Oil pump solenoids
Rating: Thread Rating: 9 votes, 4.33 average.
Old 01-11-2024, 10:30 AM
  #851
SL55inMD's Avatar
SL55AMG, ML63AMG
I'm not sure how to search a single thread so sorry if this has already been asked - i pulled the oil solenoid plug a couple weeks ago - about 200 miles of driving. Super happy with results as the slight hesitation and transmission shudder i was experiencing was eliminated. Yesterday the car threw a P02990 code - boost pressure of turbocharger 1 is too low - car seemed to be driving normally though. Has anyone seen this after pulling the plug??? It's a '13 ML63 with 66k miles and has not thrown this code before. Thanks.
Old 01-11-2024, 11:06 AM
  #852
kevm14's Avatar
04 E55 AMG (totaled), 07 S550 4Matic, 14 E63S
Originally Posted by JettaRed
I'm kinda new to oil additives. Why no Ceratec with MolyGen? What about Ceratec + Mobil 1?
EDIT: Went to the Oil Guy site and read about not mixing Ceratec w/ MolyGen.
Yes:
and in fact LM specifically says not to use Ceratec with Molygen. They have confirmed that using MoS2 is ok.
I guess it would be nice to see this in writing but it makes enough sense to me.
Old 01-11-2024, 11:17 AM
  #853
PeterUbers's Avatar
Received 2,031 Likes on 1,418 Posts
2014 E63S; AMS 100 octane ecu tune; edok tcu tune; BB intakes; dyno tuned
have you tried re plugging the solenoid?
Old 01-11-2024, 12:48 PM
  #854
kevm14's Avatar
I believe you're the first out of 850 posts in this thread.
Old 01-11-2024, 01:33 PM
  #855
bentz69's Avatar
'16 CLS63S
Originally Posted by kevm14
That is impressive. Does Blackstone have any comments on your additive approach? I am using Liquimoly Molygen - I assume you are using the regular stuff.
The additive package can be seen with the very levels of molybdenum. Blackstone has not stated their opinion on additives. But for me, its just a little extra insurance on reducing friction and wear so why not. Yes, I am using regular 5w-40 liquimoly
@bentz69 FCP recommends using Ceratec every 5 oil changes/25,000 miles. Do you use it every change? Also, the 300ml bottle treats 5 liters, but our sumps hold more. Do you use more than one bottle per application?
I use ceratec every third oil change or roughly 30,000 miles. All other oil changes I use Mos2. Ceratec and Mos2 should not be used together. I use 2 300ml bottles per oil change.
Maybe I was right all along with MolyGen then. It isn't actually 229.5 approved (just "recommended").
Who's using Liquimoly Molygen? | Bob Is The Oil Guy
Ceratec + MolyGen is a no no (and I don't use it anyway).
Many people use molygen with their amg motors even though its not approved. Molygen essentially has the additive already included. Ive just stuck with what has been working for me on my last two cars.
Old 01-11-2024, 01:42 PM
  #856
AMGandS1K's Avatar
2015 E63 AMG S
I agree. It just sounded like there would be an adverse reaction if you added Cera Tec to MolyGen. Maybe overkill, if not a waste of money. Once I deplete my Mobil 1 0W-40 using Cera Tek, I'll probably switch to the MolyGen, as well.
I just had visions of what happened when I added Redline Water Wetter to my coolant in my VW Jetta once. All sorts of solids formed and turned the coolant from pink to brown before I flushed everything and went back to only G-12 and water.
Yes:
The BITOG forum is almost exclusively about how to be cheap and increase your OCI to as high as possible. That's why almost he first recommendation you're going to get is M1 oil "good enough, has everything you need". They dislike additives because they say "The oil additive package already has what you need in it."
