18" wheels on AWD 2014 E63
Old Dec 10, 2022 | 05:35 PM
stroock6394's Avatar
2005 E55 AMG, 1999 Lexus LS 400
looks like it's been some time since this has been asked but just wanted to see if there's any updates
from my reading it seems like 18" wheels will not fit properly on the front of an AWD E63, has anyone had success in doing so? the rears fit just fine but in the front there's huge dust covers that just scrape on the inside of the rims
as i understand mercedes made these for markets outside north america, but even if wheels of those same specs were located will those huge dust covers still create a problem? is there anything to be done about the covers themselves?
thank you in advance for any advice
Old Dec 10, 2022 | 07:11 PM
C2 Turbo's Avatar
1991 964 Turbo, 2002 Black E55, 2002 Black E55 " The Beast"- 2014 E63s
Let me get this right, so you are trying to put 18" AMG wheels that happen to be 25% off on your 2014 E63s, is that correct or is that on your 2005 E55?
Old Dec 10, 2022 | 07:34 PM
not those wheels necessarily, just any 18" wheel that will fit the 2014 E63S AWD model (for a better winter setup)... i was just using that as an example for "allegedly" the correct oem wheel specs, although idk if those are intended to be for RWD only models
and yes not for the E55
Old Dec 10, 2022 | 07:43 PM
PeterUbers's Avatar
In case you hadn't seen this
https://mbworld.org/forums/w212-amg/...-packages.html
Old Dec 11, 2022 | 01:59 PM
read through it... seems like the AWD models have that extra large shield/cover behind the rotor that RWD models don't
does this mean that if that cover were to be modified or removed an 18" wheel will fit ok?
Old Dec 11, 2022 | 02:19 PM
PeterUbers's Avatar
Not sure ...but don't modify or get rid of the splash shield. You'll be the first I've read of someone trying this ... soooooo
Old Dec 11, 2022 | 08:16 PM
AMGfifty5's Avatar
05 C55-gone 06 E55-gone 15 P85D 14 E63 S 11 Sonata 😅
What 18” wheels do you guys run in the 1/4 mile? I thought I read some in the Go fast thread are on 18” ET streets…
Old Dec 12, 2022 | 08:28 AM
PeterUbers's Avatar
I haven't seen that for awd models ...
Old Dec 26, 2022 | 08:21 PM
log's Avatar
log
2014 E63S
The shield isn't the only clearance issue. That socket OD is just under 1/2" (.47ish if I remember right) and that's a stock 10 spoke wheel.
Does anybody just run taller tires for pothole season?
Old Dec 27, 2022 | 08:50 AM
BCP's Avatar
BCP
2014 E63s
I believe they only run them on the rear...
Old Dec 27, 2022 | 04:53 PM
AMGfifty5's Avatar
m
yeah which 18s will fit any 2010 and up w212?
Old Dec 27, 2022 | 05:49 PM
maxusa's Avatar
2013 E63 P30, 2010 GL550
I downsized to 18" AMG wheels 2 years ago. Sourced from Europe. Here is my research for pre-facelift front fitment. My post has the OEM 18" and 19" wheel measurements. The 18" wheel clears the front caliper, cover/shield, and steering link by 10-11mm on a pre-facelift W212 (the wheel flares out slightly). Hope this helps.
Fitting 18 inch wheels on a 2012 AMG Wagon?
As far as I can tell, the front 18" AMG wheel A2124014302 does not fit AWD W212/S212.
