Turbo coolant line upgrade
Subscribe
Jan 31, 2025 | 10:56 AM
  #126
Coolant line to Water Pump
Did you also update this line that was part of the write up?
Reply 0
Jan 31, 2025 | 10:58 AM
  #127
Oh yeah . I used a replacement from FCP Euro. Don't forget the 2 plugs in the W/P.
Reply 1
Jan 31, 2025 | 11:03 AM
  #128
Oh good! You were able to clear the WP pulley by twisting the cushioned hose clamp? Any pics? This is a point of concern for me.
Reply 0
Jan 31, 2025 | 11:35 AM
  #129
Quote: Oh yeah . I used a replacement from FCP Euro. Don't forget the 2 plugs in the W/P.
I am on hold waiting for two plugs....no way I try to reuse the old ones.
Reply 0
Jan 31, 2025 | 11:45 AM
  #130
Quote: Oh good! You were able to clear the WP pulley by twisting the cushioned hose clamp? Any pics? This is a point of concern for me.
The lines from pass. side are pretty flexible, I had no trouble moving those.
Reply 0
Jan 31, 2025 | 01:11 PM
  #131
I don't think I phrased my question concise enough. How were you able to get the silicone hose to arc around the WP pulley without making contact? Installing updated hose end to end, the pulley will rub against it.
Reply 0
Jan 31, 2025 | 02:45 PM
  #132
I used the stock MB line for the Pass. side. I only did silicone on the driver side.
Reply 0
Feb 1, 2025 | 07:59 AM
  #133
Quote: Did you also update this line that was part of the write up?
See the bottom of post #4.
Reply 0
Explore
Mar 12, 2025 | 02:21 AM
  #134
hey does anyone know if the turbo coolant line parts are the same for m157 and m278
we have a s550 2015 that blew a line in front, and i need to get it fixed.
im looking for a list of parts for the 278 but cant seem to find on the other sections of forum thanks
Reply 0
Mar 12, 2025 | 11:14 AM
  #135
Quote: hey does anyone know if the turbo coolant line parts are the same for m157 and m278
You need EPC to figure out the exact parts number. I have seen different driver-side coolant line for M278 and M157. I think the passenger side and the bridge line in the middle is the same. The water pump may have different parts numbers but the M157 one is superior. It has closed ports in the middle rather than the open port which needs plastic plug. I think Mercedes revised the design on this one.
I have a brand-new water pump in box, original Mercedes. DM me if you're interested.
Reply 0
Mar 12, 2025 | 03:51 PM
  #136
Quote: You need EPC to figure out the exact parts number. I have seen different driver-side coolant line for M278 and M157. I think the passenger side and the bridge line in the middle is the same. The water pump may have different parts numbers but the M157 one is superior. It has closed ports in the middle rather than the open port which needs plastic plug. I think Mercedes revised the design on this one.
Will the 157 pump fit the 278.
My pulley looks good. Tho it's old I don't see it walking.
Trying to keep expense down as it's. A spare car that already has two major issues with bad turbo actuator and also a lot of chatter from the rockers on the top of the head
Reply 0
Mar 12, 2025 | 03:54 PM
  #137
Yes the WP is the same. For some reason M157 pump has a much higher premium, not sure if it used a better bearing or just AMG tax. The WP part number is different and the part number on the bearing wheel is also different. I hope I paid extra dollar for a better product.
For cost wise, if you're doing it yourself you can only swap the damaged parts. If you decide to hire a shop, you better do all the "while you're down there" items because they have so much overlap in labor.
For your reference I just paid a shop to replace water pump, driver side turbo line, thermostat, oil filter housing gasket, oil cooler gasket, belt tensioner, idler pully and belt. End up with $1700 in labor, I supply all the parts.
Reply 0
Mar 16, 2025 | 01:15 PM
  #138
Rubber hose cushion size
Does anyone know what size hose cushion is used for the turbo coolant line upgrade? 3/8 or 1/2?
Reply 0
Mar 23, 2025 | 09:13 AM
  #139
If you click through to my ACE Hardware link in post #1, it says 1/2"....
Reply 0
Mar 24, 2025 | 10:29 AM
  #140
Quote: *****ORIENTATION NOTE: "Left" and "right" ALWAYS, ALWAYS, ALWAYS refers to the position relative to you sitting in the car. Never use "left" or "right" to refer to your perspective when looking at the engine from the front unless you clarify what you mean in each instance. This has been a PSA.****
Unless you're in the UK; then everything is on the wrong side!
Reply 0
Mar 24, 2025 | 10:59 AM
  #141
Quote: Unless you're in the UK; then everything is on the wrong side!
I just look at my feet while facing the car to get my bearings.
Reply 3
Mar 24, 2025 | 11:31 AM
  #142
Quote: I just look at my feet while facing the car to get my bearings.
How do you drive? You should use the gas and brake with only your right foot.
Reply 0
Mar 24, 2025 | 02:09 PM
  #143
ODDITIES...
Reply 0
Apr 23, 2025 | 01:10 PM
  #144
Upgraded Coolant Lines
I completed this DIY this past weekend. I've read these coolant lines start failing around 60-70k miles so since I've purchased the vehicle less than 6 months ago with 64k miles, the brutal Florida summer wasn't proposition I was willing to entertain. The difference was I elected to replace the coolant lines while upgrading to rubber hoses. The oil filter plunger was replaced too. Reinstalling the new coolant lines was EXTREMELY challenging due to the tight space. Overall this isn't as difficult as one would assume, just make sure you have the requisite tools along with patience and perseverance. Finally, when attaching the upper radiator hose to the thermostat housing make sure the retaining clip is closed(down position) and push the radiator hose collar thru the retaining clip until a "click" is heard otherwise your car will overheat leaving you stranded because the hose popped out. Here's what the line looks like without thermostat and serpentine belt. I'll tackle replacing the water pump, pulleys, gaskets and resealing the driver's front timing cover at another time because it'll be pretty straight forward without dealing with risk of breaking the coolant lines. Thanks to kevim14 for providing the DIY write up.
Turbo Coolant Lines
Turbo Coolant Lines
Reply 1
Apr 25, 2025 | 05:27 PM
  #145
Here's another vantage point
Reply 1
Apr 26, 2025 | 08:49 PM
  #146
Helpful post ....
Thanks for all the great info ... helpful!
Reply 0
Jan 30, 2026 | 09:56 AM
  #147
For those unfamiliar with this work,
Billet Aluminum Turbocharger Coolant Line Fittings for Mercedes M278 and M157 Engines
Reply 5
Jan 30, 2026 | 12:44 PM
  #148
Great video of the work and looks like great aluminum parts! Thanks for sharing
Reply 0
Jan 30, 2026 | 02:12 PM
  #149
Quote: Great video of the work and looks like great aluminum parts! Thanks for sharing
Glad you like it. I have been following his offering since last year, and today an owner bought and installed them posted some photos
Reply 0
Jan 30, 2026 | 02:51 PM
  #150
Without much info on the person who is selling these, it would be nice for someone to vouch for their standing.
I put a bunch of info into ordering, then realized that I couldn't even contact the seller from the link above before making the purchase. Which is ok, as long as I know from others that they are reputable.
Reply 1