One of the best recommendations I got on there was to try High Performance Lubricants' oil. Which I will be trying based on talking to the company owner. I am first going to try their Engine Cleaner in my fiancé's 2001 Lexus ES300 (prone to sludging) and see how it goes. Their engine cleaner is an oil with a very heavy additive package to clean the engine out and is recommended as a transition step to their oils. Only drawback is their oils are certainly not cheap compared to ordering something on FCP and getting free oil for life essentially, I'd definitely use it for a track weekend though.
I'm debating the HPL or buying 2 jugs of Motul 8100 Power from FCP for return policy and trying that after I do the HPL Engine Clean.
Old 01-11-2024, 01:47 PM
  #857
AMGandS1K's Avatar
2015 E63 AMG S
How would you describe your driving habits? That will drastically affect your oil health and how long you can go for OCIs.
With the mod, given the higher mechanical contact and overall time under heat, your oil will almost certainly degrade faster than your previous changes. Overall, the best adage is "oil is cheap, engines are expensive" especially if you're getting your Lifetime replacement from FCP Euro. If you want the best gauge, you'd do the UOA (as you are) and also visually inspect inside the engine for the cylinders and carbon build up.
Old 01-11-2024, 04:10 PM
  #858
jcarsnz's Avatar
2015 ML63
Re P02990, this thread is worth a read
https://mbworld.org/forums/w212-amg/871147-turbo-boost-low-code.html
Old 01-11-2024, 06:46 PM
  #859
TomZVB's Avatar
R231 SL 63
I still don’t get how FCP Euro is able to do the whole “lifetime” oil exchange thing.
Old 01-11-2024, 06:50 PM
  #860
TomZVB's Avatar
R231 SL 63
Originally Posted by jcarsnz
Your code isn’t going to be oil control related. It’s either bad vacuum or something with the waste gates. Check out the thread that was posted. Hope it points you in the right direction!
The following 2 users liked this post by TomZVB:
CaliBenzDriver (01-12-2024), kevm14 (01-12-2024)
Old 01-12-2024, 03:54 PM
  #861
pathfinder_88's Avatar
2014 GL63 Eurocharged Stage 1
Just unplugged my ‘14 GL63 after reading this thread. Quick tip: after releasing the gray clip, ensure it’s this grey clip you depress when pulling the plug. I struggled with mine for a bit (and it’s a bit of a pain to access with the active body control crap in the way on the GL). There’s not enough wiring to strap the plug anywhere so I’ve resorted to some dielectric grease on the contacts for now.
No CEL on the GL. Our weather is bitterly cold up here in BC at the moment so I’ll have to give it a bit more time to see how the drivability is as roads are snowy/slick.
The following 3 users liked this post by pathfinder_88:
juanmor40 (01-12-2024), PeterUbers (01-12-2024), TomZVB (01-12-2024)
Old 01-12-2024, 05:34 PM
  #862
AMGandS1K's Avatar
2015 E63 AMG S
Because most customers simply never take advantage of it. So givent hat their prices are higher than other places to account for the people that do take advantage, it balances out to being profitable. Almost no one is going to drain the oil back into bottles to return.
They also will refuse return on a case by case basis. Be it frequency of returns, or any other factor.
TomZVB (01-12-2024)
Old 01-12-2024, 06:06 PM
  #863
PeterUbers's Avatar
anybody who lives by the FCP Euro distribution center has it made because they can simply walk back to the front desk with the used products and ask for a new product.... possibly.
TomZVB (01-12-2024)
Old 01-12-2024, 06:08 PM
  #864
AMGandS1K's Avatar
2015 E63 AMG S
EExcept the only way I'd want to live it CT is if I lived in what is that crazy rich area, Greenwich? Haha
Old 01-12-2024, 06:27 PM
  #865
PeterUbers's Avatar
yep where kennedys get away with moidah lol
AMGandS1K (01-15-2024)
Old 01-12-2024, 07:00 PM
  #866
JettaRed's Avatar
Received 1,601 Likes on 1,194 Posts
... Almost no one is going to drain the oil back into bottles to return...
Ummm, I'm right here!
