Infotainment/COMMAND System Issue
Old Dec 21, 2024 | 10:34 AM
e.bach's Avatar
2014 Mercedes E63s AMG Wagon
Exclamation Infotainment/COMMAND System Issue
Hello World,
New to the forum. I just recently purchased a '14 E63s Wagon and I am trying to troubleshoot an issue. Love the car, but something seems screwy with the infotainment/COMMAND screen/system.
I first discovered the problem where I was listening to music and the screen froze and went black and then restarted. Upon restart, the screen stopped on "WARNING: do not let command distract you"
I tried to reset by holding the power button for 15 seconds and the mercedes logo will appear and do the run through, but still get stuck on the WARNING message. The radio plays, but i am unable to change anything.
I installed a new main battery in the car thinking that it would solve the issue (from what i read) but it seems it doesn't change anything.
The only thing that seemed to work is turning the car off and locking it for an extended period of time (~1 hour) which i think fully resets it.
I have also pulled the fuses and everything looks fine.
Sometimes i don't have issues with it and it works right...but i noticed it sometimes freezes when coming to low speeds and shifting the car into reverse to park it. the screen will just go black and the parking cameras do not appear.
Could it be the cold temperatures here in NY?
Does the system need to be updated?
Could it be the auxillary battery in the rear that needs replacing?
Looking for answers...
Old Dec 21, 2024 | 04:26 PM
thesaintusa's Avatar
2019 911 GTS / 2016 X3 / 2015 E63s / 1993 RX-7
Not the cold temps.
We see -40F temps in the mid winter, and the Command System works just fine.
Old Dec 21, 2024 | 05:12 PM
JettaRed's Avatar
Veteran: Army
Get a Mercedes-specific scanner and scan the COMAND module. (Only one "M")
Reach out to @BenzNinja at info@benzninja.com. You should consider subscribing to his services so that you have armchair support whenever you need it.
Old Dec 21, 2024 | 10:09 PM
PeterUbers's Avatar
Have you asked a dealer to update comand to the latest software?
Old Dec 22, 2024 | 02:22 PM
e.bach's Avatar
No, i haven't brought it to them yet. I plan on bringing it in a week or two.
Have you had experience having them update it? Do you know if there was a larger update in years following production?
Does the interface change?
I read somewhere that the 16s had an update UI.
Old Dec 22, 2024 | 03:31 PM
PeterUbers's Avatar
I think I had a Bluetooth issue and they did some software update back in 2015 and that helped it, no updates since then and you very well May have a hardware issue such as the whole head unit may need to be replaced or there is a wire harness issue
Old Dec 23, 2024 | 09:15 AM
JettaRed's Avatar
Veteran: Army
COMAND stands for Cockpit Management and Data System.
Old Apr 15, 2026 | 11:12 AM
otherperry's Avatar
c300
Hello World,
Did you ever get this resolved? If so, was it by having the dealer scan it and update software?
I’m having the same issue…stuck on warning screen…times out and recycles over and over again. Changed main battery too just like you did.
