ECU went bad
Old Aug 10, 2022 | 04:22 PM
dustinN's Avatar
09E350, 07E63, 13CLS63
ECU went bad
A friend of mine has problem to start the car. The steering and transmission are locked. The tech told him that his ECU is bad and he will need a different one. If he buy an used one off Ebay, does it need to reprogram at the dealer or just plug and play? Anyone know. It's stock, not performance ECU of anything like that. Thanks.
Old Aug 10, 2022 | 04:25 PM
PeterUbers's Avatar
Question is - why did it go bad? Oil in the wiring harness? If so... new ecu will go bad too
yes you can get eBay ecu and tuner can clone it; dealer likely will not do this for you, they will sell you a new one
Old Aug 10, 2022 | 04:31 PM
dustinN's Avatar
Oh, it's not M157 car so it's not the oil leak on wiring harness. . It's just an old 2008 E350. So he will need a tuner to clone it?
Old Aug 10, 2022 | 05:19 PM
lampeater's Avatar
'14 E63S, '00 E430, '07 C230
Like stated, he will need the ECU to be cloned cause the dealership will only sell you a new one.
Old Aug 10, 2022 | 05:25 PM
dustinN's Avatar
Thank you all.
Old Aug 10, 2022 | 06:07 PM
PeterUbers's Avatar
Ams in west chicago can do this for you
also Eurocharged Austin Texas
and still .... check for oil in harness even if e350
Old Aug 10, 2022 | 09:19 PM
GinDistiller's Avatar
2019 M5 Comp, 2005 Ariel Atom 2
I'll just throw this out there, we had the transmission lock out of our GL (722.9 transmission) and it turned out to be a bad battery. I would think they checked that, but you never know! ECUs don't go bad very often in my experience... best of luck!
Old Aug 10, 2022 | 09:23 PM
PeterUbers's Avatar
if it's the dealership you're giving them too much credit for having checked that
Old Sep 12, 2022 | 08:30 PM
dustinN's Avatar
We bought an used ECU with same part number on eBay, sent both in for clone service also on eBay. We received the ECU back today, plugged it in but it didn't work. Got error code 1405 ECU cannot communicate with transmission over CAN bus. Something wrong with transmission but not the ECU?
Old Sep 12, 2022 | 09:01 PM
PeterUbers's Avatar
We bought an used ECU with same part number on eBay, sent both in for clone service also on eBay. We received the ECU back today, pugged it in but it didn't work. Got error code 1405 ECU cannot communicate with transmission over CAN bus. Something wrong with transmission but not the ECU?
try starting with the actual key if you tried push button start .. take button out; insert key and try traditional turn key start; if this works it'll be the only time you need to do this and all should be fine
Old Sep 12, 2022 | 09:18 PM
dustinN's Avatar
Thank you for you help. We used the key to start, not the button. No problem to start, no problem to turn the wheel, just can't shift out of park. :-)
Old Sep 17, 2022 | 08:53 PM
dustinN's Avatar
I found a YouTube video on how to override the shifter so at least the car is now drivable. Problem is it won't shift out of 1st gear.
Old Sep 17, 2022 | 11:27 PM
PeterUbers's Avatar
Sounds like your tcu is problematic as well - why do you think the ecu went bad?
Old Sep 18, 2022 | 12:10 AM
dustinN's Avatar
I don't know. Some people had similar problem and resolved by replaceing the ECU. I'm going to replace the TCU next. I guess I would do the same as I did with the ECU? Buy a used TCU and clone the data?
Old Sep 18, 2022 | 12:35 AM
PeterUbers's Avatar
Try a tcu reset first; did someone install a battery with the wrong polarity?
Old Sep 18, 2022 | 07:29 AM
dustinN's Avatar
I will search for TCU reset. It's not a battery from Mercedes and it was installed over a year ago. Everything woked just fine until now. Thank you for your help.
Old Sep 20, 2022 | 02:13 PM
dustinN's Avatar
So I tried to reset TCU, replace some of the fuses, replace brake light switch. None of these work. It's time for new TCU and data cloning?
Old Sep 20, 2022 | 02:22 PM
PeterUbers's Avatar
No idea, can you consult a qualified benz tech? Seems like it's time
Old Sep 20, 2022 | 02:24 PM
TCUs should be interchangeable in the W211 unless it changed after 2006? So I don't think they require cloning. Don't the shifter assemblies go bad in these? I had mine for years and never ran into a problem, but if you needed to 'unlock' the shifter maybe that's the issue. I'd look around the W211 forums.
Old Sep 20, 2022 | 02:26 PM
dustinN's Avatar
Just made the appointment with MB dealership. $215/hr for inspection. Thank you for your inputs.
Old Sep 20, 2022 | 02:40 PM
dustinN's Avatar
It was locked in P. I was able to unlock and drive around but it won't shift out of 1st gear. Thank you.
Old Sep 20, 2022 | 02:58 PM
PeterUbers's Avatar
let us know what they say
Old Sep 22, 2022 | 01:03 PM
dustinN's Avatar
Mercedes won't replace just the TCU/TCM. They want to replace the whole valve body/conduct plate, part # A220270270687. This item is considered a theft relevant part and is not available for purchase online. The cost is $1,268, plus the cost to reprogram, and around 4-hr labor, and full transmission service (around $500) for the total around 3k. I'm think of buying a used TCU on eBay and DIY. I already asked Joe (Valvestud) for instruction to install it. If I can't do this myself, maybe an indy can do it for less.
P.S. Does anyone know the correct part# for the TCU?
Old Sep 22, 2022 | 05:00 PM
PeterUbers's Avatar
what year and model is your vehicle
your issues is probably the valve body it's a common issue for 722.9... but if it's not cost prohibitive and you can do it I guess it's reasonable to replace the tcu though I've never read much on people doing this ... it won't be easy I don't think presuming 722.9 trans
https://mbworld.org/forums/c-class-w...-replaced.html
Old Sep 22, 2022 | 05:51 PM
Valvestud's Avatar
2014 E63 AMGs, 2015 F-150 Lariat, 2010 Porsche C4S
[QUOTE=dustinN;8639321]Mercedes won't replace just the TCU/TCM. They want to replace the whole valve body/conduct plate, part # A220270270687. This item is considered a theft relevant part and is not available for purchase online. The cost is $1,268, plus the cost to reprogram, and around 4-hr labor, and full transmission service (around $500) for the total around 3k. I'm think of buying a used TCU on eBay and DIY. I already asked Joe (Valvestud) for instruction to install it. If I can't do this myself, maybe an indy can do it for less.
P.S. Does anyone know the correct part# for the TCU?[/QU
A0002702600
A 000 270 00A 000 270 26 00