I did return the tranny fluid because that stuff is so damned expensive, and they credited the full NEW price to my account. In the past, I think they actually refunded your credit card, but now they are just giving store credit, which is fine.
Old 01-12-2024, 07:10 PM
  #867
JettaRed's Avatar
FCP used to be FCP Groton, if I remember correctly.
Sadly, I have to agree about living in CT. The political environment is bad enough in Maryland, but anywhere from New Jersey north is worse until you reach New Hampshire (Maine is questionable). Greenwich is just a suburb or NYC, though CT is a beautiful state. And there's always Mystic Pizza.
TomZVB (01-12-2024)
Old 01-12-2024, 08:00 PM
  #868
AMGandS1K's Avatar
2015 E63 AMG S
They still are that, that's what shows up on your charges when you buy form them. I think they are using a dba name of FCP Euro or made FCP Euro a subsidiary company that FCP Groton is owner of. Either way, same people.
And yes, I take full advantage of the Lifetime policy lol. As of last year ECS Tuning now has the same policy excluding consumable liquids and a few other things. So they're a good avenue as well for some parts that FCP doesn't carry.
TomZVB (01-12-2024)
Old 01-12-2024, 09:06 PM
  #869
billvp218's Avatar
m157 SL63
I send in my oil. Postage is about $25, so that's a good price for the Liqui Moly oil change kit.
Old 01-12-2024, 09:24 PM
  #870
JettaRed's Avatar
Wonder if they relocated from Groton to Milford, where it seems they do all of their business from. Or do they have two locations? And if they did move, that would make sense to change the name, even if as a dba.
Old 01-12-2024, 09:30 PM
  #871
JettaRed's Avatar
Mystery solved!
Old 01-13-2024, 02:47 PM
  #872
san40's Avatar
2015 s212 e63s wagon
This is an interesting comparison for my 62K M157, same liquimoly 5w-40 oil but no additives. 7500 (with solenoid plugged in) is longer than usual, I target 5K miles (when dip stick starts to hover around min mark).
Most notable difference is molybdenum and the fact that your OCI is twice as long. Wonder how do we compare the heaviness of the foot
I may be the minority here but I have always done 10,000-11,000+ mile OCI's using liquimoly 5w-40 with either ceratec or mos2 (depending on the interval) on my previous '14 w204 m156 c63 for approximately 90,000 miles and wear metals were always within spec AND the TBN showed significant life left in the oil. Blackstone analysis stated I could run the oil for at least 13,000 miles if I wanted to.
Now with the '16 w218 m157 cls63s, I still use the same oil and additives while following the same 10,000+ OCI's. Results are the same. Wear metals always within spec and TBN shows a good amount of life left. Car currently has about 58,000 miles.
I unplugged the solenoid right when I did the last oil change in early December and sent in the sample to blackstone. That sample had 10400 miles and Its currently being processed. Since unplugging, I have appx 2000 miles on the new oil. Reading this thread has me wondering if I should shorten the OCI to maybe 5,000 or 6,000 and send in the sample or continue with my 10,000+ interval. Either way, Ill be sending in a sample like always.
Edit. Report came in today
Old 01-14-2024, 11:59 PM
  #873
bentz69's Avatar
'16 CLS63S
My driving style is mostly highway cruising with some local. My car often sees redline once or twice a day though.
Old 01-15-2024, 12:09 AM
  #874
san40's Avatar
sounds similar to mine, I'm taking it easier in the winter, afraid of roof box falling off
Old 01-15-2024, 11:29 AM
  #875
63sGeo's Avatar
GLE 63S
I am curious as to why the cold start sounds so different since being unplugged. Seemed like RPMs would drop to idle very quickly soon after unplugged but now seems to have adjusted back to holding the revs higher but still sounds different than before.
Any thoughts?
You have already rated this thread Rating: Thread Rating: 9 votes, 4.33 average.
Quick Reply: Oil pump solenoids
