Catastrophic Failure due to oil sensors leak
#76
Removing the oil filter housing isn’t too difficult. It’s hard to see and you may have to remove the fan, but it is certainly doable. You will have the remove the air inlet pipe and thermostat. My thermostat broke on removal. Keep in mind that there are 7 bolts for the filter housing. 5 are the same and the two on the far right (when looking in the engine bay from the front) are different in thread and length. I would get a new gasket for the housing and new o-rings for the lines. I just did this job and snapped a coolant line. Kind of glad I did as it was better to proactively replace them rather than wait until the break.
Tedious job and I replaced the water pump and belt tensioners while I was in there. Just did the coolant feed line on the back of the left cylinder head and that was a challenging job given the lack of room and visibility.
AMGfifty5 (06-06-2022)
#77
13 s212 63 p30. 03 s55amg. 06 LX470
here's the instructions
Thank you guys, I was able to find the belt tensioner. I disconnected the coolant hose and the black plastic in the center of the picture but I can't take this one out. I already removed the 3 crews which connect it to the aluminum end. I don't know what it is. Turbo coolant pipe? Anyway, it won't come out.
scroll down in this thread for instructions. Post 2 has what I needed to get all the way to the cam covers/end caps. (thanks kennyed)
https://mbworld.org/forums/w212-amg/...ck-valves.html
Edited to say crap, were you just trying to remove the belt?
If you wind up removing the thermostat, there is an updated part, so be very careful, don't remove it if you don't have to. The updated part requires a new water pump (this only may be because I have a '13) YMMV. The plastic is brittle and fancy.
dustinN (06-06-2022)
#79
yes it broke. don't wiggle it, use something to help move it strait out (like a thin blade moving around the circumference slowly, I was able to find the part. try to look up the part number first. Post five of the check valve thread
#81
05 C55-gone 06 E55-gone 15 P85D 14 E63 S 11 Sonata 😅
I was scared I’d drop a bolt from the vacuum pump into the abyss
#82
I hear you on that! I pulled the exhaust thinking I could access the bolts from the bottom but no luck. It’s really tight access. I also replaced the oil breather cover as it was seeping a little. Waiting on a few coolant lines now - decided to replace every coolant hose I can access and also put in a CSF front heat exchanger along with PLM side exchangers. Doesn’t seem like they will make much of a difference, but since everything was apart, I figured I may as well. Replaced the radiator as well - could have left it but since it had to come out anyway I decided to replace it. Hopefully, after all this and new plugs along with coils, I should be good to go on maintenance for a while. Just hit 108k and hopefully no issues will present themselves for a while.
#83
I think it's the thermostat. Code7rpd, so you broke it when got it removed? It's kind block access to the oil filter housing screws.
Yes, when I pulled it apart, a few plastic pieces that surround the thermostat broke. The heat really does a number on the plastic pieces. I just pulled the rear coolant feed line valve and it came apart. It was just a matter of time before it let loose. It was a pain to get to, but I’m glad I got it done.
The plastic just deteriorated and it cracked on removal.
Here is what it looked like:
#84
Where did you end up getting the work done? Trying to keep a place in reserve for when I need it.
#85
Code7rpd (06-06-2022)
#90
No
As far as the bolts, either put a phone down there and take a pic or go online and look at the part. I used a phone on video and going in a circle around it. I think I mentioned this issue, that wis was slightly off, as are the videos
#91
if you’re in the area I can send you his contact info.
#92
#95
What are these 2 black lines? There is a screw behind these but I can't move these away, they are not flex and I don't want to break them.
#96
2014 E63 AMGs, 2015 F-150 Lariat, 2010 Porsche C4S
#97
Those are the infamous turbo coolant lines. Be careful moving them. Depending on your mileage, they may be brittle. You will have to loosen the clamps to give you enough room to maneuver the oil filter housing out. Not sure if you will need to disconnect the bolt that holds it into the water pump. You may have enough wiggle room the slide the filter housing out.
