Turbo coolant line upgrade
Old Jan 8, 2025 | 01:24 PM
BDC90's Avatar
2014 E63 AMG wagon 1965 Austin-Healey 3000 1970 AMC AMX
My joy of pain has Me doing lines, pump, pulleys, belts and everything I break during the job.
Old Jan 8, 2025 | 01:29 PM
QuadTurboPrius's Avatar
W212 E63 S AMG
Just be super careful with the screw on the turbo if you're changing the metal parts... low torque. See thread at https://mbworld.org/forums/w212-amg/...-n-tricks.html. A poor soul on that thread broke his off
Old Jan 8, 2025 | 02:23 PM
BDC90's Avatar
Oh for Heavy Snakes, a 2nd hose clamp the WIS didn't show.
Old Jan 8, 2025 | 02:44 PM
BDC90's Avatar
Well fan removal only took 4 hours. Blistering pace.
Nor Cal SL55's Avatar
2012 E63 AMG
Originally Posted by QuadTurboPrius
No, just a few parts have to be loosened up top, then 3 screws holding the oil lines at the bottom and you should be able to sneak the whole fan shroud out.
Similar to https://www.youtube.com/watch?v=gvPt...nel=ZakiGarage, but AMG has more screws at the bottom
That is an awesome video - very clear and useful for access to many of the service projects that occur on the front of the car...
Old Jan 8, 2025 | 02:45 PM
BDC90's Avatar
Charge pipe won't come off. I'm toast for today.
Old Jan 8, 2025 | 03:00 PM
  #32
W212 E63 S AMG
Sounds about right... this "5 hour" job took me 13 over a weekend...
Just wait until you get to the part where you have to put the new turbo coolant lines into the turbo (read my thread first)
Old Jan 8, 2025 | 03:04 PM
  #33
BDC90's Avatar
Yeah I'm thinking of doing the hose upgrade and not touching where lines connect at turbo. I did get a slim head socket though.
Old Jan 8, 2025 | 09:01 PM
  #34
Jaybird123's Avatar
2015 E63S Sedan, 2014 E550 coupe
It’s a tough PITA job, but it definitely pays to do it slowly and take (cussing) breaks lol. Accept that your hands will be shredded but your car will have a new lease on life once successfully completed. If you go coolant line mod route, look forward to your feedback/pics etc
Old Jan 8, 2025 | 09:54 PM
  #35
BDC90's Avatar
The good news is My hands were shredded already from last weeks exhaust debacle including the difficult O2 sensors.
Old Jan 9, 2025 | 08:21 AM
  #36
kevm14's Avatar
04 E55 AMG (totaled), 07 S550 4Matic, 14 E63S
Yeah removing the fan was much more annoying than I expected. I had it in my head that these fans are always easy to pull. It does go back in easier than it comes out if that makes you feel better. For the charge pipe reinstallation, I had much better luck installing the seal to the turbo first, and slipping the pipe over. It would not go on any other way.
Old Jan 9, 2025 | 09:00 AM
  #37
BDC90's Avatar
Heh, I can't get the charge pipe off. I'm gonna go at it again today.
Old Jan 9, 2025 | 09:52 AM
  #38
W212 E63 S AMG
If I need to do this again, I will also upgrade-in-place. Easily would have saved a few hours. My only worry is how long those o-rings last inside the turbo... but, since the right side is built the same and doesn't seem to fail, the left side can probably last a while too.
We just need someone with a 3D metal printer to reproduce the nipples at the water pump end and those dumbass plastic flanges and pipes around the water pump.
Old Jan 9, 2025 | 03:23 PM
  #39
BDC90's Avatar
OK waterpump out. I have 2 questions. 1 . I slightly scored the aluminum lines when cutting off the plastic at the water pump. Am I hosed now on the upgrade trick and need to replace ? 2 I don't see any evidence of any kind of sealer/permatex on the WP gasket nor does the WIS say anything. Did You Guys use any?
Old Jan 9, 2025 | 03:24 PM
  #40
kevm14's Avatar
No and no
Old Jan 9, 2025 | 03:29 PM
  #41
BDC90's Avatar
Man I love a short answer. Couldn't have done this without You starting this thread. Thanks
Old Jan 9, 2025 | 04:15 PM
  #42
BDC90's Avatar
The other thing I forgot to post was one of the long WP bolts far right and down low came out covered in oil. I gotta try to figure that out too.
Old Jan 9, 2025 | 04:40 PM
  #43
W212 E63 S AMG
I agree with the no and no... but I'd also probably put a very thin (very thin) film of silicone or equivalent just to be safe
Old Jan 9, 2025 | 04:42 PM
  #44
W212 E63 S AMG
Probably nothing. I recall seeing that too. If that's the right bolt for the hole and it's not leaking externally, I doubt it's an issue.
Old Jan 9, 2025 | 04:47 PM
  #45
BDC90's Avatar
I have a gasket for the oil cooler, if I can figure that one out I'll replace it. Finding torque values in the WIS is time consuming for a newbie.
Old Jan 9, 2025 | 04:59 PM
  #46
OldManAndHisCar's Avatar
W212 E63S Wagon - GSL580 - E63 - E350 - C300
Okay...I may go to the garage and drain my coolant....shall we let my fun begin?
Old Jan 9, 2025 | 07:46 PM
  #47
Jaybird123's Avatar
Do it. You’ll cuss yourself not much later if you don’t. They leak. You’re already mostly there
Old Jan 9, 2025 | 08:22 PM
  #48
You replacing this while you are there too?
Old Jan 9, 2025 | 08:23 PM
  #49
  #50
BDC90's Avatar
Heh, I guess not because I don't recognize it.
