmission issue the rpm would bounce? Is rpm not read off the flywheel which would come from the engine only? Or am I wrong
Old Mar 16, 2022 | 02:00 PM
PeterUbers's Avatar
unfortunately I don't know ... you said you had an Mct wet clutch re adaptation?
Old Mar 16, 2022 | 02:36 PM
KP916's Avatar
2007 E63
yeah I did.
Old Mar 16, 2022 | 04:22 PM
RVAE34's Avatar
S212/M5T/Z31/240Z/3rd gen Tacoma
If it only does this before the car gets up to normal temperature, it's typical. You need to feather the throttle for the first 5 minutes or so of driving. Once it gets up to normal temp, it will go away. I believe it's because the car starts in 2nd gear unless in Sport + or M mode. I sometimes put it into M and start in 1st. Just don't get on it before getting up to temp.
Old Mar 16, 2022 | 04:33 PM
KP916's Avatar
2007 E63
well as I mentioned in the original post this happens in any drive mode including S and M and also happens long after the car is warm, if I go for an hour drive it’ll happen the entire hour it doesn’t go away with heat. Don’t mean to sound rude I know you’re trying to help but I already addressed everything you said in my original post. Whatever is happening isn’t normal because sometimes the way it jerks is so hard I go back and forth in my seat
Old Mar 16, 2022 | 05:22 PM
PeterUbers's Avatar
Some thoughts
https://forums.mercedesclub.org.uk/i...m-cold.154978/
Old Mar 16, 2022 | 05:42 PM
KP916's Avatar
2007 E63
looks great and basically same as my problem but I took it to dealer for software update they said there was none for my car
Old Mar 16, 2022 | 09:16 PM
JimFE's Avatar
2022 A220 4Matic
I'm glad I read this thread. I'm two months into ownership of a 2014 E63, and was wondering if it was normal I wasn't TOO concerned, since I have an SLK55 with the 5 speed, and it downshifts into first hard until it warms up. Again, typical of that transmission.
Old Mar 17, 2022 | 01:49 PM
KP916's Avatar
2007 E63
Here is a video, I will try to upload more I got a few videos on it today sorry for the shaking in the video it’s hard to hold the camera still when I’m being rocked back and forth in my seat because of it
File Type: mov
Old Mar 17, 2022 | 01:50 PM
KP916's Avatar
2007 E63
Another one
File Type: mov
Old Mar 17, 2022 | 01:57 PM
PeterUbers's Avatar
Thanks for the videos
what happens if you mildly brake torque/stall and launch ... still the hesitation?
i suspect this is a wet clutch engagement issue as the rest of your rpm's and shifts are good right? Under any throttle load?
Old Mar 17, 2022 | 02:07 PM
KP916's Avatar
2007 E63
do you mean like a launch control type of thing? Any sort of launching or even regular take off but just pressing the gas pedal slightly stronger and there’s no hesitation, it only happens at a normal take off at low rpm’s like in the video. Besides this all 7 of my gears up shift and down shift work perfect and beautifully, it’s just this initial take off issue. I suspect a mct issue as well and I did try the adaptation which didn’t help. I do have an embarrassing confession and that is that I have not checked fluid yet. I plan on getting around to that this week but I don’t suspect fluid being an issue because there are no leaks underneath it’s very dry, so where would the fluid have gone? Unless someone before me did a flush and did the wrong amount? I will be checking fluid and I really hope it’s low so I know that’s the issue
Old Mar 17, 2022 | 02:19 PM
PeterUbers's Avatar
not launch control .. just mash the brake and bring rpm's up and then let go of brake
but did you do a tech Mct adaptation .. that takes several hours, thanks to @sunil517 for this
https://mbworld.org/forums/w212-amg/...r-service.html
Old Mar 17, 2022 | 02:43 PM
KP916's Avatar
2007 E63
I wouldn’t say hours I did it myself with a autel elite scanner took maybe 20 minutes? It definitely did something as I heard the transmission making growling noises and my gear selector was blinking.
I guess I can try another adaptation but at the dealer but I’d be more comfortable checking the fluid first before I go dump money over there
also I just read that entire thread and a lot of people are saying the mb techs have issues with the older mct (like my 2013) adaption vs the newer 2015/2016 so I’m guessing what I’m having is somewhat normal?
Old Mar 17, 2022 | 02:48 PM
PeterUbers's Avatar
i would hate to live with this issue .. car would be sold. What's a new wet clutch/plate cost
Old Mar 17, 2022 | 02:57 PM
KP916's Avatar
2007 E63
the torque is about $500 at dealer for a reman, and the labor id do myself plus fluid and stuff so maybe $800 total but if it’s a common thing in the 2013/2014 model would I really be fixing the issue or just replacing my torque for one that has the same issue? Lmao
Old Mar 17, 2022 | 03:07 PM
PeterUbers's Avatar
One thing you could try is a sprint booster set to green...
It'll amplify even subtle throttle input to hopefully bypass that hesitant take off
https://mbworld.org/forums/w212-amg/...ct-e63s-4.html
https://www.sprintboostersales.com/?...UaArUQEALw_wcB
Old Mar 17, 2022 | 03:17 PM
KP916's Avatar
2007 E63
i appreciate your feedback Peter you’ve been a rockstar for me, but I’m just going to accept this fact I’ve already taught my foot how to take off quicker but not look like an a**hole trying to race everyone so I’ll just keep doing this till maybe I find a newer model and work a sell/buy or trade situation. Thanks for all your efforts. If I ever do get bored and dig around and find a solution I’ll come post it here in case anyone ever finds this thread with same issue
Old Mar 17, 2022 | 04:10 PM
PeterUbers's Avatar
best part of sprintbooster is you can return it, it may be a game changer for you ... $0.02
good luck and enjoy this amazing car!
Old Mar 17, 2022 | 04:33 PM
Bahnstormer's Avatar
2010 E63 AMG, 2003 E500
I love my Sprint Booster, makes a huge difference in throttle response.
Old Mar 17, 2022 | 09:33 PM
sunil517's Avatar
2014 E63s 1993 mazda rx7 on Boost
I experienced first hand
If you are covered take it to the dealer show them my paper work and ask to have those steps to be carried out. Its been some time and no issues. I just did my trans fluid and the pan and filter was very clean my second change at 60k.
I am not sure about battery disconnect on the w212 I think that worked on the W211 63s. A Sprint Booster will work as Peter stated but its not fixing the issue it is covering it up.
