i have an android screen installed and when using carplay i cannot get reverse camera to come up in R not even sensors work is there a way to fix this?
There's an adjustment within the Android monitor to tell which monitor to use. Stock, aftermarket or 360 or even pop out on some models. At least on my monitor.
Looks exactly like Peter's video instruction.
Nothing more to add.
Did you try this adjustment?
Assuming you have a working rear cam and the adjustments don't do anything, you'll have to dig deeper and take the monitor off.
Check the connections to the monitor.
Unfortunately, mine is very different from yours. I also upgraded the software to the current MBUX icons.
I have 3 white connectors vs the standard 2.
Is everything else working?
Phone, music, apps etc?
i tried what the video showed but nothing and everything else works fine btw how did u upgrade the software to the current MBUX icons
I guess it's time to pull the Comand player and check your connections.
This pic shows the Comand 4.5. Yours might be different but check # 6.
I got my monitor from RoadTop. They asked if I wanted to update the software, so I did.
