Race Chip with TCU tune?
Are the potentially negative interactions in this scenario? It seems like the TCU and ECU should behave as a black-boxes to each other -- i.e. the TCU is fooling around with clutch pressures and such, while the ECU does similar isolated things with spark timings, but when these systems talk to each other it would just be "hey, shift to 4th gear" not "hey, shift to 4th gear with [x] pressure" or whatever...
I'm just not aware enough of how these systems might interact to give the chance of a problem scenario... or even if this is a ECU flash vs piggyback style question... maybe any ECU and TCU flash scenario must always be carefully matched?
Anyone care to educate me?
i have ec and ams ecu's, edok tcu tune, and once I had my tcu tune (already had the ams 93 and ec40 e tune) I had my ecu's reprogrammed by each vendor to account for the tcu tune - they had to consider the torque tables (how much torque allowed per gear)
ams really dialed in my 93 and 100 octane tunes after I had my black boost and tcu tune with the car on their dyno. I'm a big fan of a great tuner and his custom dyno tune
Does this apply to an ECU (not piggyback) tune which isn't at all aware of the TCU update? Say, from a different company, etc...?
If so, can you describe the technical difference as to why it would matter (flash vs piggy)?
I will indemnify any party who offers an opinion here on the matter... but even then there is the matter of IP exposure. So, it might be a hard question to get any authority to respond to.
...I just don't want my **** to blow up when I try a 0-60 run now and then. But, in the legalistic environment we're in, maybe that just has to be done blind.
https://www.youtube.com/watch?v=OGPu...l=ExoticCarDIY
i guess my point is that if both software packages are sourced from ec, they are appropriately configured to understand each other / ecu tune likes the tcu tune
Yep, the EC all-the-way is definitely the theoretically best option to ensure that all the systems work together as intended... but the RaceChip 1) makes similar gain promises, 2) easy-ish to install/remove, 3) configurable as I drive (this part would be awesome). Kenny's video really lays that out well... being able to react to external temps that could make bleeding-edge performance a risk to the engine is a great feature.
So, in a world where it doesn't break things and does what it claims, the RaceChip seems like it has an edge.
i did it back in the day when you had to crack open the ecu to program it
Piggy backs were a decent theoretical advantage in that they prevented residue of a tune (car under warranty, able to deceive the dealer) .. which isn't really the case. But they have their disadvantages and the case for and against piggy back concept is well laid out on YT
The reasoning is related to how the piggyback works opposed to the ECU tune.
If you notice in my video, the piggyback was actually faster 0 to 60 and 8th mile I believe, while the ECU tune was much faster in the 60 to 130.
My hypothesis is while the Euro charge tune likely makes more power on a dyno, the reason the piggyback tune was faster down low was because it's essentially bypassing the TCU nannies.
the TCU is working in conjunction with the ecu, limiting the power in first second and third gear. Even if the ECU is tuned, the TCU is still overriding the map values and can limit the horsepower.
However with the piggyback tune, cleverly fools the sensors and is able to command more fuel and boost without the TCU knowing.
Totally making up these numbers but to illustrate, if stock boost is max 14 psi (however less in one two and three) ECU tune will tune it to 18 PSI... But then the TCU still limits it to like 14 and first, 15 and second, 16 and 3rd, 18 PSI in the rest of the gears.
With the piggyback tune, the ECU is commanding for example 11 in first, 12 and second, 13 and 3rd, and 14 PSI in the rest of the gears however the piggyback takes that 11, 12, 13, 14 PSI actual and tells the ECU that it's only 8, 9, 11 PSI and so the ECU closes the wastegate a little bit more and has a bit more fuel up to water ever the limit if the race chip is... Maybe 16psi the whole time
So essentially what a TCU tune does besides upping the trans pressure a little bit, it allows more boost in first second and third. So if one was to combine a piggyback with a tcu, you might get quite a bit more boost in first second third without the added trans pressure to prevent slip.
Long ramble, hopefully this illustrates what I'm talking about
