Which Engine Oil?
Old Oct 5, 2025 | 04:40 PM
  #126
Jaybird123's Avatar
2015 E63S Sedan, 2014 E550 coupe
Originally Posted by jvakos
@Jaybird123 hey been digging into oil options and found the Mobile 5W50 supercar oil you referred to in this post from last year…. Is your car tuned and if so how did this oil perform vs the standard 0W40?
Yes my car is tuned (E40 from Jerry EC). I have no data as I have not done Blackstone analysis on any of my oil choices, but I have used M1 supercar 2-3x now and like it! What does this mean? I like the look of the oil when changing (not black), and I do not get excessive fan noise (headlights or engine), plus my oil temps stay below 215F consistently for almost 3k miles. I change right at 3k miles.
I cannot say if I prefer it over similar Motul, but I like the M1 price and Amazon availability. Amsoil is my favorite oil thus far, but I find it price prohibitive given the high mileage and 3 MB’s I maintain
Old Oct 5, 2025 | 07:41 PM
  #127
E63SAMG2014's Avatar
2014 E63 / 2017 CLS 63 / 2015 G63
Redline 5w40
does anyone have feedback on their experience?
Old Apr 3, 2026 | 04:22 PM
  #128
W205C43PFL's Avatar
New oil certification:
Old Apr 3, 2026 | 11:45 PM
  #129
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
K.I.S.S.
New oil certification: https://youtu.be/FwuKXRod5hk
I like Jason's studies & subsequent presentations. He used to have better coverage.
Jason touch base on familiar topics but could do a much better job showcasing his sponsor high-detergent oil.
"Advanced Clean" is the answer from Mobil1 own additives formulator.
The viscosities match smaller engines application we can't touch with our hydraulic Phasers.
There is an easy way to run all the jobs of lubricants... it's available from effective oiling instead of limited oiling!
Oil cleans when it stops burning.
If you want to wash off burnt oil deposits, this product is not MB Approved.
Lately the development of cleaning oil speaks to mounting blowby issue from hot crusted rings.
Old Apr 4, 2026 | 04:40 PM
  #130
against oil additives...
The 'Motor Oil Geek" speaks against additives with lab numbers.
> BALANCED FORMULA....
The rational is additives are concentrated extreme formulations designed to boost engine oil.
The issue is that engine oils are well balanced blends that suffer when boosted one way too much. Meaning too much of a good thing is bad.
Lake briefly talks about friction vs. wear additives to say lower friction can add wear.
> CLEANING FORMULA...
One of the hot topic not discussed is oil detergent. It's a tough act because what loosens deposits also makes the oil film not cling well.
The new cleaning chemistry featured in Valvoline and now Mobil1 lubricants is an advanced agent that may work without hurting lubrication too much.
> DOUBLE-TALK...
In todays video Lake repeatedly talks about extending drain intervals...
In prior videos Lake spoke about drain intervals as a wholesome bad idea to stretch oil life beyond its effectiveness:
  1. high contaminants are abrasive!!
  2. oil dilution from fuel is quickly bad!
  3. lower sheared viscosity impact spray Rpm
  4. degraded formula components
Improving pistons ring seal delivers a lot of positives including less contaminants.
Old Apr 15, 2026 | 03:18 PM
  #131
W205C43PFL's Avatar
YT VDO
> CLEANING FORMULA...
> DOUBLE-TALK...
Great video : )
Old Apr 18, 2026 | 06:14 PM
  #132
SuprSpeedrBaker's Avatar
2012 E63 P30 wagon.
Does anyone have any UOA on our engines for some of these oils that are being recommended?
Old Apr 18, 2026 | 06:38 PM
  #133
Used Oil Analysis
Yes there's a thread sharing UOA printouts of the usual oils. You can review used viscosities of group-III oils and chemistry components of SN vs. cleaner SP oils.
Getting your own engine sample analyzed can let you spot significant fuel dilution from rings blow-by and leaky injectors.
All oils are good for a while from ~3 to 5k Miles then fall out of spec more or less fast. Fresh oil is the simple way to mitigate issues.
Old Apr 20, 2026 | 10:38 AM
  #134
ChrisHimself's Avatar
SPONSOR
11 E550, 16 AMG GTS, 13 S550
just checking in to make sure everybody remembers me
__________________
Alpha European Autotech
Purchase Amsoil at 25% off from me
Chris Tran, Retired Alpha European Autotech Owner
Amsoil Independent Dealer #7236674
Old Apr 20, 2026 | 11:22 AM
  #135
W205C43PFL's Avatar
