Turbo coolant line upgrade
Old Jan 9, 2025 | 08:36 PM
  #51
OldManAndHisCar's Avatar
W212 E63S Wagon - GSL580 - E63 - E350 - C300
Originally Posted by BDC90
Heh, I guess not because I don't recognize it.
<$20.00. Part of oil filter housing. Known leak point. Can only get to it with thermostat out.
https://www.fcpeuro.com/products/cov...des-2781800438
Old Jan 9, 2025 | 08:39 PM
  #52
BDC90's Avatar
2014 E63 AMG wagon 1965 Austin-Healey 3000 1970 AMC AMX
Crap. I just sent an order for o-rings too.
Old Jan 9, 2025 | 08:42 PM
  #53
https://www.google.com/url?sa=t&sour...ZPj01QiaDQqTXJ
Old Jan 9, 2025 | 08:52 PM
  #54
kevm14's Avatar
04 E55 AMG (totaled), 07 S550 4Matic, 14 E63S
Mine broke trying to remove and could not find locally (it's the oil cooler thermostat cover). Ended up buying an entire oil filter housing with thermostat, cooler, filter and cover at my local dealer for counter retail. Ouch.
Old Jan 9, 2025 | 08:58 PM
  #55
kevm14's Avatar
Originally Posted by OldManAndHisCar
Wow, my M157 was pretty leak free, especially compared to what's shown in that link, at over 100k. Luck of the draw?
Old Jan 9, 2025 | 09:02 PM
  #56
BDC90's Avatar
So far no signs of leaks for Me. My cooling lines were rock solid, I tried to snap them but couldn't. WP pulley showed no movement. Just that 1 long bolt with oil on it.
Old Jan 9, 2025 | 10:48 PM
  #57
BlownV8's Avatar
E55, GLS450, GL63, GLE350
Just make sure you don't try to remove counterclockwise. Turn to the right to remove.
Old Jan 9, 2025 | 10:50 PM
  #58
BDC90's Avatar
You mean the oil cooler?
Old Jan 10, 2025 | 07:49 AM
  #59
kevm14's Avatar
I think I was able to get my lines to snap but there were no signs of leaking.
Old Jan 10, 2025 | 08:12 AM
  #60
BDC90's Avatar
Maybe climate related? My car was Canadian until I moved it to N.E. PA.
Old Jan 10, 2025 | 08:53 AM
  #61
kevm14's Avatar
Yeah mine was 100% Northeast which is not too hot.
These things run ridiculously high coolant temps for emissions as it is so a hot climate must be murder on all the components.
Old Jan 10, 2025 | 11:01 AM
  #62
BDC90's Avatar
Anyone remember is the bolt that holds lines in at turbo 8mm or 10 mm torx?
Old Jan 10, 2025 | 12:12 PM
  #63
QuadTurboPrius's Avatar
W212 E63 S AMG
I think it was 8... but you could also check the other side
Old Jan 10, 2025 | 01:33 PM
  #64
kevm14's Avatar
I didn't touch mine but I believe it is 8. I remember this because I have a ratcheting 5/16" box which technically fits an E8. I remember trying to guide the wrench down to the bolt before I planned the job out and was like "nope" and made an alternate plan....
Old Jan 10, 2025 | 08:53 PM
  #65
Jaybird123's Avatar
2015 E63S Sedan, 2014 E550 coupe
I think 8 too, but my memory is crappy. I know I utilized my handy 2+ ft long big flat blade screwdriver as a lever down the sidewall behind my ratchet to help hold it in place while working the turbo coolant line bolt.
Old Jan 11, 2025 | 01:02 AM
  #66
BlownV8's Avatar
The oil filter thermostat cap. Also, be careful as it is under spring pressure, fairly strong spring so be ready to catch it if it shoots out. It was leaking like a sieve on my M157. Much cheaper than replacing the whole oil cooler assembly.
Mercedes Oil Filter Housing Thermostat Cap - Genuine Mercedes 2781800438 | FCP Euro
Old Jan 11, 2025 | 02:11 AM
  #67
andrewwiencken's Avatar
Yes I tried silicone hose at first but could get a positive crimp and moved to a high heat rubber line and used custom crimpers that are different form the flush cut crimpers. I replaced the two lines . I put dies in the system and have been checking it from time to time no leaks . This weekend replacing plugs and coils . had a misfire on #6 and the are original coils with 108.000 miles on them and the plugs are at 30,000 crossing my fingers when I shop the holes. This was my dad's car that was well maintained and all the services on time . I would detail it for him twice a year its in amazing condition .
Old Jan 11, 2025 | 09:05 AM
  #68
BDC90's Avatar
I'm a little worried that all My jockeying around moved the metal lines enough to disturb the o-rings at the turbo so contemplating trying to remove them.
Old Jan 11, 2025 | 09:06 AM
  #69
kevm14's Avatar
If you mean bending the hose end of the lines then no, it's fine.
Old Jan 11, 2025 | 09:11 AM
  #70
BDC90's Avatar
Well the hose ends got moved back and forth quite a bit and I wonder how much stress that put on the o-rings on the ends in the turbo.
Old Jan 11, 2025 | 09:16 AM
  #71
kevm14's Avatar
Was the bolt touched? If not then I don't think anything moved.
Old Jan 11, 2025 | 09:18 AM
  #72
BDC90's Avatar
Nope , I never got near it. Just had to shift the hose ends around to extract to old WP.
  #73
kevm14's Avatar
Yeah I did the same. I don't think anything could move over there.
Old Jan 11, 2025 | 09:23 AM
  #74
BDC90's Avatar
I didn't remove the bracket holding the 2 tubes together with the idea that it would provide some support. I only removed the bolt holding the tubes to the WP.
Old Jan 11, 2025 | 09:24 AM
  #75
kevm14's Avatar
I think I did because I was doing my oil cooler and filter adapter at the same time. No coolant leaks that I know of.
