M157 Engine Oil related questions
2. At what engine oil liter/quart does the “Low Engine Oil Light” come on? For instance, 1 quart less? Or 2 from full capacity of 9quarts?
3. Oil dipstick is reading between Minimum and Maximum mark on the stick. How much quart would be needed to bring a oil dipstick from between Min-Max mark to Maximum?
I never had to add oil between change or seen my low level on.
I always put 8.5qts at first. Let it run for 5min or so, then turn it off, let it cool off for 10-15min and check dipstick, add more oil till it's on max on dip stick.
In my 16k miles of ownership i have never had to add extra oil ever, Mercedes says it's normal for turbo cars to burn some oil, especially if changing every 5-8k
If I had to give you a good guess, I add about 8.8-8.9qts of oil total
have you checked the dipstick right after a oil change?
is it marked at Maximum? If not, what is your dipstick reading at full oil capacity?
you’ve added 8.5qts til it read full on dipstick. As mentioned, how much oil was added after 8.5qts was already added. Was .5qts added? Or a full quart? What was the total amount that was gradually added.
I did have a problem with the oil level sensor in my S550. It would report low when it wasn't low. After pulling my hair out and playing games with the dipstick I realized the float switch is probably just flakey. And it was. Meanwhile on my E55, it would almost never actually inform me of low oil. I would have to check via the computer and either look at the low/not low display or look at the quantity in the advanced menu. So I have an inherent distrust of some of these systems. But at least replacing the float switch on my S550 fixed that glitch.
9.5 is the MOST you should fill it if you're really goin after it. Some Porsches I just go straight to 10L and it doesn't care.
8 is the least you should fill it
I go straight to 9. Real sperglords will get it to right in the middle and be done with it. Anywhere on the dipstick until max is probably ok you can pull a dry dipstick out and the car won't even think the level is too low yet until you brake particularly hard. The car will let you know if its too low. I'm not saying it doesn't matter, I'm just saying theres a reasonable margin of error on this because oil changes viscosity, volume, and moves around alot.
Also if anybody in the thread would like to support the forum and is due for an oil change
https://www.amsoil.com/lookup/auto-a...bo/?zo=7236674
Alpha European Autotech
Purchase Amsoil at 25% off from me
Chris Tran, Retired Alpha European Autotech Owner
Amsoil Independent Dealer #7236674
Driven hard, but not on the track.
I have had cars that 'burned' oil such as a Subaru STi that burned less than a quart / 1500 miles, but when I dropped a rebuilt engine in it stopped burning oil.
My RX-7 will go through a quart between oil changes.
