Oil pump solenoids
- ECU tune
- TCU tune
- both
curious how this affects tuned cars, also curious as always @Cifdig 's opinion on all this.
thx
Do you happen to know what these tune patches do to the Bosch/Continental software?
Evaluate what it does and what you want - Pulling the plug does not modify the software that remains the same tuned or not tuned.
Oil mod extends the mechanical limits to get the ECU/TCU get in great mood from 0 to 100Mph
each one will need to "learn and lambda"
so to speak, correct?
I don't know what they do to the Bosch/conti software
After pulling the plug on the solenoid, I thought I would try the old Stage 2 file and voila, the drivability issues disappeared while I got the full performance of the tune back. The tune actually feels stronger than it did before pulling the plug.
While I don't have a TCU tune, I did have @BenzNinja install his transmission program which added a fourth mode (Agility), which may already be available on AMG cars as S+. (Peter's program also remembers the last tranny mode setting and if you are in any mode besides E, the car will start in the S mode when starting the car again.) The difference is that I have the standard 7G tranny. For me, the Agility mode is much more aggressive than the S mode.
I would try to be vanilla-stock so you can monitor your engine mechanicals gradually improving:
- piston rings seals improve.
- lambda cleanup carbonized oil.
- HPFP rattlesnake radically morphes
It seems too many testers expects 100% transformation on day-1. In fact the normal oiling is only first step of this transformation.
Once you switch back to another ECU you are going to get old stalled inappropriate maps. Just like after unplugging solenoid ECU/TCU have to relearn performance maps, better temperatures regulation, drastically improved engine output through shift-points.
I dont know how well TCU tolerate getting paired with different ECU. I know the ECU has intank ethanol sensor to taste E85 gasoline grade for combinations. It tweaks ignition advance to pre-ignition - amazin now as we know how ECU targets to roast the engine with super-heated pistons.
With normally cooled pistons the hot spots pre-ignition should be vastly improved.
The way we have awesome power above idle tells me mixture is more rich, so better better cooled from mixture than leaner.
I am not a fan of wacking adaptations to get anything fixed... try doing than on your spare boxes after 1500Mile stock vanilla when engine is in better mood.
I hope some of the wise developers coding tune extensions for Bosch knew about the limited oiling. Personally I have no interest in coding newer advanced oiling RPM limits maps... BECAUSE when that valve jams, engine is RIP.
No valve, no coding, no problem.
My experience tells me that if the CEL is not illuminated, and all OBD systems are ready, by definition, it is a pass for a plug-in test. I actually haven't checked OBD readiness but I think that would answer the question. Then, one of us will eventually find out for certain.
I am in an emissions state. If my silent codes are a problem, I would be contacting BenzNinja because I would suspect that something can be worked in developer mode - neither of these codes impact emissions compliance which is why they don't trigger the CEL in the first place.
thanks.
also - what if my oil pump fails in the future and I have unplugged this solenoid. How will I know the pump is gone other than engine issues?
also will this shorten the life of my oil pump?
additionally I tried accessing it from the top and I can just touch it but can't see anything - it's all feel. Also my arm got stuck lol soooo will be dropping the pan.
gm based video discussing all the same things:
https://youtu.be/-1f1u960I-I
They should also look into adding a sensor and the output via wire to the MB Bosch software that can be viewed via the OBD port and any app like Torque Pro OBDwiz etc via standard ODB2 PID's for oil pressure
I have read here the concern about "oil pump solenoid stuck open". The main problem is its existence at all. These solenoids can "leak pressure" due to grinding with debris in the oil. Once it "leaks pressure" the oil pump will NEVER reach its maximum expected pressure, and we all know where that leads to --> premature WEAR everywhere that hurts: crankshaft, camshafts, HPFP, etc.
Similar solenoids exist in the vehicle in different places, for example AC compressor, and the transmission. However, if the AC solenoid valve sticks we get no cooling, and the max cost may be a compressor, @$1000. If the tranny solenoid sticks, we get either a limp mode or poor shifting around that gear's solenoid. The engine oil sticks open, and we are talking about @$10K->$30K
I still do not understand its presence in the system at all.
Here is a picture of it installed in the pump (S550 photo from Ebay)
Also, this link has a few photo angles for the solenoid (for those who want to meet it)
https://www.pelicanparts.com/More_In...-180-04-15-MBZ
2. I don't think anyone knows if this will affect the life of the oil pump, good or bad. But, why would it? Are these oil pumps prone to failure?
3. Go on a hunger strike until your muscles atrophy enough for you to reach and disconnect the plug without getting your arm stuck. Which is more important anyway? Your health or your engine's health?
You need to unplug from bottom. Remove main cover, then remove the front cover. Access is pretty good that way. From the top is not recommended and you'll probably end up snapping some plastic coolant line or something, especially if you have Sasquatch arms.
I think this can only benefit the engine performance and longevity.
