swtiched 12v from dome light
Now I want to install a blackvue dash cam in the same manner. I guess Im being lazy and don't want to run the wire to the trunk for a true switched 12v source that dies as soon as the car is off. I wired the camera using the same source as the radar detector. I left the multimeter on the battery to see how many volts were used in the 1 hour before the camera actually turns off. The camera used 0.1 volts over 1 hour.
So I guess my question is, how taxing is this on the cars battery over time? Last month I installed a new main and aux battery.
Im thinking there are quite a few scenarios that come into play in regards to charging the battery. Does the alternator start to recharge the battery every time the car is running or will it only start recharging after 20 minutes or so? If the latter is true, I could see how multiple short trips throughout the day would would use more voltage for the camera without a recharge.
It keeps the main battery from draining and extends the dashcam running for up to 18hrs with the battery pack. Pretty useful if you ever have to leave your car parked somewhere and keep an eye on it.
- Normal Mode (Wi-Fi On/GPS On): ~350mA/hour
- Normal Mode (Wi-Fi Off/GPS On): ~310mA/hour
- Parking Mode (Wi-Fi On/GPS Off): ~265mA/hour
- Parking Mode (Wi-Fi Off/GPS Off): ~225mA/hour
