Changing oil, finding snakes, getting bit and falling to the car....
Old Apr 1, 2025 | 03:55 PM
OldManAndHisCar's Avatar
W212 E63S Wagon - GSL580 - E63 - E350 - C300
So...I get my new Molygen into the car. Ready to start it...Button everything up, get the key...getting in...
I have one foot off of the ground falling into the drivers seat. Just as I start to lean in a black snake shoots out from under the GLS towards me - jumping backwards and falling down (into the seat) I pull in my foot, bite my tongue as bad as any human can bite their tongue...blood pouring from my mouth the snake can not be found...to that, this is a HARMLESS black snake, maybe 3' long. Not some rattle snake, cotton mouth or python (all live here). I see the most innocent snake....and got bit.
For me? Well, I blame the folks at FCP as my order got here early. Had it got here at their estimated time I would not have yet changed the oil.
Old Apr 1, 2025 | 05:48 PM
FastWgn's Avatar
2016 E63 Wagon
Jebus - an advantage of living in the chilly Northeast. No snakes or scorpions up here!
Old Apr 1, 2025 | 06:32 PM
W205C43PFL's Avatar
Ah! Actual snake, I thought we were talking about snake oil when I read the title. Glad to hear you are fine.
Old Apr 1, 2025 | 08:27 PM
JettaRed's Avatar
Veteran: Army
... Well, I blame the folks at FCP as my order got here early. Had it got here at their estimated time I would not have yet changed the oil.
LOL! Could I ever start a political firestorm with that comment!
Old Apr 1, 2025 | 08:35 PM
JettaRed's Avatar
Veteran: Army
By the way, I changed the oil in the C350 with some Molygen New Generation 5W-40 that I didn't want to go to waste because it is only API SN rated. But I figure the car was happy with SN before SP came out, and she seems to like it very much. I was taken aback by the green color at first, thinking I had just poured antifreeze into my engine. But no, it was just green oil. I also figure for a non-turbo engine, LSPI is less of an issue. I actually got much better mileage with it on a recent trip of 65 miles mostly highway. I saw about a 10% improvement.
Old Apr 1, 2025 | 09:01 PM
MB2timer's Avatar
Veteran: Army
Veteran: Navy
SL63
When I saw the title of the thread(quite catchy actually) I immediately thought someone played the old rubber snake in the car gag on you. Come to think of it, if I am ever in your neighborhood, I might just set that gag up for your enjoyment. Maybe I will even record it and post it to the forum, so everyone can enjoy it.
Old Apr 1, 2025 | 09:04 PM
juststeve's Avatar
2012 E63 Wagon
I get up first and mornings end up taking the wife's little terrier out. I've got aggressive geese in the backyard pond and five or more coyotes in acreage next door. I may as well have a raw steak at the end of the leash.
Old Apr 2, 2025 | 12:36 AM
EckFe1's Avatar
993 cab, 2014 E63 AMG 4matic T
April fools
Old Apr 2, 2025 | 08:21 AM
W205C43PFL's Avatar
Ah departing from Pennzoil? Interesting, good to try different things : )
Old Apr 2, 2025 | 09:02 AM
That was my first "Oh Shiit" moment of the day.....
Old Apr 2, 2025 | 10:08 AM
JettaRed's Avatar
Veteran: Army
I'm still using Pennzoil in my SL400. I had bought the oil change kit with 7 liters of Molygen from FCP last year before the API SP rating became a thing. So, I thought I would try it in the non-turbo M276. As I said, the car seems to run really well with the Molygen (which is also discounted by FCP as "overstock" now).
Old Apr 2, 2025 | 12:01 PM
W205C43PFL's Avatar
Thanks for bolding the important parts, much easier to read for people like me with poor reading comprehension skills.
Old Apr 2, 2025 | 05:27 PM
JettaRed's Avatar
Veteran: Army
No problem. You're welcome.
Old Apr 2, 2025 | 05:38 PM
W205C43PFL's Avatar
Speaking of which, will you try different types of engine oil or still perfectly happy with Pennzoil on the SL 400 as well?
Old Apr 2, 2025 | 05:52 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
Lubrication without friction
SN formula is one of the greatest dry lubricant there is because ZDDP clings super well and so does Molybdenum too.
LM5W-40 SN is a better lubricant than LM5W-40 SP formula.
Old Apr 2, 2025 | 09:41 PM
JettaRed's Avatar
Veteran: Army
Good to know. It seems FCP is discounting the Molygen, so it may be a good buy for non-turbo cars.
Old Apr 2, 2025 | 09:56 PM
JettaRed's Avatar
Veteran: Army
For now, I'm sticking with the Pennzoil for the SL400.
Old Apr 2, 2025 | 10:58 PM
MB2timer's Avatar
Veteran: Army
Veteran: Navy
SL63
You must put the emphasis on the wrong syllable.
Old Apr 3, 2025 | 05:54 AM
W205C43PFL's Avatar
I see.
Old Apr 3, 2025 | 08:20 AM
Wait, am I NOT supposed to have Molygen in my turbo car???? @CaliBenzDriver
Old Apr 3, 2025 | 08:21 AM
Originally Posted by EckFe1
April fools
I wish, my tongue is still jacked up....it is a funny story however.
Old Apr 3, 2025 | 10:23 AM
JettaRed's Avatar
Veteran: Army
I know your question was to Cali. I may try it in my turbo car at some point, but I don't want to jump around too much. I did also notice that my non-turbo engine sounds quieter on startup and idling with the Molygen, not that it was unusually noisy to begin with.
Old Apr 3, 2025 | 10:24 AM
JettaRed's Avatar
Veteran: Army
You know, it was only a snake. Coulda been an alligator where you live.
Old Apr 3, 2025 | 12:21 PM
LM SN / SP vs. LSPI
In your turbo engine you should use the manufacturer recommended lubricants unless you've decided to experiment non-factory setups...
JR mentioned that because he scored a sale on original LM 5W40 API-SN that's not as good as newer API-SP against pre-ignition (LSPI) issues on turbos.
This is only an issue on extremely hot pistons when uncontrolled oil is bypassing stuck rings to spontaneously pre-ignite to explode a piston proper.
You may get the upper leg with spray cooled pistons at low speed combined with clean sealed rings lubricated with API-SP formula. That's what MOD-4 delivers.
The key is....:
LSPI needs extreme piston heat
No dry pistons > no problem!
Old Apr 3, 2025 | 01:05 PM
@CaliBenzDriver My oil sits at 212 or so, as high as 220 if I am on the car....
