Is this normal?
Old Oct 4, 2024 | 09:27 PM
E63SAMG2014's Avatar
2014 E63 / 2017 CLS 63 / 2015 G63
Is this normal?
Foremost, the video is not mine. I’ve captured to share the “noise” I hear when I’m WOT or above 5K RPM upshifting.
Hello Gents!
please listen to the noise in the video.
I’ve noticed when I’m upshifting at 5K rpm in manual mode or Sport/+ it makes this noise in the video shown. It doesn’t make this noise when I’m in Park or Neutral and revving it above 5K.
Only occurs when I’m WOT or upshifting above 5K RPM.
Below 5K rpm, NO noise.
Is this normal?
File Type: mov
Old Oct 4, 2024 | 09:48 PM
PeterUbers's Avatar
Saw this and he said resolved with trans oil??
https://mbworld.org/forums/w212-amg/...ues-again.html
Old Oct 4, 2024 | 09:49 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
look up waste gates
They open to help spool down turbos
these valves go bad when not sealed.
Enjoy.
Old Oct 5, 2024 | 12:23 AM
look up waste gates
Enjoy.
Well said, I too was suspecting wastegate.
thank you
Old Oct 5, 2024 | 10:50 AM
If the wastegate were to be a culprit, won’t it rattle or the noise will be constant during any and all rate of rpm shifts? Lastly, won’t it throw CEL? Hmmm….
Old Oct 5, 2024 | 01:05 PM
What I heard is working wastegates doing their job.
Leaking waste gates is some boost lost
Failed wastegates are no boost pressure
DTC for low boost can be activated.
Right now it's working well.
Old Oct 5, 2024 | 01:19 PM
Right it's working well.
thank you so very much for your feedback.
Old Oct 5, 2024 | 01:39 PM
OldManAndHisCar's Avatar
W212 E63S Wagon - GSL580 - E63 - E350 - C300
Curious, what engine is that? That does not look to be an AMG car
Old Oct 5, 2024 | 02:04 PM
PeterUbers's Avatar
s63 with m157; it comes from this link in post #2, it discussed a while ago, the OP says he has a similar sound
Old Oct 5, 2024 | 02:21 PM
Cannot recall seeing an AMG with a tri-star hood ornament sine the early 2000's
I’ve captured the video uploaded from that exact post. Also commented for a feedback without a reply.
it seems as if I’m not the only one experiencing this “noise” when shifting at high RPM or WOT
It seems ludacris to me that “trans service” fixed the noise. The noise is coming from under the hood (front of the grille) not beneath the car.
Old Oct 5, 2024 | 02:24 PM
search 2018 s63
