W212 - 360 Camera calibration question
Old Mar 19, 2024 | 07:28 PM
timm206's Avatar
C63 W204 / E63S W212 / E63S W212
Hello everyone,
Im in the process of taking off the front bumper on my car, the car is equipped with the 360 camera so it has a camera upfront.
Ive done some research regarding this subject but haven't found a definitive answer so here i go.
I want to pull the car out of the garage while the front bumper is de-attached to pressure wash it. Since i will have to turn the ignition ON while the camera and parking sensors are disconnected, will i have to perform a camera recalibration or issues with the parking sensors once i reconnect everything back together?
It’s a 2015 E63, i believe NTG4.7, not sure if it’s relevant.
Dealer quoted 250$ to 500$ for a 360 calibration which is not bad but i rather avoid the dealers as much as possible.
Thanks in advance
Old Mar 19, 2024 | 09:04 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
SPONGE CLEAN !!
Originally Posted by timm206
Hello everyone,
Thanks in advance
Goood question, ahead of time!
If you power up the chassis with inputs disconnected, granted some modules are going to fault defective sensors.
There's a chance everything will wake up later as if nothing happen -Or the sensors will need to be reinitialized.... your $700 question!
I would sponge the parts you want clean: exposed bumpers connectors are only waterproof, not watertight. Silicone them as you encounter them.
TIP:
While bumper is off... easily cleanup the Distronic front radar cover. It's inner side gets dirty with road projections.
Old Mar 20, 2024 | 11:24 PM
timm206's Avatar
[QUOTE=CaliBenzDriver;
[/QUOTE]
Makes sense, i should first acquire Xentry before attempting something like that.
