1991 964 Turbo, 2002 Black E55, 2002 Black E55 " The Beast"- 2014 E63s
Carbon Ceramic brakes weight vs Steel brakes---- Verdict is in
Prior to purchasing the Ceramic brakes, I googled and Googled and googled about their weight differences but no one has made any posts regarding that, so here it is.
Both brakes were off 2014 E63s wagons with around 45K miles.
Calipers were loaded with the brake pads and the brake line.
Steel----------------------------------- Carbon:
Front Calipers: 17.6 lbs------------ --------21.6 lbs
Front rotors: 29.8 lbs ------------------------17 lbs
Total Front : 47.4 lbs -------------------------38 lbs
Only the rotors have "rotational" mass...Hopefully.
Carbon calipers are heavier actually so the rotational loss is even more, the total loss is 40 lbs because the adding of mass from the calipers so really it's 44 pounds of rotational mass lost.
I believe they're somewhere around $8,600 all around with pads. Fronts $4,500 w/ pads.
I'll probably order a kit once my steel rotors need replacements.
If you're from the DC area, and go to Katie's C&C a fair amount, you'll know his Jeep and Caddy. The attention to detail is amazing. The Jeep is 900+whp, all about lightweight mods inside. It's incredible sounding and awesome to hear. Insanely fast.
For around 9 grand, you could easily pick up a used set of whole CCB package ( calipers/rotors/shields) and don't need to compromise on smaller brakes and being a poser with painting the calipers gold either. At $8400/rotors, that ain't cheap for sure.
Good luck finding a full mint set with low miles for $9K lol Those are unicorn type deals that maybe pop up every once every 10 years. New complete sets are $20K+.
Most of the weight savings come from the Carbon rotors anyways and you'll get even more weight savings with factory calipers.
