2014 - Front Differential Service
Old Mar 28, 2024 | 04:40 PM
Red Bull's Avatar
'06 SLK55, '14 E63S Estate
Not a believer in "lifetime" fluids
I'll add that I replaced the front diff fluid about 3 months ago, at round 98k mi. I had an axle out to replace a howling intermediate shaft so figured why not. I will say that fluid looked terrible! I'm glad I did it. And since I'm going to have an axle out here shortly I'm going to do it aagain, For maybe $60 in fluid (if using the expensive Castro stuff they sell by the .5 liter)it certainly cannot hurt
Old Mar 28, 2024 | 09:26 PM
Mojo20032004's Avatar
2014 E63S
I got quoted by a reputable mb shop in Chicago 750 for this service, including new axle seal. Remove axle, drain,fill,replace axle seal and reinstall.. Hefty indeed..
But then again they also quoted me 800 to install kw lowering springs 😭.. Diy everything for life!
Old Apr 1, 2024 | 07:58 PM
jvakos's Avatar
E63 SL55 996TT C5Z06
@Mojo20032004 - I’m in chicago also and am DYING to find a new solid MB Indy shop to service my 15 E63. Fletcher Jones MB chicsgo charged me $400 to service my rear diff last year and part of that cost was $120 for the new 2 bolts for drain and fill!!!
let me know if you found a good MB Indy shop in Chicsgo or surrounding suburbs?
I used to take my car to Loeber MB when it wa sunder warranty because my guy Rudy was the MB master tech there but he left just as my warranty expired so I’ve started doing basic stuff on my own since I don’t trust dealers
Old Apr 1, 2024 | 08:24 PM
2014 E63S
I do 95% of my own work, but just hate lifting the e63 above my head. But today the new quick Jacks arrived so il be doing the front diff myself. I also did the rear diff and trans last summer on jackstands and it was a pain ughh
Old Apr 2, 2024 | 12:28 PM
Red Bull's Avatar
Front diff: 75W85 Mbz fluid
After several dealer calls/visits and a few different answers, I've settled on MBZ P/N 001-989-33-03-09 (75w85) as the correct fluid for an E63S front diff. .6L seems like the agreed-upon amount of oil.
Hope this helps
Old Apr 2, 2024 | 03:51 PM
cold bud3's Avatar
2015-E63S | 2012-C300
Easy
I do all my own maintenance, I got quickjacks, youtube and laptop with merc diag soft from BenzNinja. I strongly recommend to get up close and personal with your amg or pay the $200 per hour for mechanic fee.
Old Apr 3, 2024 | 04:54 PM
  #32
OldManAndHisCar's Avatar
W212 E63S Wagon - GSL580 - E63 - E350 - C300
LIES! There is no reputable Mercedes shop in Chicagoland...north of the Cheddar curtain, maybe. Chicago to Rockford and south to Peoria...nope.
Old Apr 3, 2024 | 04:56 PM
  #33
2014 E63S
This shop in Lincolnshire, not Chicago, but close enough. Plenty of Mercedes shops around Chicago that work on MB only,but I have never went else where other than the one in Lincolnshire
Old Apr 3, 2024 | 06:10 PM
  #34
Way way way way off topic...but, most SMB who could or can did or is moving out of Illinois. A big Mercedes guy down here in FL I used to see at GLD and Byron (drag strips) back in the day. He closed shop and did the smart thing - got out of Illinois. It was very odd to walk into a Benz shop and see a guy I knew from up north....
Old Apr 11, 2024 | 04:24 PM
  #35
Red Bull's Avatar
Front diff fluid MBZ sheet 239.72
Back to the topic! Just completed front diff service. Drained the universal 75W85 MBZ fluid that was in there, which was changed at 95k ( 11k miles ago). Although it was not black like the initial drain, it was far from fresh looking so glad I did it again.
FWIW I installed the new gear oil by pumping it through the driver's side opening, which I accessed by removing not only the axle but the intermediate shaft.
As to the fluid, MBZ Sheet 231.1 states that sheet 239.72 covers front axles with alloy differential housings. Currently (and oddly) there is no MBZ-branded fluid listed under 239.72 so I installed Fuchs Sintopoid FE 75W85 which is on the list. This fluid also meets the spec for open rear axles (like our SLK55) so I'll keep it in stock going forward.
