Left Cross Strut Failure.... Again!
Mine was failed at 10k, I've seen them failed with less.
Just replace it with an aftermarket until or track weld it like I show in my you tube video.
same design but apparently, anecdotally, same or better quality than OEM part, which is 4x more $
FYI, should you ever need to warranty their parts, it's done directly through the authorized vendor and not through Mevotech directly. If you buy from an unauthorized reseller, you're boned on your warranty.
Cheers!
Honestly, I'm not averse to ordering a pair and trying them. If you're needing to replace yours, I say go for it. You'll be fine.
I was only half joking when I wrote it, but given how the problem seems to only occur on the driver's side I suspect when the engineers did the math on allowable flex they did it for perfect balance and didn't accout for the driver.
My theory is that during heavy braking, the force from the wheels puts an inward and forward pressure on both control arm bushings. The passenger side pushes towards the taper thus it doesn't fail, however the driver side being opposite, that force causes it to slip off the bushing
