Oil pump solenoids
Rating: Thread Rating: 14 votes, 4.29 average.
Old Yesterday | 01:48 PM
  #4526
KristiyanPetrov's Avatar
C43 AMG '17 / Stage II
Originally Posted by slobo
If your feeling was good, stay with this oil brand and try 5W50, like me. Best solution ever.
im bit scared to transition to 5w50 because im pushing constantly the car and nor sure if i blow the rings with much viscosity and to transition to w50 there were discussion that you should do it with a lot of km driven and shot by shot, nor sure how did you transition to w50, straight away or?
Old Yesterday | 02:46 PM
  #4527
slobo's Avatar
X218 CLS500 4-Matic 9G-Tronic / X204 GLK250 CDI 4-Matic 7G-Tronic
I sometimes drive 300 km/h on the German autobahn, and often 260 km/h—I don't think anyone pushes it as hard as I do... 🤣🤣🤣 I also frequently drive through mountain passes and often rev the engine. Trust me, the 5W50 is really good, especially when it comes to oil temperature, stable viscosity and watch my oil after 5K km.
Old Yesterday | 06:53 PM
  #4528
dspecialistb's Avatar
'14 CLS550 , '86 420SEL
because i don't put that many miles on the car, i just swapped the oil from 5w40 to 5w50. This is my second oil change with 5w50 and I haven't had an issues so far. No temperature spikes and with solenoid removed gets to temperature pretty quickly, and no issues with cold start either. I've tracked the car a few times now as well.
Old Today | 03:31 AM
  #4529
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
Post viscosity moves heat
You have witnessed HEAT being removed at normal driving Rpm - That benefit of 5w50 is not available with 5W40.
Your cooled pistons don't burn oil in ring grooves. Clean rings seal combustion equally. Not just viscous seal alone!
Removed pistons heat no longer accumulate to vaporize black oil on intake valves. This nearly doesn't matter when compared to unbalanced cylinders pressure.
### G Wagon + GLK350 + C200... hotel starting to look like MB Sce lane 😉
Attached Thumbnails Oil pump solenoids-20260603_150149.jpg   Oil pump solenoids-20260603_150121.jpg
Old Today | 05:25 AM
  #4530
Post let engine progress
It's up to you to know what your engine is up to experiment with it:
  • Strong smooth torque control ??
  • Edgy lean under 1500.Rpm
  • Heavy under 3k.Rpm ?
No point in rushing unbalanced cylinders.
The engine does put out high power but on few hard working cyls.
Give it some time until 3kR. vibrations level comes down towards your satisfaction
### S + E class mix
Attached Thumbnails Oil pump solenoids-screenshot_20260603_110323_gallery.jpg   Oil pump solenoids-screenshot_20260603_172023_gallery.jpg
Currently Active Users Viewing This Thread: 16 (0 members and 16 guests)
You have already rated this thread Rating: Thread Rating: 14 votes, 4.29 average.
