Odd Engine sound M157
CLS 63s AMG 4matic
Hey,
What are your thoughts on this engine sound. Im referring to when im slightly giving gas and the RPMs drop, you can hear this "grinding" noise. Might be wrong, but does it sound chain related? Is it normal?
Warm or cold engine, always sounds like this. Oil is fresh and oil level is good.
Link to video:
Dont mind the "empty" IC coolant resorvoir, its fixed.
Thanks.
Link to video:
Thanks.
Received 3,374 Likes
MY'14 W212 M276 3.5NA @55kMi
Hey,
Thanks.
Thanks.
How many total miles on it?
Compare between engine cold and operating temperature.
Presumably when decelerating the ECU increases the load on serpentine belt load with a higher ALT demand.
OldManAndHisCar (07-05-2024)
CLS 63s AMG 4matic
Happy to hear the engine sounds healthy. Warm/cold engine makes no difference. The car indeed only has 25k miles (yes you read that right) and has been serviced at the dealer every 3k miles. Its a 2013 model year produced in June.
Im the third owner (previous to two older gentlemen), never winter driven, a big deal for being in scandinavia with the salty winter roads we have.
Regarding the laggy throttle, I have actually hopped on the train of unplugging the oil solenoid to the oil pump. Car clearly ran better after that. Car has updated timing chain, but I have the car booked in to get updated tensioners and check valves as im hearing some slight chain rattle upon warm starts sometimes.
Sorry for the long update and history of my car. This forum is very nice and helpful!
Thanks!
timing tune-up
Gratitude for your reply!
Thanks!
Thanks!
Funny thing is dealer is going to realize your engine has better throttle response than other customer cars.
-- You know while you have the 2x front VVT covers removed to upgrade chain tensioners, it would not cost you much to throw in a coolant thermostat. It's really good insurance.
-- Also at that time have the CPS + VVT Solenoids inspected one by one or replaced with pigtails against oil-in-harness damage.
CLS 63s AMG 4matic
Glad your enjoying your excellent car with the oil of your choice.
Thanks for the tip. I have actually already changed the CPSs myself (very easy). The Solenoids though, is booked along with the tensioners.
What about the coolant thermosatat, is it really that big of a concern? Just looked it up, seems expensive for a thermostat... Im feeling like skipping it for now as my cost is already high on the work order. But not sure.
cover sealant leak...
Great to hear! So I dont need to worry about my engine sound then?
Let's address the oil leak from the VVT cover sealant gasket.
Make sure this stops leaking after the 2x chain tensioners replacement.
Cleaning and spreading new sealant on timing covers is part of that job.
CLS 63s AMG 4matic
Should I have them listen for the sound in the video or am I just overthinking at this point?
CLS 63s AMG 4matic
Please help!
Bumping this because this sound is still driving me crazy.
I would really appreciate multiple opinions on this. As you can hear, there is almost a "grinding" noise when i start giving gas and then letting go. Almost as if the timing chain is loose?
Thanks to CaliBenzDriver for the first answer on this thread.
