Checking timing without disassembly?
Old Oct 30, 2024 | 09:23 PM
max.gibson's Avatar
2013 Ml63 AMG
Does any have a trick for checking timing without disassembling anything major? I found a video of a guy checking an M276 through the sensor holes but wanted to see if anyone had any advice on this subject. Thanks! M157
Old Oct 31, 2024 | 08:28 PM
Baltistyle's Avatar
'13 s212 63 p30. '06 LX470
That is the way. Xentry could also help you see it.
Old Oct 31, 2024 | 09:47 PM
max.gibson's Avatar
2013 Ml63 AMG
The crank position is 53 degrees right?
Old Nov 1, 2024 | 03:32 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
ZERO DISASSEMBLY...
you can read the correction being applied by ECU to make up for minute "chain stretch".
When in doubt... go ahead replace the limp tensioners that leaks oil pressure the VVT Gears need.
Tensioner looseness allows camshafts to roll forward using available slack... that detunes smooth even timings.
Best tensioners are racheting type. Here instead MB went with low friction...
Sealed oil pressure is the only thing that can keeps them put still. The shaft seal is also its rubber guide soft bearing... keep 'em mint for free with lifetime warranty.
Old Nov 1, 2024 | 09:24 PM
Baltistyle's Avatar
From 32 mins.
Old Nov 1, 2024 | 11:20 PM
BEYOND THE HORIZON...
Thank you for sharing this video from a brilliant lad shop.
What do M278 post-mortem, inspection and repairs video have in common ??
dry interm. shaft grooved ($500Ea.)
4x chains setup
4x chains setup
They share standard failures:
New Camshafts + VVT Gears + Tensioners.
Here we missed seeing cylinders walls /pistons rings /con.rods bearings.
What ties all this destruction :
Built-in Limited Lubrication!