Old Apr 11, 2024 | 04:49 PM
  #36
kevm14's Avatar
04 E55 AMG (totaled), 07 S550 4Matic, 14 E63S
Why didn't you pump it into the drain plug hole?
Old Apr 11, 2024 | 04:56 PM
  #37
Red Bull's Avatar
Why did I not use drain hole?
I had an axle out, so easy enough to pump the correct volume into the differential this way
Old Nov 1, 2024 | 04:27 PM
  #38
Scott Petermann's Avatar
Mercedes Benz CLS 55 AMG
Originally Posted by kevm14
I did a front diff service on my S550 which also has no fill plug. There is an adapter you can thread into the drain hole and pump the correct amount of fluid up into the diff. It may be the same tool that threads onto the transmission pan (and the fluid is added the same way there, but considerably more). No reason to pull the axle and disrupt everything unless you want to do the seal(s).
It was one of the adapters from this kit for my S550 and I'd imagine the thread is the same on the E63:
Amazon.com: gohantee Transmission Automatic Fluid Oil Filling Filler Adapter Replacement for VW Audi 09G 01J 722.9 CVT DSG ATF Benz 722.9 : Automotive
This is on my S550 but same idea:
I think everyone will agree this is a lot easier than pulling an axle. Also, you can pump a small amount extra to compensate for the tiny spillage when you swap the adapter for the drain plug. I barely lost any...
Can anyone confirm that the 2014 CLS 550 4 matic does or does not share the trans fluid with front diff? I was about to drain but unsure no info out there . And if.it doesnt share does it need to be pumped into drain plug only?
Old Nov 1, 2024 | 05:01 PM
  #39
EckFe1's Avatar
993 cab, 2014 E63 AMG 4matic T
You pump it into the drain plug opening app. 65ml more to cover for spillage.
Old Jan 25, 2025 | 08:14 PM
  #40
Bertie_'s Avatar
GLK350, SL500 (R230), E55 (w210)
I did this, worked like a charm up the drain hole
I also used a small kitchen scale and zero'd it before pumping (using a pressure pump from amazon). Helps get exactly .6 qt in there, plus extra for some spillage.
Very quick and easy to do, once you have the right tools, pump and a simple scale.
The fluid was black like molasses.
Old Jan 28, 2025 | 02:26 AM
  #41
terryttk's Avatar
2014 E63 S Sedan
Wow, interesting the state of the old fluid. How many miles on the car?
Old Jan 28, 2025 | 02:46 PM
  #42
Bertie_'s Avatar
100k miles, at 75k miles I paid my local Benz dealer to change it during a recall or service of the front axle
Based on how black the oil is here (picture below)... I question whether the Benz dealer did a full change or just checked the level. If the former, these front diffs seem tough on oil and should have it changed more regularly.
With the process here, a change only takes an extra ~15 minutes if you're already under there doing an oil change.
Now that I know how easy the front and rear diffs are to change (rear is a dream...), I change them regularly. Same for the SL500 and E55, nice and enjoyable to DIY.
I leave most other things to my local indy.
Old Jan 28, 2025 | 07:33 PM
  #43
E63SAMG2014's Avatar
2014 E63 / 2017 CLS 63 / 2015 G63
the benz dealer 100% did not change the fluids @75K
Old Jul 28, 2025 | 02:37 PM
  #44
has anyone have had success with this method?
Old Jul 28, 2025 | 04:36 PM
  #45
BDC90's Avatar
2014 E63 AMG wagon 1965 Austin-Healey 3000 1970 AMC AMX
Yep. worked good for Me. Unscrewed fitting until end of threads, quickly swapped in thumb then position drain plug next to thumb and quickly swapped again. Hardly lost any fluid at all.
Old Jul 28, 2025 | 05:54 PM
  #46
excellent!
by the way, does front diff drain plug have washers that goes on it before or is it simply drain plug
Old Jul 28, 2025 | 06:09 PM
  #47
BDC90's Avatar
Ah I don't remember but I bet if there is one it's the same as oil drain.
Old Jul 28, 2025 | 06:12 PM
  #48
I see, fair enough.
what brand and weight of oil did you use?
I don’t think there are genuine mb diff oil, correct me if I’m wrong
Old Jul 28, 2025 | 06:30 PM
  #49
kevm14's Avatar
There is a washer but I don't think it's the same as the oil drain. You can reuse if in a pinch.
Old Jul 28, 2025 | 08:35 PM
  #50
Yes it worked fine for me as well used Motul for my diff change. Front and rear.
